Old 05-01-2006, 04:30 PM
Pontiac Performance Author
Brewster: Can you put me in touch with the guy who got my Brewster green 73 , after it went to brooklyn. I have some interesting docs showing bank to bank money info and the original window sticker.
  #62
Old 05-01-2006, 06:17 PM
Brewster's Avatar
Brewster Brewster is offline
Hey Ken,
This car your talking about is it a auto with black custom interior, and a/c ?
Boss: The rods where forged at a GM spec and should be the same either year.
  #63
Old 05-07-2006, 11:54 AM
165th's Avatar
165th 165th is offline
Ken, what's the vin. number on the window sticker? That should make some Brewster Green SD owner very happy!
Greg.
  #64
Old 05-09-2006, 02:07 AM
greyno3's Avatar
greyno3 greyno3 is offline
Why don't you SD guys get a real Bird? Why do retards need their own special corner to talk?
10C 1972 Formula 461 non A/C
08B 1969 GP J/428 non A/C
  #65
Old 05-09-2006, 07:27 AM
Larry Navarro's Avatar
How about a forum for "Whiners without SD's"
  #66
Old 05-09-2006, 08:36 AM
Brewster's Avatar
Yeap, nice reply. I wonder if the "Judge Tech Only" forum got this kind of response when it got set-up ?
Boo-Whooo-Whooo
  #67
Old 05-09-2006, 02:33 PM
Gary H's Avatar
Gary H Gary H is offline
Default Window Sticker
Ken, the Brewster Green car you are referring to is my car. Thanks for posting that you have these items. I really would like to get them from you.
I'll send you a privite message with my address, etc.
My daytime number is 904/665-6233.
thanks again!
Gary
  #68
Old 05-09-2006, 03:57 PM
74 SD455 Formula 74 SD455 Formula is offline
Hey Whiner,
I happen to own a Formula with a SD-455 in it,does that make me a bad person.I also own a 1979 Formula with a 400 4spd.Notice anything here ( NO T.A.'s ).Be happy you have what you do.If your gonna start hating what other's have,than buy a FORD.
  #69
Old 05-11-2006, 01:17 PM
Gary H's Avatar
Anybody have a phone number for Ken Crocie? I rsponded to his message about the widow sticker for my car but I haven't heard from him yet. My number is 904/665-6233.
  #70
Old 05-11-2006, 02:53 PM
Might try this: 909-980-1451
HO Racing
  #71
Old 05-12-2006, 06:33 PM
165th's Avatar
Gary H, you lucky guy you! Ken will eventually respond. I had PM'd him to see if I was the lucky guy, and it took a few days for him to respond. That's great documentation to have.
Now, if anyone has the original window sticker for the 'Car Palace' SD car, originally sold into Lamar CO, please step forward, ha!
Greg.
  #72
Old 05-19-2006, 08:44 AM
Brewster's Avatar
Anybody going to Waukesha ?
Burn Rubber,
Brew
  #73
Old 05-19-2006, 03:47 PM
Default Waukesha Car Show May 21
Brew,
yes I will be there.I will have at least one of my cars out there.Are you planing on coming down for the event??? Let me know,maybe we can hook up.If you've never been there it's big.Over a 1000 cars.
  #74
Old 05-22-2006, 05:09 PM
455HighOutput 455HighOutput is offline
Does anyone have some good pictures of the emissions control system on a '74 SD? I have this one vaccum hose that has what looks like a one-way valve on it that routes behind the carb. Anyone know where it comes from/goes to? This is an AT & AC car. Thanks!
  #75
Old 05-22-2006, 07:00 PM
SD73's Avatar
SD73 SD73 is offline
That sounds like the vacuum delay valve. It should connect to your vacuum advance if that's the case.
  #76
Old 05-22-2006, 08:15 PM
SD73, thanks. Can you tell me what's the termination of the other end, and which way does the restriction of the valve "run"? thanks.....
  #77
Old 05-22-2006, 09:17 PM
SD73's Avatar
The other end of that vacuum line feeds to the powered vacuum solenoid that attaches next to the accelerator cable bracket.
The restriction on that valve should be facing the vacuum advance. Basically, it lets vacuum draw on the vacuum advance and only slowly releases the vacuum. Incidently, as far as I've been able to determine, SD cars did not have these.
  #78
Old 05-22-2006, 09:51 PM
Oh no Mr. Bill! Then I wonder why it's laying around in there? Okay, so does anyone have a correct diagram or can just write out in words how all the vacuum lines on a '74 Sd AT car should run? MUCHO gracias!
As long as I'm wishing, does anyone have one of those seat belt interlock relays that mount on the driver's inner fender (looks like it's mounted onto a pink, plastic pedestal bracket). I need a working relay and the bracket. And probably the front wiring harness, too, since someone snipped the three wires running to it.
I think they're the same for ALL '74 Pontiac models????
Thanks!
  #79
Old 05-22-2006, 11:45 PM
SD73's Avatar
Maybe your's had it??? I haven't seen a part number for one of those fitting a SD in my parts book. Std. V8 definately had those though.
Let's see if any other SD owners have them too.
  #80
Old 06-23-2006, 09:51 PM
SD73's Avatar
You boys notice this animal http://cgi.ebay.com/ebaymotors/Origi...QQcmdZViewItem on ePay? It's not in the registery yet either.
