#6341
If everyone had the same tastes the world would be pretty boring, wouldn't it?
#6342
I think anything that old that looks that good is worth having ... that's why I still have my wife
#6343
![]() Quote:
![]() Sent from my iPhone using Tapatalk
NOT a GTO. 1965 LeMans 455 |
#6344
https://southbend.craigslist.org/cto...743223536.html
"Needs complete restoration"...never would have guessed!
if not Henny Youngman, could of been......
72 Bird |
#6346
![]() Quote:
Too bad it's probably more rust that steel at this point down there in Houston
www.fquick.com/Captainofiron 68 Firebird 400, YC 400, Hbeam rods, ported 670 heads (2.11i, 1.77e valves), 1.65 RRs, Torker 2 intake, Nodular Crank, Eaton Limited Slip, Richmond 3.55 gears, M-20 M4 97 Trans Am WS6, LT1, M6, FLP LTs, Cutouts, Flowmaster catback, Jet Airfoil, K&N air filter, MSD Opti and Coil 14 Fiat 500e 83kW motor, 24kWh lithium ion battery, +2 sized summer tires |
#6347
![]() Quote:
“It takes considerable knowledge just to realize the extent of your own ignorance.” Dr. Thomas Sowell |
#6348
![]() Quote:
Greg Reid Palmetto, Georgia |
#6349
The Michigan license plate is the best part in that pile of crap.
#6350
Super duty!! hehe
https://boston.craigslist.org/gbs/ct...738006051.html |
#6351
unlikely, but you never know what someone stuffed into it. I bought a 76 50th ann 455 and it was advertised as an 455-HO I just passed it off as like so many did and referred to them as HO. but come to find out the guy had put a 72 HO top end on it including exhaust manifolds and cam early in its life.
#6352
![]() Quote:
Wonder if 2x4 or 2x6
#6353
Missed that when I 1st read the ad.
If it was close to me I would have to check it out, a friend of mine picked up a 70 Formula that had a 74 SD 455 put into it. He talked the seller down because it was not a Numbers Matching car!!!!! Bought it for much less than the engine was worth. So you never know. But probably has the original 76 455 under the hood, or would that be a 462 now that's its Boared? At least it would give a convenient place to tack up all the engines paperwork!
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
#6354
Saved for posterity.
![]() https://boston.craigslist.org/gbs/ct...738006051.html 76 trans am super duty 455, all types work, Morosso drive oil system cost 1000 Ansen starter shield special safety 3-500, Hurst complex shifter, headers has headers on exhaust Lakewood lift bars and a 390 poi's rear end, boared & balanced all custom Edelbrock speed equipment Intake carb valve covers all Edelbrock speed equipment. Call For more information |
#6355
nope. this guy did the machining:
![]() he also hogged out the ports, too ![]() /your waitress, tip her well |
#6356
Even the 'headers has headers'.
#6357
![]() Quote:
Must be double horsepower then
#6358
#6359
![]() Quote:
![]() Quote:
To do the 2 door would cost much the same to do but what have you got when it's done? I'll tell you what you have - you have just one more 2 door LeMans. In the crudest form, a 2 door LeMans is not much different to a Mustang. And those are like ***holes - everyone seems to have one. Build the 4 door and you will have quite a different car. As time progresses, the rarer , much less seen cars, will start to draw greater attention. JMHO Ian ![]() ![]() ![]()
To laugh at men of sense is the privilege of fools. |
