#41
"...Put awesome heads on a 350 and make it run with 3.75 stroke..."
Well, it's pretty obvious that nobody here has a good 350 stroker, or knows of a good thread about one. So, since we're talkin about 350's, might as well talk about a stock stroke build. We made lots of drag strip passes with cast pistons. The 350HO build in this article used the SP 357P pistons. https://www.hotrod.com/articles/hppp...-engine-build/ I've mentioned here before about using SP cast 318 Mopar pistons, to save a few bucks, for the low budget guys. They have .020 more pin height, which is also a plus. https://www.ebay.com/itm/SEALED-POWE...5.c10#viTabs_0 https://www.ebay.com/itm/SEALED-POWE...oAAOSwUiVZ06yR With #48 heads and an 068 clone cam, that 350HO made real close to advertised hp. So, just a better cam should be able to put it up over 350hp. You mentioned good heads. With iron, it's probably better not to go over 9.5 CR. According to the CR Calculator, some 72cc heads will do it, depending of course on overbore, head gasket, & actual valve relief volume. But, 10.5 CR is supposed to be safe with alum heads. Many will remember that the member here who does the road racing, with the '68 Bird, bought some small valve KRE D-ports for his 350. They come with 65cc chambers, and you can have some shaved off if you need more CR. http://www.krepower.com/Pontiac%20Al...er%20Heads.htm Then when you get up near 400hp & over, it's probably a good idea to go with forged pistons. I've mentioned that you can buy Auto Tec pistons for a 350, for a little over $500, unless they've had a big price increase. Don't know if there are any forged 318 Mopar pistons that would work, or not. seems that I remember that the pin height may be slightly too high on most of 'em. But, since it has been said that the SP Pontiac pistons are thick enuff to machine a dish in 'em, maybe machining some off the top off the 318 pistons will work, & still cost under $500. I'll see what I can find. Nothing out there I can find that'll work. So, I reckin the Auto Tecs are the cheapest thing out there. Last edited by ponyakr; 09-25-2018 at 04:41 PM. |
#42
So... with the exception of special forged pistons, how would YOU build a 350, with off the shelf parts? Aftermarket heads are allowed. Discuss!
#43
Butler offers a 4" stroke forged crank with 3.9 bore.
The Garrett boost advisor says 15lbs of boost will produce 800 crank horsepower / 600 lbs /ft. |
#44
![]() Quote:
I'd try to find a block that would safely bore at least .060. I think Adam Strang posted that he'd found a block that would go .075. I'd have the Auto Tec pistons made with the correct pin height, to achieve zero deck height, without having to cut extra meat off the decks. Would also get valve reliefs deep enuff to use a decent size cam. Might even get BBC .990 light pins(but not too light for street use), and use Eagle 6.635 BBC H-beam rods. I think I've read that if done correctly the Pontiac cranks can safely be cut down to BBC size. Now you've got a lite rotating assembly that should safely go past 7000 rpm, with no problem, if you really wanted to take it that high. I'm a Q-jet guy, so I'd probably stay with a correctly built late '70's 800cfm Q-jet. Would probably try a port matched 455HO alum intake. Would probably separate the water crossover, so I could easily try different intakes. Would probably try a single plane, like an HSD or it's Chinese Knockoff, just to see how much low end it would lose. The cam would obviously depend on a lot of things. Since I would not be doing much high speed highway cruising, I'd probably run at least 3.73 gears. And I'd probably run a tight 10" converter, that would flash about 3500. I don't really like the idea of running a roller cam. So, I'd probably stick with a HFT. And I love Rhoads lifters. This would be a great place to run 'em, so I could run a slightly larger cam than would normally work in a 350. Again, assuming there is enuff money to do so, I'd definitely try several cams, while still on the dyno. With Rhoads lifters, I'd probably start with a Lunati 10510312 or a similar Crower, such as a 60916 or 60242. Then I'd try a Summit 2802, Howards 410141-12, & Crane 283951. Hey, if the money was there, I'd even try some bigger ones, like the Crower 60243, and even the Howards 410051-14. That's as big as I'd try, and ONLY with Rhoads lifters. A friend used an 041 in his 350 hobby stock dirt motor & did good. But, it might be a little nasty in a street 350. Assuming there's still plenty of money, I'd also try a couple of the Voodoo cams, probably the 262 & even the 268 ground with a 112-114 LSA. And I'd like to try 'em both with & without Rhoads lifters. Hey, to me it would be REALLY cool to try all these cam combos on the dyno ! And when I win millions in one of the lotteries, I'll do lots of experimenting that nobody else has done. ![]() Another thing I'd do, with a big budget, is to have the heads & block machined so that I could use Cometic head gaskets. The 350 gaskets would be much more efficient on a 350 than the 4.3 bore size gaskets. They'll make 'em with cut-outs for the cylinder chamfers. And they come is several thicknesses, so that you can set your quench distance. I've read that .040 or a little less is good. So, if you actually have zero deck height, I assume the .036 gaskets might be best. https://www.jegs.com/i/Cometic-Gaske...0-036/10002/-1 But, if the deck height is closer to .005 or .006, maybe the .030 thickness would be best. https://www.jegs.com/i/Cometic-Gaske...0-030/10002/-1 Last edited by ponyakr; 09-25-2018 at 09:24 PM. |
#45
![]() Quote:
Which heads were they ? |
#46
![]() Quote:
![]() Last edited by ponyakr; 09-25-2018 at 09:01 PM. |
#47
Could we just get some Stroke/Cubes by only using a little longer connecting rod - and have the pistons made for that ? Any longer rods that could come off the shelf and be used ?
Already hearing from a lot of folks in different areas about how slim-to-none 400 through 455 core builder engines are becoming. 326 and 350 might start becoming more commonplace for the guys in those situations trying to keep expenses more minimal. |
#48
![]() Quote:
Its getting harder to remember that build , do remember it played hell from start to finish. I'm not suggesting we do an imaginary short-deck build at all . Just curious what heads he used - guessing highly massaged Iron D-Ports. If 260cfm @ 600 |
#49
![]() Quote:
#50
"...Could we just get some Stroke/Cubes by only using a little longer connecting rod..."
Only way to get more stroke is to offset grind the crank. Buy using 6.635 BBC rods, you could offset grind a little. Last edited by ponyakr; 09-25-2018 at 09:26 PM. |
#51
dammit
brain pooted |
#52
![]() Quote:
0.060 overbore Where would we be on CID ? approx Anybody doing this would be looking for lowest buck , with some bang. |
#53
![]() Quote:
3.790" stroke (offset grind gains .040" of additional stroke). 3.935" bore at +.060".
#54
Thanks b-man
![]() So , about $500 on custom forged pistons about $300 (?) on BBChev forged rods about $200+ offset grind crank Is it going to be worth $1000+ to gain 20 cid on the 350 HiPo Budget Build ? idunno Think i might go with the stock crank/rods and use the 318 pistons for whatever maximum overbore can be accomplished. I'd use 670 heads since i have more of those than anything. Buy a book and video from whoever did those about home porting pontiac heads. Read a bunch on here about porting - then grind them babies. Q-Jet Headers Over Cam it a little with Rhoads lifters |
#55
Guys, one thing you need to keep in mind about offset grinding an OE crank is few are actually on stroke. I have personally seen OE GM cranks be as much as .035 out of stroke. There is only .050 difference between the stock Pontiac rod journal and the stock BBC rod journal. If your crank is sufficiently out of stroke this will limit or even prevent the amount of stroke increase through offset grinding. You could use the 2.100 SBC rod journal but there are only a couple of rod manufacturers that produce a 6.635 BBC rod for the 2.100 SBC rod journal.
“It takes considerable knowledge just to realize the extent of your own ignorance.” Dr. Thomas Sowell |
#56
Several have mentioned that it costs over $200 to resize the cast rods with ARP bolts.
The 6.635 BBC rods are just over $400. https://www.ebay.com/itm/Eagle-Conne...gAAOSwHz5bNCqx Eagle I-beam 5140 6.7" BBC rods are around $325. https://www.amazon.com/Eagle-SIR6700.../dp/B00BZQOUPY The RPM 5140 6.7" BBC rods are $300. But, since Paul Carter has mentioned that most all the Pontiac RPM 5140 rods he's checked needed resizing, I'd probably avoid the RPM 5140 BBC rods. http://www.racingpartsmaximum.com/sa...tockrod-2.html But, even if you go with cast pistons, you could still go with the $400 Pontiac length RPM H-beams. Cliff has said that all the Chinese H-beams he's seen are real close to spec. http://www.racingpartsmaximum.com/sa...elhbeam-2.html The 318 pistons have floating .984 pins. So, you'll need to have the rod bushings honed out slightly for pin fit. The 318 pistons + the H-beam rods are just under $500, total. And, since the rods are lighter & stronger, there shouldn't be any problem going 6000 rpm safely, if you wanna. TJ crossed the line at about 6000 rpm , with her '68 400 Bird Stocker. The Pontiac factory cast pistons made it thru that season, then nearly 3 years on the street, with no problems. And, the factory cast pistons in my '69 RA3 GTO lasted thru 60k + street miles, then 2 seasons of racing. So, if the SP cast pistons are as good, they should last just fine, as long as there is no detonation. So, you guys with the built street 350's, have ya'll had any problems with your SP cast pistons ? What's the most rpm ya'll turn, on a regular basis ? Last edited by ponyakr; 09-25-2018 at 10:34 PM. |
#57
I have Venolia forged pistons, with Tomahawk rods. I run it to 5500.
#58
![]() Quote:
If you bought the pistons new, how much did they cost, if you don't mind telling. |
#59
![]() Quote:
I really haven't been able to buzz it to 6k. Had issues nosing over at the track a little over 5k, and wasn't sure if it was fuel or springs. It was a little inconsistent. Since last track outing I put on efi, so we will see in a month or so if I solved it.
"...ridge reamer and ring compressor? Do they have tools like that?" Last edited by Squidward; 09-26-2018 at 12:17 AM. |
#60
I've always wondered what a set of e-heads or kre's would do for a 350. At the same time, I wonder how a roller cam would do. I run a 702 Voodoo in my 350, and I don't think I would run much more for a street motor. That cam caused a little softness off idle, but was remedied when I went with 3.73 gears.
It'd be fun to try a few different cams, like something a little more than what I run now. Perhaps a 703 Voodoo, or maybe a cam with ra4 specs and rhoads. It's not like there is a big body of work out there on 350's. I always wanted to try some boost on a 350, like 8psi or so. If I was going to boost, I would probably do some iron d ports, maybe with small valve 17/47/11 heads, a small cut for a little compression bump, and a cam in the ballpark of an 068 to start with as a baseline.
