#41
![]() Quote:
The formula you have in post #15 is the formula I used. I just want to make things clear that I'm the one who insisted on this cam. My engine builder wanted to go one cam up. The cam he wanted would have added 6 degrees on the intake and exhaust. 248/254. Most likely it would of made the number if that cam was used. Also, This engine only had 10 pulls. The valves and rings are not seated and once it gets 500 miles it will get more power. The jets in the carb were not changed during the dyno session. I realize some dyno sessions get 30 to 40 pulls. Comparing dyno results from 10 pulls to 30 or 40 pulls is not on the same ball park. More to come. Jim |
#42
Sorry - hijack alert
Last edited by TheGrudge; 10-20-2019 at 05:10 PM. Reason: Total hijack, pm sent to Pastry Chef |
#43
I have to correct something I mentioned before. The numbers are corrected. The best numbers from the dyno session were at 35 degrees. HP 519 @ 5200 rpm and Torque 578 @ 4200. The following attachment is the dyno sheet I could get hold of, but it is at 36 degrees of timmimg. It will be suitable for discussion purposes.
The intended use of the engine is for street only. It will not be raced. Cliff is right on with his comments. I may have the cam changed at some point if I feel it is necessary. It would have been nice if I listened to my engine builder in the first place, but this is the only time I haven't. I will live with my decision for awhile. We will see what happens when it is in the car. |
#44
From JE pistons, How to Break-In Your Piston Rings......
With today’s rings, especially moly-faced versions, this can be achieved in a very short period of time and certainly within 20 to 30 miles of street driving. In WOT dyno testing, likely the rings are seated by the end of the first few runs. .
#45
“The intended use of the engine is for street only. It will not be raced.”
I would be thrilled to death with that engine. I bet half the folks on this forum ‘wish’ they would have went with a different cam in their build with the benefit of 20/20 hindsight (... as I raise my own hand ...) But for fun on the street in the weekender / cruise night / better-than-paying-a-therapist car, it would be hard to beat your 496. |
#46
![]() Quote:
This engine fits in between my '70 t/a 433 CID with 447 HP and 535 TQ thru RA IV Manifolds and my '70 GTO with a 461 stroker with 600 HP anf 625 TQ. Both engines built by the builder of this engine. The engine is going into a '73 brewster green TA. Getting converted to a six speed tremec t-56 and 3.73's out back. Original numbers matching 455 and turbo 400 are going ito storage. Last edited by napster; 10-20-2019 at 05:48 PM. |
#47
What is the vacuum at idle? What was your Hp goal? It does seem that the motor should make more than 519 Hp with that size ci/cam.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
#48
Thanks to everyone who responded. Specific advice will be used in the future.
Jim |
#49
Update to the previous porting done to the Super Duty heads #16. It seems the porting done before I bought the heads was worst than I thought. According to my engine builder too much material was removed from the bowl area. Since he can’t add material, I have to live with it. The missing material is adversely affecting air flow.
I’m not as knowledgeable like many of you guys, but would a bigger cam really get me more power with this extra information? As a side note, I was watching an episode of Engine Power. Pat Topolinski indicated a rule of thumb for horsepower is you should make 2 HP per CFM of airflow. The heads were bench flowed and got 260 CFM. Easy math means 520 HP. The engine did 519.4. I’m just saying………. |
#50
It's a "rule of thumb" type deal, but yes. Addressed in post 13...
'65 Tempest 467 3650# 11.30@120.31 |
#51
![]() Quote:
I don't know what you got for pistons but if your disappointed with the results maybe you could upgrade the top end @ some point with some E-heads and a 248/254 cam as mentioned. Awhile back I did a 462 build with 64 heads as I recall flowed around 240 to 250 cfm and made about 546 hp. Many years later still prowling the streets. https://forums.maxperformanceinc.com...d.php?t=633706
Carburetor building & modification services Servicing the Pontiac community over 25 years Last edited by shaker455; 01-05-2020 at 03:30 PM. |
#52
![]() Quote:
Like I said in my original post, picking up 30cfm to 35cfm is a large gain. Carry on. Calvin Hill Hill Performance 708-250-7420 |
#53
![]() Quote:
#54
![]() Quote:
Since you brought up SD doing heads for me, you are saying here in an open forum this is true? Did Dave tell you that? You know nothing about Mondello’s. You are also bad for the Pontiac community always spouting off opinions and misinformation without first hand knowledge of any of it. How many sets of heads have you ported? One last thing, when your parts and engine build were being held hostage in WI and you’ve were looking for help, that’s right I offered assistance, GFY. You are nothing but a tool bag. Calvin Hill Hill Performance 708-250-7420 p.s. how’s that bad ass build coming along? |
#55
At any point does DargonDouche get a vacation for spreading fertilizer all over this Website?
This is almost the same made up story just change the "accused" name. It's a detriment to this Website. Last edited by PAUL K; 01-05-2020 at 07:17 PM. |
The Following 2 Users Say Thank You to PAUL K For This Useful Post: | ||
#56
Enough with this GARBAGE! Take your arguments to the clubhouse where they belong. Stop screwing up my thread!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
#57
![]() Quote:
I see he's here spewing his bull****... |
#58
I have a lot of insight to that deal, what the hell do you know? Better yet, what is your skewed 3rd hand version of it?
#59
He knows low rpm tractor engines... I agree there
#60
![]() Quote:
Do you know where they got that "big cfm" port you love so much? Did they developed it or Xerox it from another one of your heroes? I know the answer to that question...do you? |
