Members Helping Members help Buying a non Pontiac item, transportation help, Handy-man advice, directions, vacation ideas, places to dine, ebay and generally anything you think might help other members. |
#41
2019-07-19_02-21-26 by Kerry Grubb, on Flickr
Heres what I cut with now. Poor old thing is abused, but still keeps going. 2019-07-19_02-21-17 by Kerry Grubb, on Flickr 2019-07-19_02-21-09 by Kerry Grubb, on Flickr Heres my cub. Its a 1971, Pop bought it brand new. When I was in second or third grade I decided to take it for a spin and ran head on into mom's brand new Grand Ville, broke the hood off the mower and smashed the fiberglass nose on the car!! |
The Following User Says Thank You to TAKerry For This Useful Post: | ||
#42
That Cadet has another 30 years left in it. They go for a decent buck if you ever decide to sell it too. People in the know realize they'd have to spend $5000 to get a new mower that tough.
The Following User Says Thank You to dataway For This Useful Post: | ||
#43
My plan is to restore it. I would like to start on it this fall. I quit using it because the deck started to rust away. That was the only problem, that and the fact that it is LOUD!!!
#44
Kubota zero turn with welded "Pro" deck is bulletproof.
I have a tractor with front loader, also. The front loader is awesome to have, but there's NO WAY I'd want one on the lawn mower. They really complicate maneuvering around obstacles, fences, walls, etc. (unless it's easily removable) FWIW: Eric
#45
The last thing that happened was the engine seized (Tecumpseh I think). I gave it away to a guy that fixes up old mowers and resells them. Thanks for the end user report on the JD by the way. I've been using a push mower this year until I can find the right one with a loader. I can still use that if the shovel turns out to be a problem. I need the loader more than the mower as even though I have a lot of grass to cut, I have not been unhappy pushing for a change. I just split the cutting up between different areas. Part this week, another part next week, so on.
Greg Reid Palmetto, Georgia |
#46
I like the Kohlers in my old Wheelhorses. I'm still using the '58 RJ (4 HP K91) a lot every summer. Yeah, I've rebuilt the engine twice, but that's since I got it in 1968. The '63 753 (7 HP Kohler) is now relegated to just sickle bar mowing (nasty to mount/unmount the mower). Both the Kohlers don't crank easily with their Total Seal ZGS rings, but they run great.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) ... or has a Pontiac born the same year as Jim Wangers? (1926} |
#47
The old Wheel Horse and Gravleys were also tractors that would last a lifetime. What the heck has happened to quality? I just don't understand the logic of buying 3 $1500 tractors instead of one $4000 tractor.
#48
I have a glut of old Cadets, and will be thinning the herd. Dad's estate and all. If any of you have yellow fever, bring a trailer.
$1500? bah! I got a non-running 1650 cadet from 1980 and snow blade for $100. Sold the blade on ebay for $91. My $9 cadet has been mowing my yard for 12 years now. Cost of ownership, $0.75/yr! In actuality, its about dead now, and I'm going hunting for a good Kubota 60" zero turn. The other thing I mow with (for the rest of the 5 acres) is an 1950 8N Ford with a 60", gear-driven, rear-discharge Woods mower. I suspect both to last another 50 years.
Clutch Guys Matter _______________________________________ 53 Studebaker, 400P/th400/9" 64 F-85 72 4-4-2 Mondello's VO Twister II 84 Hurst/Olds #2449 87 Cutlass Salon 54 Olds 88 sedan |
#49
Yep, bought my first Cadet, 1450 I think, for $300 used, mowed three acres with it for ten years.
#50
I did not read every comment but do yourself a favor and get one with a hydrostatic transmission. No selecting gears, the accelerator is basically just like having a gas pedal.
Mitch Kunath |
#51
I suggest you try driving a hydrostatic before buying. Some years ago I had one- holding the pedal at the desired speed drove me crazy.
#52
My last lawn tractor had a stick that you just moved with your hand same as a regular gear shift, You increased hydraulic flow by moving the stick further forward or reverse. Take your hand off the stick and it stays put at the flow you set it for, and keeps a constant flow/speed until you move it. Ariens brand mower, from the little I've read about it the same hyrostatic unit is used in many different brands of mowers.
#53
Tractor
Used to have this old tractor, it ran great but was missing the mower deck. Wish I had kept it now.
“Nothing in the world can take the place of persistence. Talent will not; nothing is more common than unsuccessful men with talent. Genius will not; unrewarded genius is almost a proverb. Education will not; the world is full of educated derelicts. Persistence and determination alone are omnipotent. The slogan Press On! has solved and always will solve the problems of the human race.” ― Calvin Coolidge |
#54
My JD x300 with the hydrostatic has cruise control. But, I rarely use it.
Remember no one is perfect. Everyone's butt has a crack in it! |
#55
Yeah, the JD twin pedal style hydrostatic seems just like driving a car. I bought my LT155 in 98. I am trying to hold of till fall for a new one. Sent from my iPhone using Tapatalk Pro |
#56
a friend of mine has a backyard half full of riding mowers , he fixes them up and sells them , and does repair , and he wont touch a hydrostatic trans,,,takes too much time, and some parts are trans specific, takes a month to get the parts in and not cheap..he only swaps the trans out ..so if u get or have a riding mower w hydro trans get a extended warrenty,, or be ready for a big repair bill if it goes bad..anyone have 10 years or more on a hydro trans ???seems like Murf from the last post has about 20 on his..am i reading that right Murf?
CAROLYN JONES(1930-1983 Actress)may she never be forgotten!! Last edited by madokie; 07-27-2019 at 01:53 AM. |
#57
Looks like it might be an old Montgomery Ward, someone like Wheel Horse or another good brand use to make them for Wards.
#58
Gilson (WI) made most of the M Ward machines.
#59
If I'm correct it's rated for a 300# trailer and has been able to pull a loaded 2000# enclosed trailer loaded with all kinds of stuff. Second gen T/As weigh nearly 4000# and a 2003 GP I would guess weighs 32-3500#. I had to fab a sturdier 2 inch trailer hitch for it as the sheet metal factory one wasn't up to the job...……………… |
