#61
LOL, that's why I'm trying to gather up this S-10 stuff, also...I worked on a 97 Riviera, here, in last month, it had the ratcheting caliper cluster..........had to replace both, couldn't get the old ones to cooperate.....you'd of thought ford invented them...
#62
To remove them easily.... The front of driver side cable is attached to that sheet metal bracket that joins the two cables together (so that they are both pulled evenly to apply the E-brakes). You'll have to squeeze the fingers w/ pliers to get the front of the housing out of the bracket, then disconnect the drivers side inner cable (disconnecting the inner cable isn't hard, I forgot exactly how, though...) The pass side cable comes off by removing all the brackets and guides surrounding or holding that specific cable. There is a small bracket the attaches to the diff. housing. Then just pull the whole pass side cable out.... Go as far forward as possible ( to get ahead of the piece that joins the furthest part of the inner cable, and cut in front of it (so that you can take that adjoining piece with you). A good set of dykes will cut the cable, but only a couple of strands at a tme.
#63
Yes just the guts, the cable itself, not the housing.
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
#64
What booster/master cylinder options do I have that will work on an A body?
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
#65
179-2115 from A/C Delco. S10 rear disc parking brake rebuild kit. $54 delivered from Amazon.
#66
I ordered a few parts from Summit yesterday. Bendix rotors. Braided lines and random fittings for brake line attachment. Longer wheel studs. Backing plates.
I need to drop by Advance Auto and see about calipers, pads, fluid and a few misc parts. Advance offers loaded calipers with attachment brackets included, I may go that route. One of my junkyard brackets has a VERY nice gold finish. Shiney. The other is a rust bucket. I'll also need a proportioning valve and some sort of booster/master cylinder. Outlay to this point? $54 for the parking brake rebuild kit. $38.01 for my junkyard stuff. Calipers, caliper brackets and axle brackets. $159.81 for Summit parts
#67
I was going to add to your thread and suggest the parking brake rebuild kit for those going to the salvage yard, but you beat me to it. The shoes and other parts can wear and the price is quite reasonable. I got mine at Amazon as well for the same amount. Here is a pic of my assembled and painted backing plate unit:
I got the Wagner semi loaded calipers at Rock Auto. One of the brackets had the nice gold finish and the other was silver! Two bad I ordered a matching pair (left and right); but needed two lefts because of the staggered shocks (had to reorder). I painted the calipers and brackets with POR15 caliper paint. Here is a pic (left and right): I got the flexible brake hose brackets and retainers at Summit: http://www.summitracing.com/parts/rus-683942 http://www.summitracing.com/parts/rsd-fhc01 I ordered two S10 parking brake cables; a long one and short one. I am going see if I can cross the long one over either on the axle or in front of the tank. That way, I get the cables off the exhaust.
1979 TATA Extreme TKO .64 Hedman elite; Pypes 2.5; Borla XS; MSD 6A; Edelbrock intake; open scoop; Sniper Q-jet; Powermaster 150; 4 core radiator/Mark VIII fan; RobbMc mini starter; subframe connectors; solid body mounts; fiberglass rear springs; poly sway bar and link bushings; 81 master; D52’s; Blazer disks; 225/60 & 235/60 17's TrueContact's; relays for PW, PDL, lights; keyless entry |
#68
Looking good Bob.
I'm not sure how I'm going to approach the parking brake cables. I suspect I'm going to get the hyd brakes working and then make a run back up to the Pull-A-Part and get some. Months off.........
#69
Just ordered these for a look.
http://www.ebay.com/itm/DISC-BRAKE-S...dc31c8&vxp=mtr
#70
So, I called Advance to get some calipers/brackets coming. I get Matt on the phone. I give him my part numbers SLC628 and 629 and he punches them in. There is one at a store about 60 miles away and the other is all the way across town. The warehouse has none.
I could order some from Summit but I have to go through the whole core shipping thing. Sigh.........
#71
There is a Car Quest about a block up the street from my office. I generally don't call them because they run a little pricier than the Advance close to my house. I called CQ this morning and they actually had what I needed in stock and the pads.
Outlay to this point? $54 for the parking brake rebuild kit. $38.01 for my junkyard stuff. Calipers, caliper brackets and axle brackets. $159.81 for Summit parts $174.98 for rebuilt calipers with brackets and a set of ceramic pads @ Car Quest $35.99 for eBay shims. I'll need to buy a few bottles of brake fluid and also make a return run to Pull-A-Part for a parking brake cable. I will need ends put on the cable after I figure out a length. After I get the brake end of the deal working then a decision on a booster master cylinder will need to be made. Even on "the cheap", this ain't cheap.
#72
The "kit".
#73
Painted the axle brackets with some semi gloss Rust-oleum 2x Ultra Cover. Being the slave to accuracy that I am. I had it...... This is them hanging in the drying booth.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. Last edited by David Jones; 05-27-2014 at 08:20 PM. |
#74
David,
Who makes the shims, you bought??? Thanks Jeff
#75
Painted and looking good! You have most of the parts; it looks like you decided to go ahead sooner rather than later. Your parts cost is still less than mine. I think when this is installed, you are going to say it was well worth it.
I start next week. In addition to the brake upgrade, I am doing diff cleanup, painting and maintenance. I am now looking for a local company to weld the axle tubes. Here is what I purchased today: http://www.taperformance.com/proddetail.asp?prod=TA%5F1807A
#76
S10 Warehouse Jeff. They run them on eBay constantly.
If I'm honest here, I'm not really sure how this shim thing works. Never having removed bolt in axles....or replaced drum brake backing plates with disc brackets, I'm not sure how this all works. I need to see how a space needing shimming is created by adding a thicker piece. Soon will see though..........
#77
Probably start in about 3 weeks...............
#78
The caliper moves as the pads wear, keeping the rotor centered over the rotor. IF, IF the caliper (installed w/o shims) isn't centered after some wear it could grind up either the inner or outer disc pad, if the rotor can't center it self. Not what you are going for... You have to take in consideration the pad wear to make sure the caliper is still centered after the pads are wore all the way down... It will be a little trial and error installing the axle, and caliper bracket, and caliper/rotor to make sure you have the spacing correct...nothing big, especially if you have the rear assy. out of the car.. I just got my buddies copy of Popular Hot Rodding. They wre installing a Baer rear disc setup on their 74 Chevy Laguna. The kit was like $1275.00 similar to what you are doing (and I hope to do also).
#79
Thank you Jeff. I think I understand but until I actually put my hands on it there will be a question.
I did mock up the backing plate, parking brake mechanism, axle bracket and caliper and it's bracket. The parking brake rebuild kit came with the wrong screws. I believe I can clean the junkyard screws up. I also need to clean up the caliper bracket to axle bracket bolts. I'll need to buy new axle bracket to axle flange bolts once I come up with a length.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. Last edited by David Jones; 05-28-2014 at 07:48 PM. |
#80
Looks like a pretty involved project there David!
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
