#61
KRETTFMF!!! Do you think he is all butt sore over E'heads because they've went sevens naturally aspirated in a similar weight car and GG is still trying to accomplish that with hi-ports and a power adder.... along with much bigger tires?
#62
Cast in ductile iron, or steel. |
#63
KRE,s billet block with standard mains is one choice. Then you have Visners block and the LSM block. They would not be there if people did not feel the need for them. Builds are coming. |
#64
Iirc twinTurbo Bill has made one of these
#65
Like i stated it's nice for reliability but not sure it's slowi g people down. Just my opinion. |
#66
A fully skirted, deep block design with large cross bolts is a superior design for very high HP applications, little argument there. A bolt-on girdle band-aid apparatus of some type would also help some depending on specific design and how it was married to the block. A billet block with smaller mains and a skirted block would be better suited to the Boss Bird application. It would not be "Pontiac" enough to the guys who own it though. So far, at least, cap walk and fretting have been tolerable. Best possible race block? No, that would require a billet block that was not a "Pontiac" IMO. The Boss Bird cast Aluminum block is a stock dimension, stock deck height, 3" main traditional "Pontiac" block. Any production Pontiac head will bolt on, it uses a stock dimension lifter valley cover, timing cover, oil pan and valve covers. Everyone has their own idea of what a Pontiac needs to be, and it varies allot depending on who owns and races the car. Honestly, at an open event, more people think our engine is some type of small block or big block Chevy than a Pontiac. They generally figure out the narrow cylinder heads and plug wires not going through the middle of them must not be a hemi.
#68
I just want to see guys try it. (skirted) See just how much a Pontiac can push down on a crankshaft. |
#69
First Pontiac powered street car in the 7's 7.940@170.84. 3460#s |
#71
“If you street...be street...if you ain’t...be ain’t...” Ever notice how those guys come off the track racing deal and then can’t hang with a Pontiac on the street. They lose the tune...Chief doesn’t...he’s still street racing even off the show and making big money at it! |
#72
LOL so true./.
#73
KRE did have some of the early blocks, well you know how that went. It has slowed people down. When you rip every main out of a race iron block it tends to do that. Just because the crank actually did not end up on the pavement does not mean the block did not fail. Pics don't lie. Not posting so don't ask. Cast iron has its limits. |
#74
Dragncar you and that scarecrow from the wizard of oz have allot in common
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
#75
Lmfao!!
#76
And as Chief’s license plate says.....”481XLOL” |
#77
The more I think about it I believe he made a cap/main girdle set up
#79
Again a skirted block is nice but i dont see performance being effected just reliability |
#80
We are going back nearly 10 years here, but I think that set-up actually produced in metal was for an Oldsmobile V-8. If my memory serves Mr. Anderson was working with Cody, (last name?) at Joe Mondello Racing Engines and they had cut that unit out for Oldsmobile installation. I do remember him posting somewhere a similar unit for a Pontiac in a CAD format of some type. But not sure if one was ever made. Steve Barcak and a couple other guys have made multi-piece reinforcement girdles for Pontiac blocks. As an engine machinist, I like the multi-piece design from a service standpoint. Having a one-piece girdle/main cap bridge is a complete nightmare when it comes time to line bore/hone the mains. Conventional engine machining equipment can't handle a piece like this. Now your into CNC machining for routine service. A deep skirted block with 7/16" or 1/2" cross bolts and individual caps would be the best for strength and service. For big HP, a stock design Pontiac block just doesn't have the material in the right places to create the best possible lower end. If you use 9/16" fasteners in the center bolt holes, there is very little material left to hold them. The outer splayed holes as well if large fasteners are used, very little material to hold them. A much smaller main bearing would help by allowing more material around them to hold the caps. The original 180 HP design from 1955 has it's limits. The 3000 HP a few are making out there is probably close.
