Old 12-12-2019, 10:00 PM
Dennis,
Nice score on the Formula 400. Here's a picture of the spare tire and rim from my old 1970 Formula 400, and I'm pretty sure it was the original to the car. I think the Goodyear Polyglas tires were for the 15 inch wheels and the Firestones were for the 14 inch wheels.
Thanks 77Canamman! I was wondering if they were replacement tires since it seems all '70 Formulas & TA's were shod with Goodyear Polyglas GT's. I've never seen any '70 Birds with anything but Goodyears in 70 and 60 series tires..78 series, yes. But, never say never.
Dennis
  #42
Old 12-12-2019, 10:17 PM
Dennis
Dennis,
It's actually been my observation that in '70, Pontiac seemed to have sourced the 15" white lettered tires from Goodyear (i.e. all TAs had the Polyglas GTs), but at least some (I'm inclined to say all based on what I've seen over the years... but never say never) of the 14" RWL tires from Firestone. My '70 Formula had one original tire still with it when I bought it (14" Rally Wheel car), and it was a Firestone Wide Oval.
BTW, congrats to you guys - that is a very cool car!
  #43
Old 12-13-2019, 07:39 AM
SD455DJ SD455DJ is offline
Thanks Craig! Dan actually owns the car with me, but we are now esteemed members of the Lucy Blue club.
Eaglesan13 & Keith K, thanks for the clarification on the Firestone vs. Goodyear tires. I now recall seeing the '70 TA in Rocky's book on display with F70 - 14's when PMD considered making that the standard tire on the TA.
Canamman77, thanks for the date deciphering for the 721 radials. Funny that they were installed and never driven on. They still have the nubs sticking out of the tread.
Dennis
  #44
Old 12-13-2019, 08:31 AM
Here is the original 50 year old nylon/aluminum gear and chain that is wearing quite well considering.
Dennis
Name:	Nylon Timing Gear 1.jpg
ID:	526636   Click image for larger version
Name:	Nylon Timing Gear 2.jpg
ID:	526637   Click image for larger version
Name:	Nylon Timing Gear 3.jpg
  #45
Old 12-13-2019, 08:33 AM
Default Firestone BW F70-14 Spare on CL Wheel
Maybe it is one of the original tires to the car...?
Dennis
Name:	Sare Tire 1.jpg
ID:	526639   Click image for larger version
Name:	Spare Tire 2.jpg
ID:	526640   Click image for larger version
Name:	Spare Tire 3.jpg
ID:	526641   Click image for larger version
Name:	Spare Tire 4.jpg
ID:	526642   Click image for larger version
Name:	Spare Tire 5.jpg
  #46
Old 12-13-2019, 10:57 AM
Norwood's Avatar
Norwood Norwood is offline
Dennis are you putting it back together with the nylon gear ?
  #47
Old 12-13-2019, 11:06 AM
Craig, Nope, it has a bunch of hairline cracks in the nylon teeth and looks like it wasn't long for this world, so we caught it in time. The new gears and chain were installed yesterday by Dan. The old one in now garage wall art!
Dennis
Name:	New Timing Gears & Chain.jpg
  #48
Old 12-13-2019, 02:47 PM
Rocky Rotella's Avatar
Rocky Rotella Rocky Rotella is offline
Dennis, just wondering. What timing set are you using?
  #49
Old 12-13-2019, 07:17 PM
Rocky, From Carquest it is a Cloyes std. duty timing chain and gears, installed straight up.
Dennis
  #50
Old 12-13-2019, 07:19 PM
Cloyes C-3007K...that is. Picture didn't post...darn phone.
Dennis
  #51
Old 12-13-2019, 07:22 PM
The pictures of your tire look the same as mine, so your tire might actually be an original tire.
Dennis
ID:	526702   Click image for larger version
ID:	526703   Click image for larger version
ID:	526704   Click image for larger version
  #52
Old 12-13-2019, 07:25 PM
Thanks!
  #53
Old 12-14-2019, 09:42 PM
Rocky, Here is the picture of the box with the Cloyes part number.
Dan has the engine all back together along with the rebuilt 7040270 Q-jet and stock distributor with its original factory advance weights and springs. The carb had 69 primary jets with 37 primary metering rods and DL secondary metering rods on an F hanger...all which appear to be original. Dan is going to check the electrical tomorrow before refiring the motor. After is has been run and thoroughly checked, Dan is going to check the actual compression with the Whistler (once it has cooled to about 170 degrees).
The original RA air cleaner base may have slight 'bumps' for the Holley carb fuel bowls??? They aren't as pronounced as the '70 GTO RA bases and are hard to discern...Jonny?
We will report back then to share what its actual static compression ratio is.
Dennis
ID:	526757   Click image for larger version
Name:	YZ 400 Ready.jpg
ID:	526758   Click image for larger version
  #54
Old 12-14-2019, 10:40 PM
FASTASSBIRD FASTASSBIRD is offline
Let’s see that starter......
  #55
Old 12-14-2019, 11:16 PM
fbody_mike's Avatar
fbody_mike fbody_mike is offline
so very cool, keep the pictures coming!
I built it one piece at a time and it cost me more than a dime.
  #56
Old 12-15-2019, 12:43 AM
70FormulaCA's Avatar
70FormulaCA 70FormulaCA is offline
Very cool indeed. Congrats guys!
70 Formula 400 Auto non-A/C
Wanted: 71 or 72 Formula HO 4spd - leads very much appreciated.
  #57
Old 12-15-2019, 12:49 AM
Shiny Shiny is offline
Dennis
Messy thread in the Street section trying to determine if Morse still sells these silent chains.
Not to divert, but would you mind posting photos of any markings on this original chain? Is "Morse" stamped anywhere?
Same question regarding the crank sprocket. Is it obvious what it was made from (cast iron or steel)? Any way to tell if it was hardened?
Your car is awesome and a wealth of info. Thanks for sharing and congrats on finding it.
Tnx
  #58
Old 12-15-2019, 11:21 AM
unruhjonny's Avatar
Dennis, I have pictures that I can dig up;
does that base have mounting studs for the engine mounted alignment tabs?
1970 Formula 400
  #59
Old 12-15-2019, 11:48 AM
Originally Posted by 77 Canamman View Post
19th week of the 4th year of the decade. So realistically, it could be 1974, or 1984. The coding changed after 2000, and there was a triangle after the last three numbers during the decade of the 1990's.
Good info
  #60
Old 12-15-2019, 11:51 AM
Dennis,
Graduations Dan and Dennis great car ,I have a 1972 Trans Am with a firestone wide oval 72 dated tire in the trunk F-60-15 . I wonder if they were offered on the Trans Am in 72 for the first year or they started in 73?
