#661
Try partsamerica.com that is where I got my Cardone rebuilt water pump that had a cast impeller. I got the part number from one of the early pages of this thread
67 GTO Hardtop |
#662
Hey, Bob send me a PM or email with your info. If I get a chance this weekend I'll give you a call regarding the spindles.
George
#663
hi and thanks for getting back to me as quick as you did thanks a lot
#664
hi i would very much like to know the part number for the cardone water pump with the bigger vanes or the store name or phone numberof store and what to order for my 67 gto thanks alot you can email me at 2classiccars@bellsouth.net and thanks a lot for getting back to me so quick
#665
Robert, sent you an email with the cardone water pump information. I see that they now sell ''new'' as well as remaufactured 8 bolt cast impeller pumps.
67 GTO HT 1968 400 Engine YE TH-400 #13 Heads -J069 Q'Jet . 8.2 Eaton Posi/3:55 __________________ |
#666
Ok I read all 34 pages everything seems simple enough.I'm getting a 400 to rebuild will zero decking help it run cooler?
#667
. Had to get it off of the number after 665
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
#668
I cant say enough How great this Idea and FInd really is!!!!!!! Think about how many Engines this will save!!! Thanks Everyone This is a Great Idea!!!!!!!! PMDRACER I SALUTE YOU!!!!!!!!
72 Lemans |
#669
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">I cant say enough How great this Idea and FInd really is!!!!!!! Think about how many Engines this will save!!! Thanks Everyone This is a Great Idea!!!!!!!! PMDRACER I SALUTE YOU!!!!!!!! </div></BLOCKQUOTE>
Credit also has to go to George Kujanski who brought up the part about the separator plate, which I believe is also mentioned in Jim Hand's book.
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same. -RONALD REAGAN 462 cid/ 6x-4/ TH400/ 3.36:1/ 28x10.5/ 3880#/ 12.35 @ 109.36/ 1.69 60 ft/ 4 wheel disc brakes/ 15 mpg |
#670
Add me to the list of guys this made a difference with. Changed my gap from 0.25 down to 0.100(or maybe a little less) and it dropped my temps 15 - 20 degrees. Thanks for bringing this back to the top.
65 Lemans Street Car - 521, T400, 3.70 9". 10.13 @ 135. 3770 lbs. Drag Week ‘14, ‘15, ‘17 63 Lemans Race Car- 8.81 @ 151, 5.60 @ 123(SOLD) 67 Bonneville ragtop 74 Firebird - 455, e heads, TK0600 in process |
#671
Ok, you're added to the list.... where's my dollar?
George
#672
Check's in the mail George.
#673
Not remembering the 4GC too well, I'd say the discrepancy in the jet sizes is a big clue. What do your plugs look like?
Also, post your question in the Street performance forum; perhaps one of our carb experts will respond. George
#674
Thanks George for your response. The plugs are like a whitish-brown color. I will repost on the Street Forum
-Don
1966 GTO 1966 421-9.3-1 comp-Race Tec 23cc Pistons 1966 Tri-Power 1967 670 Heads Pontiac "Highlift" TriPower Cam by SpeedPro DUR 214 Int 224 Exh @.050 - 107 ICL LIFT .445" Int .465" Exh Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers 1966 Muncie Wide Ratio 4-Speed 1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears |
#675
I also wanted to say to everyone to make sure that all your exhaust manifold bolts are there & tight cause I noticed last night that one of them was missing. This will also lead to overheating. Ive ordered the cast impellar unit and will try and gets some pics of the 4 bolt waterpump with the cast versus the stamped unit. That way some of us guys with these pumps can see the difference if any too.
-Don
#676
Welllll, after reading all the posts on this topic, I still have a bit of fog on the brain. I'm finally getting my 66 GTO finished. The engine had been run a couple of times on the stand and in the car. It (surprise) seemed to get fairly hot running in the garage but I didn't really think too much about it as the carbs had not yet been set up beyond the rebuild specs. The timing had been set as well). Then I drove it down the road (less than half a mile) and back, just to see if the brakes braked, the gears geared, and the mufflers muffled. Pulled back in the garage and smelled antifreeze. Popped the hood and the temp guage (installed temporarily under the hood read 210. Unfortunately the smell was coming from a nice little stream of antifreeze gracefully arcing its way up over my pretty engine. Even more unfortunate was the source--a pinhole had sprouted in the top of the timing chain cover. Aww geez, not only a fix, but plenty of paint touch up. I found another cover from Don--our local (tidewater VA) GTO guru. I mentioned the heat and he pointed me to this forum and told me to read everythingposted.
OK, finally to the questions. The adjustment of the clearance between the pump vanes and the inner housing makes perfect sense but I run into a problem with the earlier, 8 bolt pumps. Pictures are below, but text first. Where I'm having trouble is that the divider plate and inner housing just drop into the timing chain cover (thus not being held in place by being sandwiched between the pump housing and timing chain cover as in the later, improved 11-bolt). As can be seen below,the fit is loose and, in this case varies from almost 0" to a little more than .6" which means that even when the inner housing has been "adjusted", the loose fit would seem to introduce the potential of adding that .6", thus still ending up with same low efficiency. Corrosion in both the old timing chain cover and the replacement pictured show that this varibility existed in a consistent manner with at least these two. However, the plates could be altered by bending the lips of the two output "nozzles" and deepening the dimple until the two plates are flush with the timing chain mating surface. Does that make sense? Does anyone have some input on this? Also, with only the three contact points holding the plates in place, I wonder if it would make sense to make the fit slightly high and then to allow the water pump to mash them back slightly for a tight (and unchanging) fit. And (if you noticed all the corrosion and wondered) yes, a new divider plate and inner housing are on the way, which brings me to the other question I didn't see answered. The replacement inner housing has a round intake hole where the one pictured has an additional area cut out on the bottom between the 5 and 7 o'clock position. The various pictures on this thread show both, so the question is whether or not the replacement should be cut out to match. Thanks for the great thread. RickO |
#677
Picture 2
#678
Picture 3. Sorry about the messed up font--had to squish the picture to get file size small enough.
#679
Hi,
I decided to install a WIKA thermometer in the water cross over between the heads. Here is what it looks like. I used the 1/2" NPT port for the thermostatic vacuum valve. Water temp holds at 185*F and spikes to 204*F after shutdown. I don't have the cast impeller, but did check the gap between the impeller and divider plate. Mike
1968 Pontiac GTO 462CID, 4-Speed Manual, 3.55 rear. Aleutian Blue exterior, 219 Teal Blue interior. Chrome bumper, AM & 8-Track and Rally II Wheels |
#680
I left some Guys out before I want to say Thanks to EVERYONE who helped and posted!
This will be the First Issue I address On my Future Macho poncho build up.
72 Lemans |
