Old 01-08-2011, 06:54 PM
Mikes455Wagon's Avatar
Mikes455Wagon Mikes455Wagon is offline
Well, I have mine on the car and took some pictures before removing them to get them coated. They fit wonderful and I believe a stock starter will still fit. They headers look like they are gonna be our header solution. The only spot I found that was tight was the drivers side collector flange is very close to the floorboard. I spoke with Mark and will be sending him pictures so he can adjust this on the next set. I will say Mark seems to be a GREAT GREAT guy to deal with and I am very happy with the work. I will get pictures up as soon as I can.
  #42
Old 01-08-2011, 11:58 PM
Here are some pictures...enjoy!
  #43
Old 01-09-2011, 12:42 AM
crossbreed455's Avatar
crossbreed455 crossbreed455 is offline
Looks good. All tig welded too
  #44
Old 01-09-2011, 02:35 AM
Cartman TD's Avatar
Cartman TD Cartman TD is offline
Send a message via AIM to Cartman TD
SWEET!!!!!!! They look great! I found what my next project is going to be for my GP once i get the carb rebuilt.
  #45
Old 01-09-2011, 09:39 AM
ponchbro's Avatar
ponchbro ponchbro is offline
Thanks for the picture's!! Like you said it would be nice to see the driver side dropped down just a bit!
78 Grand Am,455,KRE D-Ports,Turbo 400 conti conv,3.42 Rear
  #46
Old 01-11-2011, 11:09 PM
ONEFASTLEMANS ONEFASTLEMANS is offline
those look better than my old indian adventure headers ever did..
  #47
Old 01-12-2011, 02:18 AM
matt65's Avatar
matt65 matt65 is offline
Be sure thank candyman for hijacking my trailer and bringing his pos up there!
2 '65 Tempest hardtop.
  #48
Old 01-12-2011, 04:03 PM
Olds80Six Olds80Six is offline
Yeah, that crazy bastard held me at knife point while I trailered his car all the way there and back!
  #49
Old 01-13-2011, 12:55 AM
All that sounds like something my friends would say about me!
  #50
Old 01-13-2011, 01:06 PM
RA462's Avatar
RA462 RA462 is offline
Good to hear someone is making headers for REAL G-Body Pontiacs.
ONEFASTLEMANS what are you using for headers for your car?
Todd Sedlmeier
Who ever thought pinewood derby cars would lead to this!
October 2004 HPP Shootout participate
http://www.highperformancepontiac.co...out/index.html
86 Grand Prix
535 High Port 8.93 @ 153
65 GTO
433 High Port 12.04 @ 113
  #51
Old 01-13-2011, 08:41 PM
ugpkgb's Avatar
ugpkgb ugpkgb is offline
This is the junk I made. As you can see I am very primitive and have very little skill when it comes to header fab. I really need to get some cash together.
ID:	230848   Click image for larger version
  #52
Old 01-13-2011, 08:52 PM
T.D.Vick's Avatar
T.D.Vick T.D.Vick is offline
Mike,
What size were the headers that you bought, 1 3/4? Did it look like there would be room to get a band clamp around that slip tube connection? I'm concerned about a leak with running full exhaust but it would be nice to keep the slip fit.
'80 Grand Lemans
Was 301 C.I. Will be bigger soon.
00 GTP NBM / Graphite, Stock
Sold Aug. 2011
70 GTO Black / Black TH400
460 CID, 542 FWHP, 580 FWTQ
(Sold, Fall '09)
04 GTO Black / Black M6
Back to bone stock and sold, fall '05.
  #53
Old 01-14-2011, 02:21 AM
T.D I do not believe your gonna be able to get anything around the pipe there. A regular band clamp might go but isn't going to do much. The ones I have are 1 3/4" tubes. If you aren't worried about having to take the header in and out without jacking the motor up I would take the torch and sweat it with brass. I really think that would be a good way to seal it up. However, Candyman says to put some anti seize on it (which I agree totally with) and slide it together and he has had no leaks.
  #54
Old 01-20-2011, 02:17 AM
matt65's Avatar
Looks like too much time on your hands stud. Gotta stop with the driving drunk in bulldozers.
  #55
Old 01-20-2011, 02:28 AM
matt65's Avatar
Candys ran today and it don't leak. One slip fit is not a problem.
  #56
Old 01-20-2011, 11:33 AM
ugpkgb's Avatar
Get your facts straight. It was a front end loader and i was found not guilty. Now as for having to much time on my hands. Yes I guess I do.
Andy
  #57
Old 01-20-2011, 09:37 PM
ONEFASTLEMANS what are you using for headers for your car,, im using the old indian 1 1/78 round ports
  #58
Old 02-03-2011, 11:08 AM
shotgun shotgun is offline
PY Staff -Tech
Mike, a few questions.
I see you "adjusted" the rear of the lca mounts with a sawzall , was this needed for the install?
Also the d/s collector seems to be pointed downward, ie not perpedicular to the frame/floor.
Is it or is it just an illusion from the photo angle?
"resurfacing Pa highways 2 long black strips at a time"
78 Olds Cutlass Drag car PONTIAC powered with 440 (destroked 455), th400, 12bolt with spool 4.10z
Best to date 10.00@130.92 mph at 3250#
79 Grand Prix, will be new home for the 440
Goal 9.75z@135mph at 2900#
83 Malibu Wagon UUV Crate 350, Custom T5, 8.5 with Auburn posi 3.73z
Making it the Ultimate Utility Vehicle
Go, tow and show (not so much show, yet)
  #59
Old 02-03-2011, 01:00 PM
Shotgun, the header collector is pointed downward slightly on the drivers side so there is no illusion there. As far as the LCA, it was trimmed years ago to clear other headers that were "attempted." This will not be necessary with these headers though as there is a good bit of distance between the LCA and the pipes(a couple inches).
  #60
Old 02-03-2011, 07:47 PM
PY Staff -Tech
