Old 01-11-2020, 01:34 PM
Visual proof that the 3/8 belt is too small for the PS groove. This is a 68 'short' pulley. The Chevy pulley uses the smaller groove in both positions.
Old 01-13-2020, 03:59 PM
Got another water pump pulley in the mail today. 481040XT... Also too short but only by 1/4". That's three wp pulleys I have now that are too shallow for the application. Well, actually two..the Chevy pulley is the correct depth but narrow groove size and diameter is slightly smaller. Getting a little frustrating. I'm almost ready to run the Chevy pulley with the narrow belt.
Old 01-13-2020, 04:04 PM
antique69lemans antique69lemans is offline
What is the casting number on water pump ?
  #44
Old 01-13-2020, 04:32 PM
dataway's Avatar
dataway dataway is offline
I could make you a spacer if you really get stuck.
Just an aluminum disk whatever thickness you need with four holes for the bolts.
  #45
Old 01-13-2020, 04:46 PM
Old Goat 67's Avatar
That sounds like a good solution to me.
  #46
Old 01-14-2020, 12:27 AM
No casting number but it's 4.5" from the mounting surface to the fan hub.
Thanks dataway but I don't think a spacer would work. I'm needing the pulley grooves to come back, not forward.
I just bought another one. The guy sent me a pic next to a ruler so hopefully it's correct this time.
Funny thing is that the one I just bought and the one I got in the mail today are the same stamping numbers but the one I just purchased has a 'D' at the end of the number. Maybe that's where the extra .25" comes in?
I guess I'm going into the second hand pulley business for a while. I'll post them in the classifieds. VERY frustrating...and getting expensive.
Old 01-14-2020, 06:48 AM
dataway's Avatar
You sound like me ... I'm a belt stickler ... have to run true, no climbing in the pulleys, no vibration
  #48
Old 01-14-2020, 07:29 AM
Hope the pulley you have coming is a "128" or "130". Those are the only original pulleys that will line up right with '68-70 AC diam crank pulleys & a tall 11 bolt waterpump.
  #49
Old 01-14-2020, 08:00 AM
Searching the web, came up with this-
http://grandprixchapter.com/technica...-acc-brackets/
69-70 P/S & A/C – 9799130 (long snout pump) (2 groove for alt. and P/S.) 7 3/16″ diameter
If the above is accurate, it's the pulley that I need.
I think the long snout wp may have been a mid-year '69 deal and so the ones on the page listed by OG68, I think are still for the short pump.
Never was a mid '69 model factory installed deal. The tall 11 bolt waterpump, the "124" was first introduced with the production rollout of the '70 models in mid August of '69. The oddity that took place is '69 Firebirds continued to be built up into Nov '69 & their engines from what I've noted over the years were built with the 351" casting (short) 11 bolt wp.
As a service parts procedure, Pontiac advised dealerships in replacement of original '69 waterpumps to install the tall '70 (or later) casting wp along with swapping to the '70 design wp pulley. This is easily noted in Master Parts Books. This service procedure worked fine on '69 A, B, & GP series cars, but not on '69 F-body's with 4core radiators.
  #50
Old 01-15-2020, 01:58 AM
OPH, any ideas on why the 481040XT that I just bought is 2.5" tall and the 481040XT-D is apparently, judging from a photo sent by the seller, 2.75" tall? The 'D' is the only difference I can see. Maybe F as opposed to A body applications?
The different accesory bracket and pulley combinations that apply to Pontiacs is enough to make your head spin!
Old 01-18-2020, 02:10 PM
Ok, I give up. I'm putting the Chevy pulley back on with the narrow belt. I can see why someone did the swap in the first place now.
The pulley l just got here is closer on the overall height but there is a half inch difference between the face of the pulley and where the first groove is placed...
As a famous GTO tag says... GR-RRR!
Sent from my moto g(6) play using Tapatalk
Old 01-18-2020, 03:24 PM
242177P's Avatar
242177P 242177P is offline
Lightbulb
Ok, I give up.
If you're going to stick with the narrow, might I suggest a 66 crank pulley?
The crank and water pump were in a perpetual state of war, using the PS
pump simply pushed things over the edge. Eliminate the primary conflict.
  #53
Old 01-18-2020, 04:42 PM
After cooling down a bit, I should say that I'm not giving up on it but I am approaching the problem the wrong way.
I need to figure it out and stop buying parts to throw at it.
First thing is to figure out what I have for accessory brackets, ps pump etc. Then figure out what it is that I need to make it work.
Old 01-18-2020, 08:50 PM
I'll look into the 66 piece as I'm pretty sure I have one here. The Chevy pulley actually lines with the crank and ps pump fine, it just doesn't seat the half inch belt well.
Was there a 4" water pump length in 11 bolt as well as the 4.5"? If there was, it would solve my issue. I know I read that somewhere but that means little on the www.
Old 01-18-2020, 09:36 PM
9796351 is 4"
The Following User Says Thank You to antique69lemans For This Useful Post:
  #56
Old 01-22-2020, 01:23 AM
I missed this somehow when you posted. You MUST be right because I finally came up with the same number and I can't find one anywhere...that proves that it's the one that will work because just about everyone has done the 11 bolt wp swap at some point.
Anyone hoarding a 9799128?
Old 01-22-2020, 07:34 AM
alex s's Avatar
alex s alex s is offline
I have a 128 pulley available
Please contact direct at nescgto@gmail.com or 617-966-1608
Also have a 901 ps pulley if needed
The Following User Says Thank You to alex s For This Useful Post:
  #58
Old 01-23-2020, 02:52 AM
I've sent you an email alex.
Old 01-24-2020, 08:38 PM
Have you converted to manual steering yet ?
  #60
Old 01-24-2020, 08:40 PM
Wasn't planning on it.
