Old 01-12-2006, 03:29 AM
Brad B. Hillebrand's Avatar
Brad B. Hillebrand Brad B. Hillebrand is offline
One more....approx 535hp 585 tq.....
ID:	38610   Click image for larger version
  #62
Old 01-12-2006, 03:34 AM
Couple interior shots, engine shot with HO cleaner for shows
ID:	38612   Click image for larger version
ID:	38613   Click image for larger version
ID:	38614   Click image for larger version
  #63
Old 01-12-2006, 11:44 AM
Rugratman's Avatar
Rugratman Rugratman is offline
Brad's back, wuz up man? Car looks good, but I am partial to Torch Red.
KRE pulled that kind of power out of stock heads and intake? Wow.
Gotta put a fan gaurd on there, my man.
That Aussie car, and the gold 67 is very sweet too.
So a 8 track and a vac gauge will fit together........My car originally came with a 8 track, I have been looking for one, but few and far between.
........I'm just learning as I go.......
  #64
Old 01-12-2006, 01:51 PM
Bryan Jensen's Avatar
Bryan Jensen Bryan Jensen is offline
On Vacation
Send a message via AIM to Bryan Jensen
Silly rugrat, he's got a performer RPM manifold hidden with Pontiac Blue under there
  #65
Old 01-12-2006, 02:18 PM
6t7gto's Avatar
6t7gto 6t7gto is offline
Here's mine...
david
  #66
Old 01-12-2006, 04:17 PM
meanolgoat meanolgoat is offline
Showbizkid,
Nice Spinners, thats something you see very little of. Mostly on the Fullsize cars.
  #67
Old 01-12-2006, 04:22 PM
Smile
Don't forget the 1 inch valve cover spacers to run the rollers plus 1 inch spacer, now pontiac blue as well. heheheheheheh...
Been working on my new toy and leaving the car along for a while....I am working on a Polaris 800 STORM tripple snowmobile that's supposed to have 165hp. As usual, I have to tear everything apart to somehow make it better than before (not sure if it actually gets better or not but it's fun anyway) So, I've been on that for a few months, too bad we have no snow:-) I'm sure once I do get it on the snow I'll wind up in the hospital somewhere.
BTW: your KRE has more power than mine......
Brad
  #68
Old 01-12-2006, 04:25 PM
67GTONUT's Avatar
67GTONUT 67GTONUT is offline
Originally Posted by 6t7gto
Here's mine...
david
6t7gto.........
what are the specs on the wheels on the red one?.........
Looks like a nice setup........
size? tire size? rim offset?
Troy
Rockaway NJ
67 GTO
400HO / TKX 3.27 1ST GEAR-.72OD / 3.36 POSI
HOTCHKIS/UMI/BILSTEIN
  #69
Old 01-12-2006, 08:09 PM
67gtoTony's Avatar
67gtoTony 67gtoTony is offline
Default You guys have some great cars, here's mine
Just when you think you are done, it drags you back in.
ID:	38679   Click image for larger version
  #70
Old 01-12-2006, 08:13 PM
67gtoTony's Avatar
Thumbs up overhauled 67
They did a 67 on Overhaulin this week.
  #71
Old 01-12-2006, 08:34 PM
hog1340 hog1340 is offline
Hi all
Got some Great lookin' '67's out there! Well here is mine, she needs some work but I love her as she is...
Motor just got redone and should be fired up this Monday.
ID:	38684   Click image for larger version
  #72
Old 01-12-2006, 10:21 PM
Brian D'Amico's Avatar
Brian D'Amico Brian D'Amico is offline
Nice pics guys.. Brad.. Can you share you engine combo?? I'd love to see what you got in that thing!! NICE!
Brian D'Amico
  #73
Old 01-13-2006, 12:43 PM
Sure, what do you want to know? All specifics?
Brad
  #74
Old 01-13-2006, 01:34 PM
On Vacation
You know, the 67 GTO Overhaulin' I think is actually really awesome!!!
Didn't get a chance to see the show where they did it, but I like the pro-touring look they did on this one, it definately looks different...but it's not too flashy or obnoxious. Very well done!
  #75
Old 01-13-2006, 01:45 PM
aj66gto's Avatar
aj66gto aj66gto is offline
Brad...That car look's GREAT..The interior is even better...Where do you get that done...Is that parchment???
Anthony
I do it right cause' I do it twice.
  #76
Old 01-13-2006, 10:12 PM
Hitman's Avatar
Hitman Hitman is offline
6T7, I like how the exhaust exits on the blue one, was that easy to do?
Tony, what wheel and tire size is that you have, and what backspacing are they. I have been looking at several 67's and your sits and looks just like I want mine to.
Hog1340 Everyone told me I was crazy and why would I put a red pin stripe on my car and I tried to tell them and seeing yours makes me now know I am not crazy, that color and that stripe just draws attention.
Should you ever find yourself the victim of others peoples bitterness, smallness or insecurities, just remember, things could be worse. You could be them.
Check out my sons blog, www.driftundertheradar.com
  #77
Old 01-13-2006, 11:43 PM
Brad.. just some of the specifics. I assume it's a 455. What kinda heads are you running, cam? CR? I'd love to hit the 500hp mark one day. Please enlighten us!!
Brian D'Amico
  #78
Old 01-14-2006, 08:47 AM
6t7gto's Avatar
Hitman,
both my cars have the same exhaust exiting location.
it was on the cars when i bought them.
david
  #79
Old 01-14-2006, 06:45 PM
It's a KRE 400 stroker to 462.
Eagle H beam rods
Steel Crank
Ross Pistons
Comp hyd roller - 112 lobe/540 lift/242/252 duration
Comp roller lifters/rockers
670 race ported heads...2.11/1.77 & "The Works" as KRE puts it
RPM intake port matched
AED 950 HO carb
Carter mech. race pump
4 hole sprial bore 1 inch spacer
MSD Pro Billit dist.
MSD 6AL
Taylor spriocore 8mm wires
Blaster II coil
NGK race plugs
FlowCooler water pump
9.8 compression to run on pump gas
I guessed at approx 30 more HP and TQ than my dyno run based on the tuning I did all last summer, new race carb, Ram Air and other cooling stuff....
Brad
  #80
Old 01-14-2006, 11:59 PM
Grr8one's Avatar
Grr8one Grr8one is offline
Cool
Here is my Grr8one.
