Old 12-13-2009, 09:20 PM
GTOJOE228's Avatar
GTOJOE228 GTOJOE228 is offline
Default Update!
All is well.....no changes whatsoever....running cool all summer!
Joe
1966 GTO Conv't, 4-speed, Tri-Power(sold)
1967 GTO Ram Air, PHS Doc. 4sp, #'s match, 15+ options 1 of 751
(Featured on Cover plus 6 page spread in May 2006 HPP)
1970 GTO Judge, PHS Doc. 4sp, #'s match, Ram Air III
2006 GTO Spice Red. M6,18" wheels, 400 HP LS2
richmondcountypontiac.com
Need High Quality Printing fast and reasonable?
www.farbetterprinting.com
Since 1974
Quotes at: sales@farbetterprinting.com
  #62
Old 01-06-2010, 10:43 PM
GTOJOE228's Avatar
Bump!
Since 1974
  #63
Old 02-23-2010, 11:06 PM
Bnick166's Avatar
Bnick166 Bnick166 is offline
Joe,
After reading over this post, I'm inclined to ask if you feel the same 5.5" and 7.25" pulley set up would work on the later model 11 bolt pump set-up?
  #64
Old 02-24-2010, 09:27 PM
Bnick166's Avatar
Anyone???
  #65
Old 02-24-2010, 10:00 PM
lust4speed's Avatar
Since I have never seen an advantage either way between the 8 bolt and 11 bolt pumps, I would say that pulley ratios will have the same effect with either pump. I've found that my engines prefer the 8" bottom and 6.5" top pulleys, and that gives us an overdriven ratio of 23%. Using a 7.25 bottom pulley and a 5.5" top pulley gives us an overdriven ratio of 32%. This ratio should provide even better cooling at low engine speeds. Only thing you have to watch out for is the actual water pump speed. If I shift at 6,000 RPM with my 8/6.5 setup my water pump will be turning about 7,400 RPM; but with the 7.25/5.5 setup the speed will be 8,000 RPM. The clutch fan should be free wheeling after 4,600 RPM shaft speed so except for extra stress on the clutch bearings, it shouldn't make that much of a difference to the fan. If you never hold your shifts, then the extra ratio doesn't even need to be considered. All that for - yea, the pulleys should work great.
Mick Batson
  #66
Old 02-24-2010, 10:55 PM
67blackcherry's Avatar
67blackcherry 67blackcherry is offline
Location: The conservative enclave in a land of liberals; South Orange County, CA
So where exactly could one find a 7.25" bottom pulley and a 5.5" top pulley for an 11bolt water pump?
The Firebird, GTO & LeMans are gone...the garage is now occupied by 2005 Porsche 997 C2S and more guitars in the house...
  #67
Old 02-24-2010, 11:13 PM
68gtoMN's Avatar
68gtoMN 68gtoMN is offline
Originally Posted by GTOJOE228 View Post
At the moment we have located at least 15......
I know where one is that is not yet on your list.
'68 GTO 4-spd Hardtop (11)
'68 GTO Convertible AT (1)
'70 LeMans Sport
Land of Lakes Muscle Car Classic
Facebook Event
Facebook Wall (Kurt Smith,Minneapolis)
  #68
Old 08-01-2011, 08:28 PM
GTOJOE228's Avatar
Default Still Running Cool
As of today the pulley has done wonders! No issues at all. Just a complete pleasure!
Thanks to Nunzi.
Since 1974
