Closed Thread
Old 03-21-2020, 12:59 PM
Stan Weiss's Avatar
Originally Posted by mysticmissle View Post
george you already had the block honed to new pistons?
Originally Posted by GTOGEORGE View Post
No they honed the block first or before I got the pistons.
GTO George
Remember This is GTO George you are talking about. He doesn't do thing like everybody else. As he says it is all plug and play.
Stan
Pontiac Pump Gas List
  #62
Old 03-21-2020, 01:29 PM
charlie66's Avatar
GTO George
I hope you're gonna recheck'm again...
My Half AN Injun.....
  #63
Old 03-21-2020, 02:09 PM
GTOGEORGE's Avatar
Yea, that’s the plan, I’m sure they be fine.....not like the old’n days! LOL!
GTO George
  #64
Old 03-21-2020, 02:10 PM
GTOGEORGE's Avatar
Stan
This is a little different! LOL!
GTO George
  #65
Old 03-21-2020, 03:10 PM
charlie66's Avatar
Good luck .
Hope to see you at Norwalk this year...
  #66
Old 03-23-2020, 12:38 PM
GTOGEORGE's Avatar
Race car SH_T...........everything come with numbers so if you need a replacement they give you the same item that you had before!
New on the left old on the right.
My aluminum GRP rods were the same, came with a number, I told them the number they looked it up a got me another set the exact same.....plug & play.....kinda!
GTO George
ID:	535149   Click image for larger version
ID:	535150   Click image for larger version
  #67
Old 03-27-2020, 03:23 PM
GTOGEORGE's Avatar
I received my !/2" ARP2000 studs today, they look really GOOD!
GTO George
  #68
Old 03-27-2020, 04:49 PM
GTOGEORGE's Avatar
GTO George
Im able to get 2 sizes in the ARP2000 (stronger then 8740 material) 1/2" head studs, 6 5/8" & 5 1/8" both can be cut down 1 1/2" on the block side thread.
GTO George
  #69
Old 03-29-2020, 07:19 PM
GTOGEORGE's Avatar
Reinstalled old main bearings except for no.1 main, dropped crank in. Starting to finally come together.
I have 2 years on the bearings.......still look great!
GTO George
ID:	535712   Click image for larger version
  #70
Old 03-31-2020, 04:45 PM
GTOGEORGE's Avatar
I just got through installing the main caps and torquing them to 75 ft lbs. (for now), I hate torquing stuff when it cold out, I'm want for warmer weather to finish the torquing of the mains by then I should have my pistons & rods in.
GTO George
ID:	535892   Click image for larger version
  #71
Old 03-31-2020, 07:57 PM
Cool?
88 degrees here. (no record today though, so is cooler)
Get er dun!
  #72
Old 03-31-2020, 08:13 PM
GTOGEORGE's Avatar
Cool?
Get er dun!
Not in a hurry it’s going to be awhile before racing resumes.
GTO George
  #73
Old 04-09-2020, 05:23 PM
GTOGEORGE's Avatar
So now that I'm sitting at home I've got plenty of time to work on my Blower engine. I hung the rods today, installed camshaft, timing chain and started fitting the NEW ARP2000 head studs! On a side note I'm also getting my Wifes TA blower motor ready for the streets.
GTO George
ID:	536847   Click image for larger version
ID:	536848   Click image for larger version
  #74
Old 04-10-2020, 03:11 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
... I hung the rods today...
I'm just curious what "hanging the rods" means to you? To me, it's a job for an engine shop- checking that the centerlines of the big/little-ends are precisely parallel in both planes.
  #75
Old 04-10-2020, 06:39 AM
GTOGEORGE's Avatar
Nope, just installing pistons on the rods. New pistons and pins, same rods and crank and bearings.
Today I plan on installing the gapless rings on pistons after checking gap in cylinders.
GTO George
  #76
Old 04-15-2020, 02:39 PM
GTOGEORGE's Avatar
Got the rest of my NEW ARP2000 studs yesterday! I finished on installing the rings on pistons, maybe Saturday when it gets warmer (its 34 degrees outside now) ill drop piston assembly into block!
Race Car STUFF!
GTO George
ID:	537412   Click image for larger version
ID:	537413   Click image for larger version
  #77
Old 04-15-2020, 07:22 PM
charlie66's Avatar
What rear main seal are you using George? Have you tried the 1 piece yet?
  #78
Old 04-15-2020, 07:48 PM
GTOGEORGE's Avatar
Yes I have I’m on my 2nd seal.......no problems it works great!
GTO George
  #79
Old 04-17-2020, 10:51 AM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Race Car STUFF!
GTO George
Hey George,
Can you post the P#s for the ARP2000 studs, I'd like to see if I can get them to work with the DCI V heads.
Thanks,
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #80
Old 04-17-2020, 11:14 AM
GTOGEORGE's Avatar
Hey George,
Thanks,
What size are your studs?
GTO George
Closed Thread
