Old 06-15-2023, 08:59 AM
RedDirtRoad RedDirtRoad is offline
Thanks for the heads up Mark.
I will take a peek when the frame comes back from the blaster.
  #42
Old 06-21-2023, 06:52 PM
Got the frame back yesterday
Luckily no cracks as Mark pointed out in his post.
Started to assemble front suspension and sort out the new brake lines
since they always need a bit massaging to fit perfectly,
Have upper and lower control arms painted and new bushings and ball joints installed
Have the upper ball joints “riveted” . Ok I cheated like everyone else! Actually rivet head with threads.
Just need to sandblast a few more parts on my own and can finish the chassis
ID:	614605   Click image for larger version
ID:	614606   Click image for larger version
ID:	614607   Click image for larger version
ID:	614608   Click image for larger version
  #43
Old 06-21-2023, 07:40 PM
I goofed on mine as I did not put the fuel lines in before the springs.
  #44
Old 06-25-2023, 01:37 PM
SD421's Avatar
SD421 SD421 is offline
Looking good!
Quick question for you. I see the upper control arm attaching bolt is what my 1966 GTO uses. I thought the 1967 upper control arms used a nut to tighten up the bushings??
Maybe you have an early year 1967 GTO??
1966 GTO
1966 421-9.3-1 comp-Race Tec 23cc Pistons
1966 Tri-Power
1967 670 Heads
Pontiac "Highlift" TriPower Cam by SpeedPro
DUR 214 Int 224 Exh @.050 - 107 ICL
LIFT .445" Int .465" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
  #45
Old 06-25-2023, 06:08 PM
You are correct
64 to early 67 used bolt and washer.
Late 67 and up used nut and washer.
All my front suspension parts are Moog that I bought
At Rock Auto last month. When I opened the boxes to install them in the control arms I realized they sent the early style . The problem is the shipping to return the parts to rock auto and get new parts cost more than the parts are worth And I didn’t feel like waiting another week.
Even though I have a late model 67 I’m not too concerned about using the early style.
But yes you have a good eye!
  #46
Old 06-25-2023, 10:06 PM
roger1's Avatar
roger1 roger1 is offline
Following.
Looks like you got yourself a good one!
'69 GTO Convertible - Acquired October 2020. An all original project car. Restomod is underway PROJECT THREAD
'83 Chevy Choo Choo SS El Camino - LT1 350/4L60e, Owned for 30 Years, completed 2nd restomod in 2018 PHOTO
2019 BMW 440ix - Twin turbo I6, 8spd auto. PHOTO
'55 Chevy Bel Air Sport Coupe - Ram Jet 350 / T56 Magnum 6spd, Restomod Completed Sept. 2012, Sold Sept. 2021 PHOTO
  #47
Old 06-27-2023, 02:05 AM
242177P's Avatar
242177P 242177P is offline
Umm, no. Different plants. HTH.
  #48
Old 06-27-2023, 06:30 AM
That’s good to know
I thought it was based on years and not plants
Thanks for the insight. Love this forum.
The Following User Says Thank You to RedDirtRoad For This Useful Post:
  #49
Old 07-30-2023, 05:29 PM
Just got back from vacation and back on the GTO
Needed to order a few more parts and now that I think I have everything I am putting the front suspension together now.
I should have my rear axle back from my rebuilder in a couple of weeks and then I will have a roller chassis
ID:	617047   Click image for larger version
ID:	617048   Click image for larger version
  #50
Old 07-30-2023, 05:30 PM
What’s the trick to rotate photos?
  #51
Old 07-30-2023, 08:08 PM
Your work is looking great.
I'll tell you something that I discovered on my cell phone camera.. When I look at my viewfinder there is a little horizon line. If that line is not upright at the bottom of the screen the photo isn't upright. That horizon symbol can migrate to any of the four sides of the screen depending on how you're holding the camera and especially if you're taking a photo aiming straight down at the subject. Wherever the horizon symbol is will be the bottom of the photo.
Old 07-31-2023, 08:49 AM
Cammer-6 Cammer-6 is offline
I had a 67 that came with one of each style control arm
and I'm 100% certain it hadn't been changed.
Do you have a better pic of the frame with the body biscuits still attached?
See discussion on body mounts in this forum
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
  #53
Old 08-02-2023, 03:07 PM
See discussion on body mounts in this forum[/QUOTE]
The short answer is No
I took about 300 photos during the disassembly process with my digital camera now the camera keeps telling me there is an SD card error and can’t access any of those pics which I wanted to use for future reference since this care was unmolested and in great condition.
  #54
Old 08-02-2023, 03:47 PM
I took about 300 photos during the disassembly process with my digital camera now the camera keeps telling me there is an SD card error and can’t access any of those pics which I wanted to use for future reference since this care was unmolested and in great condition.[/QUOTE]
maybe worthwhile to have someone "recover" those pics.
I had one do that and a buddy(who was on this forum and recently passed)
ran a program that recovered all but a few pics.
  #55
Old 08-02-2023, 09:06 PM
I have a family member who is in IT
Hopefully he can work his magic and recover the data
  #56
Old 08-02-2023, 09:23 PM
Default Special thanks to Frankyboy455
Big Thank you to Frank
He sold me his Rally 1 wheels, caps and trim rings for a reasonable price.
I sandblasted the steel rims and stripped the black paint off the centers and polished the center cap.
I also scored a set of NOS trim rings
Thanks Frank !
They came out great
ID:	617309   Click image for larger version
ID:	617310   Click image for larger version
ID:	617311   Click image for larger version
ID:	617312   Click image for larger version
  #57
Old 08-03-2023, 09:32 AM
NOS trim rings
wow how did you do that?
what are you doing with the used ones?
  #58
Old 08-03-2023, 10:01 AM
While you guys are on the subject of Rally Ones, is there a 'tell' for which ones are original vs repops? ...ie. the rims themselves, not the rings.
Old 08-03-2023, 11:34 AM
NOS trim rings
I got lucky and found a guy on FB marketplace that was fairly local to me selling them
He told me he bought them years ago
Date on the box is 1983!
I have a bunch of mis matched trim rings and
Center caps
Most likely will sell them off along with a room of
Other parts I accumulated over the years
Just don’t have the time to post sell anything yet.
Trying to get this car completed by next summer
  #60
Old 08-03-2023, 05:06 PM
Rebuilt the rear brakes today
Still waiting on the rear so I will have a roller soon
Still can’t get these pics to load in the right position!
ID:	617345   Click image for larger version
