Old 12-04-2016, 07:04 PM
Ron Landis's Avatar
Thumbs up Sweet!!!
Had two '77s...wrecked the first and bought another one just like it. Only had the first one two months. Love to get another. I never had a 4-speed. Are the bell housings really orange on those cars? Anyway...looks like a really nice one you snagged there. Enjoy!
  #42
Old 12-04-2016, 07:09 PM
I used the Thrush setup sold by Summit. It is very inexpensive for what you get. I have a lift and am a metalworker by trade so was able to tuck it in nice and tight. The welded connector is all wrong though - I fabbed a crossover box to eliminate this issue and allow the exhaust to tuck up an additional inch.
  #43
Old 12-04-2016, 07:58 PM
Aus78Formula Aus78Formula is offline
Who did you source the fuel tank through, what brand and how was the fit compared to stock?
  #44
Old 12-05-2016, 10:06 AM
starlightblack's Avatar
starlightblack starlightblack is offline
Originally Posted by Bentwheelbob View Post
I used the Pypes system. The quality was really good and installation straightforward. I went with dual mufflers instead of a transverse. What are you going to do for manifolds? If you use ram air mani's I have 2.5" Pypes down pipes for the ram air manifolds. Ordered by mistake and never used. I'll make you a deal on them.
Bob, I will PM you on those PYPES
  #45
Old 12-08-2016, 05:40 PM
77 Canamman's Avatar
BentwheelBob:
I like the looks of your system. Did you buy this as an all inclusive kit, or did you have to order the tailpipes, splitters, and X pipe separately?
2017 Sierra SLT 1500 Z71 4X4
2019 Canyon SLT Crew 4X4
  #46
Old 02-22-2017, 12:26 PM
I have ordered the SGF70 Pypes system with the transverse muffler and X pipe, and black chrome tips from RAMC. More to come..
  #47
Old 02-22-2017, 12:49 PM
77 TRASHCAN's Avatar
I'd like to see pictures of that!
Shut it off
Shut it off
  #48
Old 02-22-2017, 06:40 PM
burd's Avatar
burd burd is offline
I've never seen a shajesprvseal with the joint in the front. Crazy. Even back in the day.
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here
Just Say No To 8” Flakes pause pause
F ire B irds
  #49
Old 02-22-2017, 08:27 PM
granted:
Name:	Exhaust H pipe.jpg
ID:	447886   Click image for larger version
Name:	Exhaust installed.jpg
  #50
Old 02-23-2017, 01:53 AM
Are those catalytic converters?
Shut it off
Shut it off
  #51
Old 02-23-2017, 10:54 PM
burd's Avatar
Why all the Cats?
F ire B irds
  #52
Old 02-24-2017, 05:23 AM
*tap tap*
seems to be working
  #53
Old 02-26-2017, 01:29 PM
Thumbs down
I have begun this installation of the Pypes SGF70 transverse muffler exhaust system. After 6 hours of fitting, removing, modifing, and excessive cussing, I have the system about 60% completed. The X pipe, and everything forward to the headers was a good fit and straightforward.
HOWEVER..
The tailpipes are really ridiculous. Is it really that hard, or not cost effective to produce a tailpipe that is meant for the splitter tips? They will be correct for multitudes of '76-'81 Trans Ams... I hate all these extra cuts and joints caused by the adapters. Additionally, the drivers side midpipe that goes over the axle comes dangerously close to the brake hose. Again, this is an engineering blunder, and not one mention is made of this in the supplied literature. I have found numerous posts on other sites regarding this issue. This will take even more time to correct. Overall, I give this system a "D" for fitment and overall quality. It does sound nice, but is FAR FAR from a simple bolt on installation!
  #54
Old 02-26-2017, 02:54 PM
Those cats are for the EROD setup, so 75 and later cars can be legal in Cali. They come with the engine. Problem is they don't line up worth a s**t and required a bit of rework to fit correctly.
LeMans if LS'd will not need them.
  #55
Old 02-26-2017, 05:35 PM
I'm not sure if there's slight variations within the same kits or just in the cars, but the installation always seems be either so easy, or a nightmare. Mine spent 2 weeks at an exhaust shop. It was so bad it kept getting pushed to the corner and ignored.
  #56
Old 02-26-2017, 05:45 PM
Aus,
what brand/kit did you use?
  #57
Old 02-26-2017, 06:05 PM
Pypes, possibly SGF11....that number sounds familiar. All the tailpipe area, cut and shut several times and reworked to make fit, splitter hangers relocated to even be close.
  #58
Old 02-26-2017, 08:44 PM
I am going to have well over 10 hours in this system's installation, and 388 F-bombs. I have over $800 invested in the cost of the system, band clamps, adapters, etc.
I hope the improved sound, the tucked up appearance, and the performance increase will makes this remotely bearable.
  #59
Old 02-28-2017, 09:34 PM
OK, I just completed the installation of that SGF70 Pypes exhaust system. Total time for installation was 11.5 hours. I was able to clearance the drivers side mid pipe to allow 1/2" from the brake hose. I was able to tweak the main fuel line 2/3" away from this same pipe. I am still going to apply a high heat wrap to prevent the lines from getting hot. While the end results for the sound and appearance is good, I don't wish the installation on my worst enemy..
  #60
Old 03-01-2017, 12:35 AM
Only 388?
Shut it off
Shut it off
