Old 08-19-2007, 11:45 AM
twov8sandat4's Avatar
twov8sandat4 twov8sandat4 is offline
1974 Trans Am. 4010 lbs with me and 1/2 a tank of gas.
- Original 400 ci. Stock crank, rods, pistons... Was rebuilt in 1988 to stock spec.s.
- Completely stock 4x heads with the exception of some Crane RV cam from 1988. Not ported.
- Edelbrock Performer intake with out of the box Holley 650DP. Original intake and carb were long gone when I got it.
- Hedman 3 tube headers with Flowmaster 2.5" exhaust, H-pipe with original style Flowmaster crossflow muffler.
- K&N air filter in the Shaker scoop. Opened flap.
- Stock GM HEI with Mallory coil, cap, module and Accel wires. Originally came with unitized Ignition, but was long gone when I got it.
- Original TH400 trans with Shift kit. Rebuilt in 1990. Stock converter.
- original 10 bolt rear end with 3.42:1 gears.
- 225/70-15 BFGs on stock Honeycombs.
- Koni Red shocks, stock rear leaf springs with no traction aids. Front stock replacement springs, stock sway bars with poly bushings.
- This is as basic a combination as can be. It has been dead reliable for the past 17 years I've owned it. Drive 75 miles to the track, race, and drive home.
Best E.T. to date: 14.19 @ 97.42, with crappy 2.1 60' times leaving at idle. Car has more in it, but I can't tune a carb to save my life
Panos
Little Miss G Racing
  #62
Old 08-19-2007, 03:23 PM
PMDRACER's Avatar
PMDRACER PMDRACER is offline
1971 Pontiac LeMans Sport, 3880 lbs w/o driver
1971 455 block
Stock crank
Eagle rods
TRW pistons W/Butler lightened pins
Speed-Pro moly rings
BOP rear main seal
6X-4 heads ported to 255 cfm by Pete McCarthy
Stock 1.5 rockers and push rods (for now)
Edelbrock Perf. RPM manifold w/porting to match the tall roof on the the heads and removed water crossover
Brad Urban Stage II Q-Jet
#79 jets / 43K rods
DU secondary rods / H hangar
Cam specs:
Intake/Exhaust
@ .006 285/290
@ .050 235/240
Lobe Lift .338/.331
Gross Lift @ 1.5:1 .507/.496
Lobe Separation 106 Deg
Installed Intake Centerline 102 Deg.
Doug's headers
PY/Pypes 3" exhaust and tailpipes w/x-pipe and Goerlich XLerator 18" mufflers
GM HEI
MSD 6-AL
MSD Timing control
Taylor wires
Autolite plugs
TH400
Continental 10" "Jim Hand Special" converter
Pontiac 10-bolt
3:36 rear gear
Moser axles
Original "machined" cone-style posi
28x10.5 slicks
Sumped stock gas tank
140 GPH pump
-10 from tank to pump and filter
-8 line to regulator, etc
Stock front suspension
Rubber bushings
"El-cheapo" front shocks
1-3/8 swaybar from F-body
Stock rear suspension
Owner-boxed lower control arms, w/tubed holes for swaybar
Poly bushings
Brakes
Factory disc brakes
T/A rear discs in rear
10" dual-diaphragm booster from 78-87 A/G body
Aluminum master cylinder from pre-'91 Caprice
Line lock on front brakes
Brake pressure gauge in car
Best E.T.:
12.35 @ 109.36 mph (1/4 mile, Speedworld, 2600 foot relative)
7.69 @ 89.75 (1/8 mile, Irwindale, 1500 foot relative)
Drove to Pontiac Heaven, won on Saturday, R/U on Sunday, drove home, average 14.5 mpg.
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same.
-RONALD REAGAN
462 cid/ 6x-4/ TH400/ 3.36:1/ 28x10.5/ 3880#/ 12.35 @ 109.36/ 1.69 60 ft/ 4 wheel disc brakes/ 15 mpg
  #63
Old 08-19-2007, 11:46 PM
Billy177's Avatar
Billy177 Billy177 is offline
1970 GTO PS/PB A/C
71' 455 +.030 zero decked
Nodular crank .010 M .020 R
Scat forged H-beam rods with pressed pins
TRW forged pistons
Sealed power 80lb oil pump with a stock baffled pan
Comp XE274H with an Edelbrock timing chain
Stock Edelbrock heads (87cc)
Harland Sharp 1.5 rockers
Performer RPM Gasket matched with a 1 inch open spacer on top
Holley 850DP fed by a Carter 120gph mechanical
Doug's Headers with dual 3 inch exhaust
Hays Flywheel with a 11 Inch ram power grip and Power Master Mini Starter
TKO600 (.64)
Shortened stock drive shaft
Ford 9 inch with 3.60's and a Detroit TruTrack
275/60/15 Radial T/A's on 15x8 Cragers
Engine was assembled by me when I was 18
In the pictures it had the crappy Edelbrock 750 and a performer intake
ID:	102149   Click image for larger version
ID:	102150   Click image for larger version
ID:	102151   Click image for larger version
ID:	102152   Click image for larger version
70 GTO
462 E-Heads TKO-600 9-Inch/3.60's
  #64
Old 08-26-2007, 01:57 PM
WARPed's Avatar
WARPed WARPed is offline
Default 467ci 635hp
467cid Specs, my sig lists the track times and on the dyno we made 635hp@6400 and 575ft/lbs@4900. This dyno has proven to be conservative by about 50hp when track times & race weight are calculated. I drove this all over the place on the street and made well over 350 passes at the track before I pulled the motor to check everything over.
  • Block: 1968 Pontiac 428 + .060 over, zero deck height, 4 bolt mains with stud kit
  • Rods: Eagle 6.80”
  • Piston/Rings: ROSS flat tops, 134gm pins, Total Seal Gapless
  • Balancer: TCI Rattler
  • Flex Plate: TCI
  • Bore/Stroke: 4.181/4.25 (455 crank)
  • Heads: Edelbrock 320/250cfm 70cc, cr 12.09, 2.11/1.77 valves, head stud kit
  • Pushrods: 9.350” .080” wall 5/16” cm
  • Intake: Edelbrock Victor, port matched, 1/2” spacer
  • Carb: King Demon RS 1095cfm
  • Rocker Arms: Harland Sharp 1.65
  • Cam: UltraDyne roller 307/314 (271/278 @.050), .4176/.4176 tappet lift, 700/700 net lift with .024/.024 lash
  • Ignition: MSD 6AL, MSD crank trigger, MSD 8981 programmable timing control and is sent through a gutted GM HEI
  • Exhaust: Hooker round port 2"x30” and 3.5" (9.5” long) collector headers, 3.5” to Dr.Gas ‘X’, 3” out to 3” FlowMasters 3 chamber mufflers and no tail pipes
  • Oil control: Melling 80psi oil pump, Canton oil pan
1994 Formula
535ci NA CV-1 - single 1050 with c14 - 940hp@7000/825tq@5200
Pontiac Powered 4th Gen Project Progress
  #65
Old 08-26-2007, 02:25 PM
WARPed's Avatar
Default 416ci 518hp
416cid Specs, my track times in my 69GP with a 3750 race weight has gone a best of 6.90's@100mph & 10.80’s @ 123mph, on the dyno we made 518hp@6300 and 496ft/lbs@4300. This dyno have proved to be conservative by about 50hp when track times & race weight are calculated. I drove this so many untold miles on the street and made well over 200 passes at the track before I pulled the motor to drop in the 467 motor
  • Block: 1970 Pontiac 400 + .060 over, zero deck height, 2 bolt mains with stud kit
  • Rods: Eagle 6.80”
  • Flex Plate: TCI
  • Bore/Stroke: 4.181/3.79 (400 crank offset ground)
  • Heads: Edelbrock 300/220cfm 77cc, cr 9.98, 2.11/1.77 valves, head stud kit
  • Pushrods: 9.300” .080” wall 5/16” cm
  • Intake: Edelbrock RPM, port matched, 1” open spacer
  • Carb: BG Gold Claw RS 875cfm (now called Race Demon RS)
  • Rocker Arms: Butler 1.6 roller
  • Cam: UltraDyne roller 295/303 (262/270 @.050), .3883/.3883 tappet lift, 600/600 net lift with .024/.024 lash
  • Oil control: Melling 60psi oil pump, Canton oil pan
1994 Formula
  #66
Old 09-19-2007, 11:27 AM
Thumpin455_GTO's Avatar
Thumpin455_GTO Thumpin455_GTO is offline
70 GTO 4200lbs race weight.
72 455 +.030 -
4.21" stock crank -.010/.010 balanced
cast pistons
resized cast rods with ARP bolts
Ported 5C heads/stock valves
UltraDyne 280/288 hyd / stock type lifters
stock rockers
RPM/Demon 850DP
Summit headers/ 4' length of 3" pipe with cheap Summit mufflers/no tail pipes
2004R/stock lock up converter
2.93 gears in Olds rear
BeCool aluminum radiator
Stock H2O pump
185 thermostat
best ET 13.51@105 best MPG with Qjet 25MPG, 16 city, 22HWY is normal
Recently swapped in a 12 bolt with Eaton Posi, and 3.42 gears. Have not raced it since.
  #67
Old 09-19-2007, 11:37 AM
72 Formula 3900lbs/ # matching
455 HO 4bolt main +.030
Stock 4.21" crank
Stock reconditioned rods
7F6 heads/untouched/stock valves
CC 292 hyd cam
1.5 roller rockers
TorkerII intake/800 E carb (since changed to Performer/Qjet, runs MUCH better but no ET)
Hooker supercomp headers/Full 3" system
TH400/3000 stall
3.70 gear
Power everything, AC = heavy
Bought from a good friend who had it set up this way. He got a best of 13.0 with it, dont remember the MPH.
  #68
Old 09-19-2007, 11:51 AM
79 Formula 3750lbs race weight
(previous combination)
73 455 + .030
4.21" crank -.010/.010 balanced
stock rods, resized, ARP bolts
TRW Forged pistons
JBP ported 670 heads/Fererra valves/stock size
11.3:1 compression as measured
UltraDyne 288/296 flat hyd
Comp 995 springs/CC locks-retainers
Crane 1.65 aluminum roller rockers
TKII/850 Holley DP
Hooker headers 1 7/8/4' length of 3" pipe/cheap Summit mufflers
TH400/L88 style stock converter/stalled around 2200
4.10 geared 12 bolt. Ran faster with 3.42, but the 4.10 was left over from the previous 400
McCreary DOT dirt track tires/later BFG Drag Radials 296/65/15
Stock WS6 suspension, front sway bar removed
Best ET 11.71@115
Typical ET 12.1@114 / 7.70@ 88 1/8th
  #69
Old 09-19-2007, 12:02 PM
79 Formula - 3100lbs empty
(Current combination)
73 400 block + .030
Eagle 4.25 crank / balanced
Eagle 6.800 rods
Ross pistons
JBP 330cfm E heads 85cc/ tall solid roller springs
CC 270/272 solid roller
JBP 1.6 rockers
Victor/1050 Dominator (4" cowl hood is too low)
Hooker SuperComp headers/2' of 3.5" pipe/3.5" Dynomax bullet mufflers
Th400/manual VB/3600 stall (Needs a 4000 Continental or similar stall)
4.10 12 bolt
adjustable drag shocks up front 50/50 rear shocks
Moroso trick springs in front
NO ET as yet. Only a few shakedown runs around 7.40 in the 1/8th. (3rd gear only)
Will be a while before it sees the track again. Needs all safety equipment and a good stall. Plus the closest track is 6 hours away.
  #70
Old 10-04-2007, 05:31 PM
JoePapa's Avatar
JoePapa JoePapa is offline
Engine Modifications:
'69 400 2 bolt block bored .030
Deck height set to -.001
#62 Iron heads - home port to 275cfm @ .500 lift - heads milled to 10.4 compression with .040 gasket
Stock 10/10 crank
Eagle H-beam rods with ARP fasteners
Forged Probe SRS Pistons
Bullet Solid cam 260 / 258 duration @.050 - .554 / .586 lift int / exh
Crower Solid lifters with EDM hole
Crower 1.6:1 roller rockers
9-way Timing chain from P.P.R. (nice piece)
Edelbrock Performer RPM Intake, top 1” milled out of plenum divider and light porting
Heads and intake port matched to RA IV gasket
825 CFM Mighty Demon
Mallory Hyfire IV
Mallory Mechanical magnetic distributor
Transmission:
’69 Muncie has been upgraded with Super Case, Iron Mid plate, M22 wide ratio gears
McLeod SFI Aluminum Flywheel
11” clutch
Rearend:
Dana 60 with 4.10 gears and 35 spline Strange axles and Aerospace disc brakes
Suspension
Multi-leaf rear springs
QA-1 Race coil over shocks/springs up front set on 90/10
CE adjustable drag shocks in back set on 50/50
1 1/8” sway bar up front
Cal-trac’s
New best ET is 12.06 @ 113 with 1.75 60' time.
Still dialing in combo - shooting for 11's. Need to get 60' times down. MPH is consistently in the 110-114mph range. ET varies from 12.0* to 12.3 depending on launch / 60'.
Edit:
10/13/07 - new best is 12.01 @ 113 on motor 11.31 @ 122 on 100hp shot
Nitrous system is an NOS top shot (sits on top of carb) - 150 shot coming soon...
10/26/07 track trip yielded a new all motor pass of 11.82 @ 114mph with 1.74 60'
- still don't have a solid pass with the 150 shot.
'69 Firebird 400
http://firstgenfirebird.org/show/closeup.mv?CarID=734
  #71
Old 10-04-2007, 05:51 PM
David Holmberg's Avatar
77 Trans Am 3745 lbs with driver
455 .060 over, bottom filled, 4 bolt mains
87cc E-heads ported by Butler, 315cfm.
factory crank, eagle rods 6.8, SRP flat top pistons
254/262 solid roller, .590 lift (street roller)
Victor, Holley 4150 (850)
Hooker headers, 3" exhaust with X pipe and tail pipes.
Turbo 350, TCI 3500 converter, 3.42 gears with a posi in the stock 10 bolt, MW axles
Cal trac's, mono rear springs, QA1's
Weld pro stars, 3.5's and 10's with 13.5x28 QTP's.
Full interior, Alpine Stereo with Subs, 10 pt cage, per NHRA rules.
10.90's @ 125 on motor
9.90's @ 135 on a plate kit.
Street driven all the time.
  #72
Old 10-11-2007, 07:16 PM
Virginian's Avatar
Virginian Virginian is offline
Default Two tales
I used to have -
73 TA, Bucaneer Red, no AC
4 Speed - M-22 - Hurst
4.10 rear gears, Saf-T-Trak of course
455 original block
'67 GTO heads (I think they were 92 or 94s?) reworked with bronze guides and knurled stems and 3 angle valve job by Kline Automotive in Richmond VA
Copper head gaskets, O-ringed heads - 11.25/1 coompression
Crane Fireball Cam (294/304 advertised, about .45 lift), springs, lifters, etc.
GM 1.65/1 rockers
GM HD pushrods
Edelbrock intake
Holley 850 DP
Hooker Headers
Rebuilt recurved distributor
Carter fuel pump
reworked water pump (2 vane)
Undersized drive pulley
Scoop opened up for cold air
Traction bars I could adjust at the track
Air Lifts
Turned about 12.25 to 12.30 at 128MPH at Richmond, VA
I still have-
1966 Goat, Barrier Blue, no AC, no PS, Quick Ratio Steering
3 dueces, Posi, 4 Speed M-20
Bobcat Kit
M&H Cheater Slicks
Turned a best of 13.12 at 107 at Richmond, VA
ID:	107558   Click image for larger version
"What could have happened, did."
  #73
Old 10-29-2007, 12:33 AM
Paul Westcott's Avatar
Paul Westcott Paul Westcott is offline
Default EFI 455 Street and Strip
1967 Pontiac Tempest 2 Dr. HT ...originally an OHC-6 1barrel w/ 3 on the tree.
This car was designed and built to be a REAL street and strip car. As such, it is by definition, a compromise. It is not another of the all too numerous “race cars with a license plate” that pretend to be called a “street car” while screaming down the highway at 4000 RPM, sucking fuel like a Titan rocket! Seriously, what kind of gas mileage do you get and how practical and reliable is it on a long road trip? Oh, well! ...to each his own! My goal is a stealthy, reliable, pump gas friendly and relatively economical road cruiser that is also capable of kicking some ass in the quarter mile!
Engine Details, Etc.:
1970 XF code, 4-bolt main, 455 +.050 (467 cu. in.)
Stock Nodular crank turned 0.010
Cleavite bearings
Ross Custom flat top pistons
Hastings file fit rings
Eagle forged H-beam 6.625” rods
Zero decked
9.5:1 comp. ratio
Melling 60 psi oil pump
Balanced rotating assembly
SFI balancer
Fel-pro gaskets
#96 heads, ~96 cc, hardened seats, gasket matched, blocked crossovers and mild porting
Ferrea SS 2.11 / 1.77 valves
1.6 ratio aluminum roller rockers
Comp XE 274 cam 230/236@.050 523/529 lift w/1.6 rockers 110LSA
Comp Cams timing chain set, hyd. Lifters, valve springs and push rods
Edelbrock Performer RPM intake manifold
Holley 900 CFM TBI with 4 x 85 lb. per hour injectors
Megasquirt II v 3.0 ECU -controlling all fuel and ignition.
3/8” in / out fuel lines
Twin parallel MSD EFI inline fuel pumps
Innovate Wideband O2
HEI w/locked down mech. advance and no module
34 degrees advance in by ~3K rpm
MSD6AL box
MSD coil
MSD 8mm plug wires
Doug's Headers
3" pipes w/ 3" X pipe and 3” cut-outs
Dynomax Super Turbos
Dual Flex-a-Lite electric cooling fans
Trans Details:
’88 700R4 -w/Hytek max build
Transgo 700 shift kit
TCI BOP adapter
2500 stall converter, w/full lock-up
B&M trans cooler
B&M Megashifter
Rear end:
10-bolt BOP 8.2 Nodular GS type
3.55 Richmond gears
Auburn Pro posi
TA Performance Rear End Girdle
Moser custom alloy axles
SSM lift bars
Split, independent-fill air shocks
275-50-15 BFG Drag Radials (track)
245-60-15 BFG Radial T/A (street)
Misc.
PST polygraphite front suspension kit
MBM power front disc brake kit
OMZ Racing seats
Hurst Line-Lok
Highway Performance: Getting close to 20 MPG @ 70 mph cruise at 5% throttle!
-Runs nicely on the 91 octane oxygenated crap gas found here in Phoenix.
¼ Mile Performance: Only 1 trip to the track so far; ET 13.05 @ 107 mph with a momentary starting line bog and resulting lousy 60 ft. times. Pulls very hard thru top end!
More tuning needed w/TBI at launch.
-Looking for mid to upper 12’s?!
…Stay tuned!
Weight: ~3700 lbs. w/ driver
ID:	109518   Click image for larger version
Name:	Tempest 03.31.07XM.JPG
The 1967 Rustbelt Refugee. Work in progress. Donations accepted.
- 467 Cubic Inch EFI Pontiac, Megasquirt II v.3.O ECU, 700R4, 3.55 gears -
Best 1/4-mile ET: 12.79 @ 107.36 MPH - Best Fuel Economy: 18.47 MPG
...That's no GTO, that's a Tempest!
  #74
Old 11-12-2007, 01:13 PM
4speed455 4speed455 is offline
Default Daily driver, 76 TA
455 .040 over, early Pontiac forged rods, KB pistons, zero decked
800 Qjet, MSD dist. both done by the late Bob Maxie
KRE 310 dports , WFO drop base, RPM port matched, UD 239/247 hyd (. 507/.520)
MSD 6AL ignition, 6000 rpm chip, (effective @ 5,500)
Borg Warner 4 speed, 2.88 first gear
Hooker headers, Dr Gas 3" X 2.5" crossover, Flowmaster transverse muffler
Stock 3.23 rear, driven year round as long as the streets are dry
Temp never over 180 degrees, stock water pump
Sorry no pics, this car is from an all analog, vacuum tube powered home!
Never on the track, Always enjoyable!
Garcia Hill
Fort Washington, Md
  #75
Old 11-27-2007, 02:43 PM
prexford's Avatar
prexford prexford is offline
1971 Pontiac Formula 400
Engine
Stock Displacement: 400 (actual 400.18)
Block modifications: trimming of flange castings by lifter cross over for better oiling
Freeze plugs: brass
Displacement after bore: 406 (.030-inch over)
Bore: 4.12
Stroke: 3.75
Main Size: 3.00
Main Caps: stock 2 bolt
Rotating assembly: Stock
Crank: Stock 3.75
Rods: Stock (Length)
Bearings: Federal Mogul Cam FEM-1220M, Main FEM4040M, Rod FEM-8-7050CH
Pistons: unknown .030-inch over aluminum stock type flat top
Rings: Moly model SLP-E-299K030 from Summit/Sealed Power brand
Timing Chain and Gear: Comp Cam model 2112 stock chain gear type
Oil pump: Melling MEL-10541, shaft MEL-IS-54A
Camshaft: Summit model SUM-2801 214 / 224 duration at .05” lift with 1.5 rockers,
advertised 272 / 282, 112 lobe separation
Lifters: Comp Cam model 852-16
Push Rods: Comp Cam CCA-7851-16, length 9.136”, 5/16” diameter
Rocker Arms: Harland Sharp 1.50 full roller rocker model CSP-S6001
Clylinder heads: Stock 1971 96cc heads
Cylinder head modifications: trimming of casting flanges for better oiling, light porting of exhaust, light porting of intake openings and push rod bulge
Rocker arm studs: 7/16” (big block Chevy type) ARP Model ARP-135-7101, poly-lock 7/16” by ARP model ARP-300-8245
Valves: Ferrea stainless steel valves 4.98” length; 1.77 exhaust model F5062, intake 2.11 model F5065
Valve springs: dual springs, Crower model 68404
Valve retainers: Comp Cam 10 degree model CCA-740-16
Compression ratio: 8.2-1
Fuel / intake
Carburetor: Stock 1971 Rochester 704163 750 CFM
Intake: stock 1971 455 HO aluminum intake with cast iron exhaust crossover (blocked)
Octane: pump gas 91 octane
Air cleaner: Stock ram air cleaner
Exhaust
Mufflers: Dynomax, dual mufflers
Tail pipes: 2.5” diameter
Exhaust Manifolds: Stock ram air III D ports
Cooling
Radiator: OEM style from NPD; Aluminum. 160 degree thermostat
Drivetrain
Axle: 3.75
Tries: BF Goodrich 235/60 R15, Rally 15 x 7 rims
Traction bars: Lakewood
Transmission: 4 speed, Muncie M21 close ratio
Clutch: Ram clutch, 10 1 /2” diameter
  #76
Old 11-27-2007, 02:58 PM
ericwy's Avatar
ericwy ericwy is offline
My daily street driver.....
1977 TA 400 9.5:1 CR 351hp 414LbFt, #13 Heads + 1.52 Roller rockers, 1968 Pontiac 400 intake, Holley 4165 650 DP #7054
Howards Hyd .447/.467 IN:288 EX:298 214/224@.050, MSD6A + MSD timing control + H2o/Meth
1-5/8" headers, Magnaflow 200CPI Cats + 2.5" Pypes X, Dynomax STs, TH-700R4 2200 stall, 3.42 Eaton 10-bolt, PS/PB/PW/PL/AC/Cruise
13.84@100.14mph 2.18 60' on P255-60-R15 radials, pump gas, mpg : 21.5 hwy 15.2 city
  #77
Old 12-07-2007, 10:42 AM
track73 track73 is offline
1979 T/A WS-6 4 speed w /rear 3.42 gears w/ original posi 245/60 BF Goodrich tires
engine:
455 .030 over w/trw pistons
stock rods reconditioned to H-O's specs with good bolts, magnifluxed and shot peened
'71-no. 96 heads 3 angle valve job
Cam Dynamics (crane) no. 10514 Cam 234/234 .494 lift w/1.5 stock rockers and Rhodes lifters and stock push rods
Competition Product no. 98341 valve springs
Edlebrock Performer or Holley Street Dominator manifold (depending on how I feel )
Holley 850 dbl pumper w/original jets
BOP rear seal
Warrior crank scraper
Centerforce 10.5 clutch
'68 GTO ram air III exhaust manifolds with 2.5 pipes w/Flowmaster mufflers
Griffen aluminum radiator w/ 7 blade clutch fan and homeade shroud.
Accel ingnion with HP module and coil set at 34* and a Crane vacuum advance
Suspension is a complete Rancho kit w/ stock Gabriel shocks
I am planning on installing 1 5/8 4 tube headers w/cossover and 1.65 rockers
The above combination produced 474 LB/FT of torque at 4000 RPM and 417HP at 5000 RPM on My Performance Trends Engine Analyzer. The torque curve was very flat only varying 71 lb/FT from 3000 to 4000 RPM. I used N0.62 heads for the flow example with 9.5:1 compression. Take it for what it's worth.
  #78
Old 12-17-2007, 03:50 AM
RAJNWDY's Avatar
RAJNWDY RAJNWDY is offline
Talking EL GATO GRANDE
My car is a 1964 Catalina Executive 4 door sedan.
stock: it had am radio, Air Conditioning, Seat belts in front, Power steering, 389 O5L engine, 2.56 to 1, with a Roto Trans. Weight around 4100#.
Racer: No seats, bucket for driver only, No A/C, No Power Steering, cross bracing for rear seat removed, heater removed and all extra sheet metal up front, flat panels made from aluminum road sign material. wet weight: 3650# Race weight: 3945#
Engine:
Stock WX 455 out of a 76 Trans Am
Stock Crank
Stock Rods
Stock Cast pistons with 9 CC champher
Stock large inlet oil pump, changed from small inlet on this engine
Stock oil pan w/baffle no windage tray
Cam: Ultra Dyne...can't find my card at the moment
Cam Chain: Cloyes Double Roller
Lifters: Pep Boys replacements, good for 5500 RPM
Pushrods: stock for heads used
Valves: stock, Ram air 4 springs & retainers. no shims
Heads: casting 98 2.11 intake 1.60 exhaust, 3 angle, no porting, .030 off surface
C.R.: 8.6 to 1 87 octane fuel
Rockers: JBP Aluminum rollers at 1.60
Lift at the valve: 5.12 intake 4.98 exhaust
Headers: Unknown Make 4 tube headers into 3" collector
Exhaust: 3" pipe into 4 chamber flow masters, dumped at the rear end
Distributer: Stock Point type, Accel 32oz points, cap, rotor, Beldon 8mm wires, accel coil, resistored
Advance: 14* locked at idle, 34* total at 2800, No Vacuum
Spark Plugs: Autolite
Manifold: Edelbrock Torker II
Gaskets: Felpro
Carb: Holley 750 cfm Vacuum secondary set as lite as it can, no choke, 2.5 PV
Jetting: its been so long since I had it apart, I don't remember
Air Cleaner: 8" round, 6" tall K & N sticks partally into scoop
Water pump: stock, electrically driven
Alt: internal regulated, belt
Damper: Stock, used to have timing tape
Transmission: T-400 short tail
Rebuilt? Yes, by owner with mods from T-400 book, shift kit, seals modified
Converter: GM-6 HD Stock replacement for 427 Corvette Ect.
Stall: Roughly 2200-2400
Driveline: 4" Lincoln shaft with the ends made to GM 64" long W/loop 8" behind yoke
Shifter: full ratchet up and back
Rear end: Stock 64 Pontiac
Gears: 3.42 to 1 with "spyer locks" no spool, no Saf-T-Track
front tires: 215/75/15" Rear: 9 X 28 X 15 Mickey Thompsons
Fuel Pump: Holley Blue with regulator
Fuel tank: 9 1/2 gallon cell in trunk Battery: in trunk 1 or 2
Fuel line: stock no return
Power Adder: 150 Plate shot of NO2 at owner descretion. not linked to throttle
10# bottle in trunk, best pressure to run this car.....940-1000 PSI 115V heater
Brakes: single circuit, Manual Drum/drum
Axles: Stock
Steering: Manual box transplanted
extra engine filter: Frantz oil Cleaner with Modified roll of CHARMIN TP
engine filter: Purolator Blue stock type
Oil used: Castrol Syntec 20-50
Oil changed at: I don't change the oil, just the filters, OIL IS 7 YEARS OLD
Gauges added: Hour Meter, Oil, Volt, Temp and 8000 Autometer Tach with Sh/lite
Hours on meter since car in this configuration: 152
Street driven? yes, it is licensed and can be driven legally on street
Fastest speed driven: well over 120 +
launch RPM: Just off idle to 1400 in low, manually shifting, shift light set at 5200 rpm
1/4 mile results: LACR 13.69 on engine, @ 98 12.58 NO2 @ 106.9
POMONA: 13.25 on engine @ 102. 6 12.05 NO2 @ 114.7
Sears Point: 13.20 on engine @ 1--.- 11.93 NO2 @ 111.7
The 11.93 was a surprize and I got in trouble because the car wasn't set up for that.
It launched so hard it knocked the wind out of me, and yes I have a copy of the time slip for both Pomona and Sears Point (infineon raceway park)
Name:	Cat engine.jpg
ID:	114784   Click image for larger version
ID:	114785   Click image for larger version
ID:	114786   Click image for larger version
RDRR Custom Fabrications
....A fictitious company doing fictitious work....
  #79
Old 01-28-2008, 11:59 PM
JoePapa's Avatar
I have another post on page 3 but the motor has since been rebuilt – this is the new combination. Car is a ’69 Firebird, full body car. ~ 3600 lbs curb weight.
Stock 10/10 crank
Mallory Hyfire IV
Transmission:
11” clutch
Rearend:
Nitrous Top Shot set to 150hp
Best all motor pass is 11.82 at 115 or 116 mph. Can run 12.0 at 114 pretty consistently.
Best nitrous pass is 11.20 at 125mph. Also pulled similar times on 100 shot.
Still tuning …
'69 Firebird 400
  #80
Old 01-31-2008, 04:08 PM
cushsix cushsix is offline
Default 1968 Ram Air III GTO convertible
'69 engine L74 YZ 400/366 HP 410 ft lbs torque performance longblock:
400 block bored, honed, decked and align honed
Speedpro® performance camshaft:
214/224 @ .050 or cam of choice
.465 lift
112 lobe center
New Durabond® cam bearings
Reground 3.75” stroke steel crankshaft
Resized rods with ARP® rod bolts
New King® performance bearings
Speedpro® domed forged pistons with Molly® rings
9.3 to 1 compression ratio
New Melling® timing set
New Melling® high volume oil pump
New performance gasket set
Pontiac Heads #48 includes:
2.11/1.77 new performance valves
Bronze guides
3 angle seats
110 lb. Matching springs
New push rods and stamped rockers
TH 400 3 sp automatic His/Hers shift
Flowmasters
