OHC-6 TECH Over Head Cam projects, questions and advice.
Old 04-13-2024, 08:14 AM
Cammer-6 Cammer-6 is offline
Gary, great to see another 67 AIR air cleaner survived! You don't still happen to have the FH stamp you had made do you? I was thinking of having one made with 1" tall 1/2" wide letters but if you still have yours I could borrow or buy it off of you.
Im sure I do
will PM you when its found
Another thing that comes to mind was a bright pink "spot"
IIRC I duplicated with spray paint as it looked rather line assembly applied.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
  #42
Old 04-13-2024, 10:09 AM
how good is your label on air cleaner?
might be time to repop it.
  #43
Old 04-14-2024, 01:01 PM
Thanks Gary, I will dig out my aircleaner and check the label's condition
  #44
Old 04-14-2024, 07:47 PM
mine has 2 labels one on top of the other.
either the wrong one was put on first or it was upside down
  #45
Old 04-17-2024, 06:06 PM
Here is my Placard Gary not perfect by any means. Plus I added picutes of my battery tray that just came back from the powder coaters in the other tread
  #46
Old 04-18-2024, 07:25 AM
that should be good enough to replicate.
Mines in about same shape but is double layered
Many,many years ago I got into a discussion with Jim Osborn on the color of the metallic print.
I say its gold,Jim said"golds too messy,its silver"
I have an NOS 68-9 and its gold. Im pretty sure the color fades with age.
  #47
Old 04-22-2024, 01:30 PM
(Note the 69 Bird was missing the entire A.I.R. system when I bought it in CA back in the early 1990's.
Did 69 OHC's still have California emmisions? NO 69 V8 Pontiac's had any California specific smog stuff installed.
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
  #48
Old 04-23-2024, 08:30 PM
North you may be correct that the 69's didn't use a smog pump. I remember the exhaust manifold on my 69 had the A.I.R holes drilled in it, but that they where capped off. I just assumed it originally had a pump.
