#41
Thanks Mark....As of now the best I've been with those heads is 9.22 @ 3275. That was with a 1050 on alcohol. I put a 1250 on it and it picked up another .03 in the 1/8th. My engine is a bit bigger though 529". They are a pretty good set of standard port heads.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0 2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion and 2015 IHRA Div 5 Mod champion |
#42
Coool, what kind of intake are you running ? I like engines that are not like everyone else's. 445 block or 400 ?
#43
You bring it all on yourself George. Think you can throw shade on someone and they are supposed to take it. Rather than take it I will give it back, just because its you.
What I think happens is you drunk post a lot. Pop off after you have had a few pops. Get what you get. If I were you, short stuff I would keep my comments to myself. Runts making pep pee cracks is not a good look. You had better keep your car roots blown. If you put the right turbos on it, from the way it looks it would do a clockwise roll on its side about the 100' mark. Get that suspension fixed. All you had to do is say what in your mind makes alcohol a good fuel for bracket racing and I would have just said "thanks". |
#44
Methanol is a very consistent fuel. I do watch the weather to make dial in decisions but the only part of the weather that seems to make a difference is humidity. I could predict the car pretty well when I ran gas but you really had to stay on top of weather conditions. In a race that would last from late morning(10:00am) to late into the evening(1:00am) there could be a change in dial of as much as .07. With alcohol the car may vary at most .015 and that is late in the evening when humidity gets above about 75%. My car runs the same et's in 70 degree weather as it does in 95 degree weather. That's just one advantage though. It makes more torque also. Another is cool water temps. I run a primer plus system which injects gas into the plenum to warm up the car and keep heat in it. Between the primer plus and making the pass on alcohol I can make sure I go into the water box at 160 every time no matter if there is 10 minutes between passes or 2 hours between passes. You know that consistency comes from doing everything the same every pass. Alcohol makes every part of the pass that has to do with the engine more consistent. One example: With Norwalk being a 1/4 mile track, that means a lot of starting and stopping driving to the staging lanes, a long trip back to the pits and round robin after 3rd round. Usually the temps are in the low 90's so the gas cars struggle with maintaining water temps. When they start doing the round robin rounds if I go into the water box at 160, I make the pass and go off the track at 170. If I were to drive back on alcohol the 1/2 mile to the staging lanes to cool, I would probably be at 150 when I got back. I turn on the gas system to keep a little heat in the water so I'm at 160 when they are ready for the next round 10-15 minutes later. I keep my primer system fat so it doesn't gain much heat on the drive back. If I need it to gain heat quick I have a lean out valve I can open to lean it out. It just makes dialing the car way easier than on gas. I would bet 85% of the good bracket racers around here are on alcohol. And I bet at the Million there is at least that percentage or more. I know there aren't many tracks where you are but you should make the trip to Vegas for the Spring Fling Million. It would be an eye opening experience. That's the only big race I can think of anywhere close to where you are. There are big money races all over around here. You could hit one every weekend if you wanted. As far as the corrosion deal goes, most of that is an old wives tale. I never get any kind of corrosion. I keep alcohol in the car 365 days a year. I do take the carb off in the winter. I run top lube in the oil. That keeps any corrosion problem at bay. It is harder on the cylinder walls though, I'll give you that. I have to change an accelerator pump once in a while at the beginning of the season after it dries out. If the carb is right there is no milking of the oil and any moisture in the oil is taken out with a vacuum pump. I ran gas for years. Now I've run alky for years. I would NEVER go back to gas. There are just too many advantages that outweigh the few disadvantages.
#45
4.185 Bore, 4.050 stroke, Eheads flow 341@.700 Intake is a Wenzler early style, Flat 1/4 plate for a top, carbs are 750CFM Carter AFB's. Twist it to 7100/7200 RPM.
#46
Good post Probird!
Can you discuss the cost to switch over, the cost of methanol, in addition to availability. Quote:
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
#47
I do however get corrosion in my carbs and my foam in my fuel cell doesn’t like the alky! GTO George |
#48
George, I took the foam out a long time ago. Possibly if you had a foam made for alky it would be OK. Plus the foam wouldn't let it flow fast enough into the fittings.
I also changed a long time ago from carbs to mechanical injection, lots better and no worries about carb pieces. (have to have alcohol compatible parts for alky) And I agree with Rick on all the attributes of alcohol. More power and more consistent, what more do you need? (and lot cheaper!)
#49
GTO George Last edited by GTOGEORGE; 05-23-2018 at 11:44 AM. |
#50
GTO George |
#51
Like Rick, I run an additive, never a problem.
#52
I am not the guy who started threads about tire pressure and should I degree my cam ? You are. I know a few people who run it. Know basic things like its very high octane, cools the engine, takes more of it than gas, can milk your oil, has corrosion issues and heard guys hint is was good for bracket racing but never took it any further. Probird did what you can not. Give a detailed, respectful and intelligent answer to a question. In other words, a long post and one that is full experience and knowledge. Calling you the "Black Hole" of Pontiac knowledge would be a compliment because it would be inferring that you had some to begin with. But I can't. |
#53
So basically: Fuel pump- $485 Fuel line and fittings - $150 Big port Regulator- $110 Primer Plus w/ 1 gallon fuel cell - $560 Alky carb - depends if new or used $300 - $1200 If you have a carb you want converted over send it to Ken Jones Performance. Usually about $650 I think Barrel of alcohol- $140 Bottle of top lube - $10 A vacuum pump is also a good idea from my experience.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0 2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion and 2015 IHRA Div 5 Mod champion Last edited by Probird; 05-23-2018 at 06:28 PM. |
#55
Dragncar,
Just to clear things up! Originally Posted by Probird View Post "If your serious about bracket racing use methanol." Dragncar quote "Can you explain the , if your serious about bracket racing methanol comment. Not sure I understand." So Mr. Bracket Racer (Dragncar) this is what I commented on Originally Posted by Dragncar View Post Can you explain the , if your serious about bracket racing methanol comment. Not sure I understand. GTO George Quote "......alcohol.....Bracket Racing....you don’t have a clue huh!" I figured there is no way possible you could not know the benefits of running Alcohol when you have BIG TIME bracket racer and have Bracket Raced as long as you have.......Seriously! Not once in the above post did you ask about the NON- benefits of using alcohol in a race car. If you did I would have been the first to mention a few things (I hate long posts) to answer. so even though a long time ago I wasn't running alky but my friend did so i watched and listen......obviously you didn't! I was trying to give you a little credit....i quess I shouldn't have......sorry! GTO George |
#56
GTO George |
#57
Roots blown cars start very easily...at least that has been my experience...
#58
Ive never had a leanout valve on my engine would I install it before the blower or in the intake to lean it out.....just curious! Also this is the Fuel Additive I use, i didn't have luck with top lube so I tried something else...........Pro Blends alcohol lube works great (Pro Blend 8400 Alcohol Lube)! GTO George |
#59
100% agree on Brad Penn oil... I ran it in the funny and never had an issue.. buddy of mine would buy it but the pallet for his pro mod.. I just bought it from him...
#60
Back when I bracket raced I Loved alcohol. Has a Rupert carb and ran Brad Penn oil. I never had an issue and it was dead on consistent. I even won a super Gas and Super Street div 2 race on alcohol. Hardly anybody uses it on throttle stop racing but I did for years.
1965 TriPower GTO, 1967 GTO, 1969 GTO, 1969 Judge, 1972 GTO, 1977 Smokey and the Bandit, 1989 TA ProStreet, 1968 Firebird NHRA 10.90 racecar, 1963 Tempest S/Gas |
