#41
Give it a try
#42
Give it a try, there might be slightly more to it than that.
#43
Just so you know, I'm not trying to diss your work, Craig, just going by what it looks like in the pic. I just ordered one and do have access to a machine shop, so I think I will.
As a side note: Does everyone else show a forum database error when they post? |
#44
Will be interesting to see what you come up with. Which cap did you order #1 or#2 as their construction is different? Harold you always have a way with words.
#45
Where's the popcorn eating guy when you need it? I like beer anyways..🍺🍺🍺
Mike/Illinois |
#46
#47
RC 15 Caps
Thank you Norwood for your meticulous efforts to bring us as close to original parts as you can. Let us know when they are available for purchase. I'll need 3 RC15's for my '72s.
You're the man Craig! |
#48
I believe Craig already has them available. Craig, I ordered the one that newyorkrestomod sells.
#49
Craig ...How much more different is a 73 rad cap...I need to go look at mine but it's a Pain in the arse to get off...
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's |
#50
I'll answer that the '73-6 used the RC 33 cap. No ears, so easy to see the difference.
#51
Thanks HFR. NO wonder it's a pain....
#52
Harold you won't be drilling that onE that is design #1. I like that cap better but I think that it's graphics are earlier than the Goodmark cap
#53
Craig, isn't that the one that you show you drilled? When you say earlier graphic, what year(s) are we talking? I noticed the distance from the arrows to the impression is different.
#54
That's the first design one in my post .
#55
Okay, so, why not be indenting the rivet?
#56
How about this ....the 2 repop caps are not of the same construction. Let's see what you come up with for the one you bought. Post it up after you do whatever you are going to do
#57
Brake and clutch rivet.
Kinda looks like a brass brake or clutch rivet on the early ones. Then GM or whom ever switched to a metal piercing solid rivet for ease of assembly and speed on the later ones.
Surprising how the re-pops just cant get enuff brain power together to make it exactly like the original. Looks like they just need the right set-up and proper rivet. Norwood, I don't think FShaker is trying to marginalize your work. Looks like you used a brake/clutch rivet as a replacement on the first one that looks more correct. Nice work
White/Blue 71 455 HO T/A Auto Blue/Blue 71 455 HO T/A 4 Sp White/Sandalwood 71 455 HO T/A 4 Sp White/Black 70 RAIII T/A M21/373 (stripper) Carousel Red/Black 69 GTO Judge 4 Sp 2002 Firehawk Red/Black 6Sp |
#58
Craig, my caps arrived today and they look great! Again, nice work and thanks for getting them shipped out so fast.
Cheers, Tim |
#59
Skunk... exactly. Craig hasn't stated what he's done. In the pic it looks like he drilled the divot, that's why I keep going there. Now it's mentioned that a rivet was used. It always comes down to proper communication. Email and texting just doesn't quite substitute for face to face or telephone conversations.
