Old 06-30-2015, 11:33 AM
MescaBug's Avatar
MescaBug MescaBug is offline
Yes. You can buy different speedo gears to accomodate a change in gear ratio or tire size.
If swapping to a 8.5" unit, you need the correct U-Joint or an adapter for the driveshaft.
  #42
Old 06-30-2015, 11:38 AM
Josue's Avatar
Josue Josue is offline
Are the yokes different between 8.2 and 8.5?
  #43
Old 06-30-2015, 11:41 AM
MescaBug's Avatar
Yes they are. I believe the 8.2 yoke has 25 splines pinion and the 8.5 is 30. The 8.2 uses straps for the u-joint, 8.5 I think uses U bolts...
I might be wrong... Its been a while since I swapped diff units!
  #44
Old 06-30-2015, 11:49 AM
Josue's Avatar
I'll dive into it more. It's a good thing for these forums! Little things like this is what would have sank the project for sure. I like knowing everything I'm going to encounter before starting a project, so I can just get in there and get it done. Not have to wait a week or 2 until I get the part I need and the time to work on it again!
  #45
Old 06-30-2015, 11:53 AM
MescaBug's Avatar
I always read the forum before starting a project. Better be safe than sorry!
I hate to have a car on blocks because I'm missing a crucial parts that might take weeks to find...
  #46
Old 06-30-2015, 11:57 AM
Josue's Avatar
Exactly! Plus in my case, I have a 3yr old and a 10 month old, and a wife who stays home with them full time, so it's hard to balance work and them, then try to find time to work on a car for fun without making it seem like I'm ditching her with the kids more than the 40hrs a week I already do for work!
  #47
Old 06-30-2015, 01:55 PM
You will need to shorten the drive shaft by around 3/4" and change the rear U-joint (you need an adapter joint) when swapping in the 8.5 rear. The yoke on the 8.5 uses straps instead of U-bolts. Shortening the shaft is a small price to pay for the opportunity to use a far superior third member, also gives you the chance to freshen up both U-joints and have it all balanced.
Forget yoke swapping, even if they did interchange you'd be messing up the pinion bearing preload.
  #48
Old 06-30-2015, 02:01 PM
Josue's Avatar
And deeper into the rabbit hole I go!!
How do you go about determining the length of driveshaft you need then? i.e.- if I follow through on the 200R4 swap, I don't recall the driveshaft requirements for that, so maybe I'd just get the trans and rear end in, then measure it out from there? Or maybe driveshaft companies would know the length I'd need for that trans/rear end setup.
  #49
Old 06-30-2015, 02:19 PM
Driveshaft companies can't tell you an exact length for any custom or swap application, but they can tell you how to properly measure to determine what length you need:http://www.dennysdriveshaft.com/how_to_measure.html
  #50
Old 06-30-2015, 04:14 PM
Josue's Avatar
Seems simple enough!
  #51
Old 06-30-2015, 04:29 PM
JLMounce JLMounce is offline
Yeah it's a simple job, takes just a couple seconds once you have the vehicle in the air.
Had to do this when I installed the Moser 12 bolt. The pinion is a bit longer on the snout than the 8.2 that I took out.
In the end it was a good thing because my stock shaft was in very poor repair. The slip joint was badly pitted, the shaft showed signs of corrosion from the inside out and both u-joints were in need of replacing. I had a custom aluminum shaft built with a new slip joint, solid 1350 series u-joints etc.
-Jason
1969 Pontiac Firebird
  #52
Old 06-30-2015, 04:36 PM
Josue's Avatar
That's a good way of putting it too, because like I said, this car is just about 95% original mechanically, so having to replace all this stuff would be a good idea anyway!
Who did you get your driveshaft setup from?
  #53
Old 06-30-2015, 05:36 PM
Doug Hopkins's Avatar
Doug Hopkins Doug Hopkins is offline
I had mine built at Columbus Joint & Clutch. (Ohio)
  #54
Old 06-30-2015, 05:41 PM
You might consider using the stronger 1350 yoke that Moser and Jeg's offer for the 8.5, and having the matching joints installed in your driveshaft build.
  #55
Old 06-30-2015, 05:51 PM
I had mine done locally. Northern Colorado Driveline. They have a reputation for quality work and the price was much better than some of the widely used online shops. It cost me $340 in total for a complete driveshaft, slip joint and solid 1350 series u-joints.
-Jason
  #56
Old 06-30-2015, 06:02 PM
Josue's Avatar
Nice. I'll have to look into locally sourced shops then, like you guys did.
Doug - Did they build you a whole new driveshaft? Or you had your stock one modified/repaired?
  #57
Old 06-30-2015, 06:26 PM
I took them my busted shaft They used the front yoke (TH400). They then built a shaft that would handle 550 HP with tires . New shaft and joints with a 1350 joint at the rear and balanced. It was $275 out the door. The guy that runs Columbus Joint & Clutch is a racer, so he knows what it takes for a driveshaft to live. The shaft itself was larger than the stock shaft. You give him the distance from the rear trans seal to the rear u-joint center of the yoke with the rear under load, and he will build it in a day.
  #58
Old 06-30-2015, 06:46 PM
Josue's Avatar
Damn, not bad at all! Thanks for the tip!
  #59
Old 06-30-2015, 10:23 PM
Josue's Avatar
Checked with the neighbor tonight, I was wrong, it's only a 8.2 10 bolt. I guess I could still go with it if I wanted to save a good bit of money for now, and I wouldn't even have to do the driveshaft or anything yet.
It all depends on what I'll do with my budget...if I want to drop most of it on a 400 build, then I'd get a better axle from Jim. If I end up just keeping the 350 in there for now, spending money on brakes, suspension, OD trans, and wheels, then the 8.2 with 3.08 posi will be just fine I'm sure.
  #60
Old 06-30-2015, 10:30 PM
Grab the neighbor's 3.08 geared 8.2, even without a posi it's worth more than $100.
It will give you a nice boost in street performance and still be decent on the highway.
