#741
Nice, I see you have a mini-split system. Those are great for keep a shop warm and cool. I put two in my garage and love them.
#742
I love my garage little over a year old now, mini split heat/AC is great except when it gets real cold.
#743
(And yet another jeep in the background. )
Adam __________________ 1964 LeGTO 469, M21, 3.42 __________________ Sold: 1968 Pontiac LeMans Convertible See it go HERE |
#744
I installed two 32K BTU units in my 4,000 sf garage this past summer and love them. Its surprising how much air they put out and how efficient they are.
I keep it at 73 degrees and the Mitsubishi units have no problem. The best part is how much moisture it takes out of the air. |
#745
Very nice!
1964 GTO: Tripower / 4 speed 1970 Judge. 2015 Challenger Hellcat 2017 Jeep Trackhawk 2017 GTS Viper 1958 Plymouth Fury. CHRISTINE. |
#746
What a great thread! some amazing, some gritty and some are just downright cool. I'll post pics shortly.
#747
#748
#749
WOWOWOW!
I need more pics of this. I'm curious as to why all the access doors on the left side. I'd love to see more pics zoomed out. Is that a residential residence? And I haven't even started to comment on the contents of the garage! wow EDIT: I just saw the entire album. Nicely done. What state are you in that your building codes allow for that kind of wonderful garage space? In metro NY, there is NO way!
Adam __________________ 1964 LeGTO 469, M21, 3.42 __________________ Sold: 1968 Pontiac LeMans Convertible See it go HERE Last edited by AdamIsAdam; 09-24-2016 at 09:57 AM. |
#750
Impressive! Nice collection!
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
#751
#752
I live in a suburb of Houston- our HOA only allows 4 garage doors and it had to look like it was originally built that way. It started as a 3 car garage on a pie shaped lot which gave us the opportunity to expand.
Originally the doors on the side were to a carport but it has since been enclosed. Now it has sliding barn doors on the side and a large swing out door in the back. The roll up doors were all for air flow because it gets so hot and humid here. Here is a pic of the house and garage together: |
#753
I'm curious, how many of you have an overhead hoist/i-beam hoist in your garage. My garage (30'x40'x12') is in its architectural stages. Just trying to cover, or think of everything. Hopfully breaking ground in another month
#754
Check out garagejournal.com they will have a few threads on it. The ones that slide on rails are pretty expensive for how often I thought I would use it. I went with a fold up engine hoist I can stash in the corner.
#755
Nice job
#756
Eventually - with trolley hoist on it.
#757
My plans called for an overhead crane or forklift. I decided on the forklift, but still installed a trolley and likely a second on the way.
#758
What are you guys doing for music in your shop? Right now I am using a small blue tooth speaker that gives moderate sound but nothing too loud.
I would like to find an old Marshall amp stack cause I think it would look cool and fit my theme, but then again you need to have room for it. The garage is out of room- I have two cars at the shop and room for one at home. I thought about trying to expand or put another lift in but it's too damn hard to move the cars around now and I don't think adding to it will help. |
#759
Although a trolley w/hoist would be cool just more to think about |
#760
Another advantage of a 4-post lift in your garage is that it can be used to get stuff out of the back of your pickup truck. I have laid a plywood deck over the runways and rolled refrigerators from the pick bed to the hoist, once on there, lowered it to the ground and rolled it off the lift. I have also used the 4 post lift as a hoist by laying a wood beam across the runways with a chain hanging down. Works great and avoids placing a load on your rafters.
R68GTO 1969 Camaro COPO 427 "RAT'S NEST" |
