Old 02-19-2009, 12:21 AM
greggutknecht greggutknecht is offline
7211 i thought in your earlier pics your car sat lower did you raise it for a reason?Greg
  #62
Old 02-19-2009, 12:24 AM
BILTIT's Avatar
BILTIT BILTIT is offline
It is sitting 2'' to high right now, he needs to make some adjustments or something he said.
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
  #63
Old 02-19-2009, 01:04 AM
ventura7211's Avatar
ventura7211 ventura7211 is offline
The height was raised, but not by choice. After breaking the dana 60, I built a 9inch for the car. The back brace for the 9 covers the holes in the brackets where I had the coil overs on the dana. When I put the car back on scales and "blocks", I'll adjust the height back to where it was so the ladder bars will be back at the proper angle. I prefer to do this step last when the car is "race ready". I should have enough adjustability left to do it with the shocks, so hopefully I will not have to change the upper mounts. Sucks but that's part of finding the weak link in a car, I guess. However putting the rear tires on is easier, so it has that going for it, lol.
  #64
Old 02-19-2009, 07:25 AM
ponjohn's Avatar
ponjohn ponjohn is offline
I never would have guessed the dana would be the weak link?
What IS the proper angle for the ladder bars?
John
  #65
Old 02-19-2009, 10:43 AM
John
Yep, twisted the driverside tube.
Bars, parrallel with the ground. Pinion, -3.
  #66
Old 02-19-2009, 11:17 AM
BILTIT's Avatar
Was the tube welded?
I think twisting a tube can be done on any diff, not really a particular diff's weak link.
I know people who have spun a tube on 14bolt full floaters, still an extremly strong diff just needs the tubes welded to the centre section.
Derek B.
  #67
Old 02-19-2009, 11:30 AM
Tubes were welded all the way around the centersection, the tube ripped away from the rossets and the centersecion broke where the tubes were welded. The tubes spun and pulled out around an 1/8" or so. Just part of racing.
  #68
Old 02-19-2009, 11:44 AM
BILTIT's Avatar
Hmm, that does seem like alot of damage for a 60.
Derek B.
  #69
Old 02-19-2009, 08:02 PM
71 Ventura II's Avatar
71 Ventura II 71 Ventura II is offline
Lance, no harm intended but I keep thinking the weld penetration was the cause of the dana failure. Thoughts??? JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride!
  #70
Old 02-19-2009, 09:08 PM
BILTIT's Avatar
Anyone know of any double adj. rear shocks for sale?
Derek B.
  #71
Old 02-21-2009, 01:31 PM
The rossets started "leaking" after the first trip to the track, more of a I got a bum housing out of a salvage yard then anything else, no biggie.
They show up on the NMRA forum quite often. Just buy a good coil over and not use the coils if your staying with leafs.
  #72
Old 03-01-2009, 12:58 AM
BILTIT's Avatar
New rear rims are in!!
ID:	159813   Click image for larger version
ID:	159814   Click image for larger version
Derek B.
  #73
Old 03-01-2009, 09:14 AM
ponjohn's Avatar
Very Nice.
what specs?
  #74
Old 03-01-2009, 01:22 PM
BILTIT's Avatar
15x10 5.5BS
Derek B.
  #75
Old 03-01-2009, 06:14 PM
ponjohn's Avatar
Do yourself a favor and weigh them, you'll want to know at some point what they weigh.
  #76
Old 03-01-2009, 06:22 PM
BILTIT's Avatar
Will do, they feel very light.
Derek B.
  #77
Old 03-01-2009, 10:38 PM
Did you decide to narrow the rearend at the same time as the mini-tub? I have Centerline rims that are 8.5" wide with IIRC 5.0" BS; in conjunction with my rearend which is 1.5" narrow than stock. My 29.5"/9.0/15 tires barely and I mean I had to really beat the inner lip of the quarter and cut the crap out of it to get them to fit. They still rubbed a little making shiny areas on the sidewall so I preloaded the springs via extensions on the front of the CE J-bolt bars to stop the contact. Will the new rim "tuck" under? Pictures? JD
  #78
Old 03-01-2009, 10:41 PM
BILTIT's Avatar
I will be narrowing, yes. I want to go to a bearing retainer ( not c-clip eliminators) so narrowing aswell is not that big of deal.
Derek B.
  #79
Old 03-01-2009, 10:50 PM
COOL! I can't wait to see how it turns out. I have plans on the "horizon" to swap my car to ladder bars and coil-overs. Keep us posted! JD
  #80
Old 03-01-2009, 11:19 PM
BILTIT's Avatar
Almost have the garage done, the car is coming back in as soon as i find two more friends to help push it in or the weather gets closer to melting (no block heater in the car).
I should have it in by the end of the week. Want to start on the tubs ASAP. Also waiting on autoweldchassis to see about shipping tubs to canada, have to phone them back tomorrow.
I am going to test fit the rims before having the tires mounted to verify they are correct.
Front QA1's are on the way, sliders should be on the way shortly.
Derek B.
