Old 12-17-2019, 10:29 AM
Region Warrior's Avatar
Jack, yes, the MT block I posted photos of is at the Pontiac Museum. I have more detailed photos (hi-res), but PY reduces the image size.
The all-aluminum engine that appeared in a 1962 Catalina at the POCI Nats was another one I thought of.
Mike
Aluminum D-ports!
  #62
Old 12-17-2019, 12:25 PM
Looks like it even has the Aluminum Exhaust Manifolds too !
They went the full blown monte'
  #63
Old 12-17-2019, 12:27 PM
tom s tom s is online now
When I got then engine it even had a alu 4 bolt water pump,alu 60 style flat 4 bbl intake and timing cover.Will find the pic as I found it and post.Tom
  #64
Old 12-17-2019, 12:45 PM
Monetarily wise it makes no sense to do anything with these castings as they will never be as good as the aftermarket alu blocks avail.
I have never been accused of having good sense.Tom
Don't have to worry about good sense when you have good tastes.
Aren't these blocks even More Raw than the raw un-machined aluminum block you didn't want to hassle with - and sold to Greg Tee.
Greg built it with Iron Ram5 heads and put it into a 70 TA. iirc
idunno who did the machining for him
Maybe the folks who machine the new aluminum blocks would be a good place to send them -
if the locals cringe and give nuclear quotes.
Good luck and Best wishes on the journey
  #65
Old 12-17-2019, 02:20 PM
I sold that block to SteveBarcheck,he sold it to Greg and KRE finished it and Rick Johnson built it.Tom
  #66
Old 12-17-2019, 06:44 PM
mgarblik mgarblik is offline
The IA II Aluminum blocks are machined on fully automated multi-axis CNC machines. I would be scared to death to sent a one of a kind block into a machine like that and push the GO button. No way to recover when something goes sideways. KRE has the ability to machine it in manual mode, which you can generally hit the emergency stop before something is completely ruined. Might be worth a call. It can be machined on a manual mill. Lots of time and set-ups. It would take hundreds of hours. A labor of love, not profit.
  #67
Old 12-17-2019, 06:48 PM
here are some old pics of the all alu factory engine
ID:	526953   Click image for larger version
ID:	526954   Click image for larger version
ID:	526955   Click image for larger version
ID:	526956   Click image for larger version
  #68
Old 12-17-2019, 06:50 PM
sorry about the first pic
  #69
Old 12-17-2019, 06:53 PM
more of the engine
ID:	526959   Click image for larger version
ID:	526960   Click image for larger version
ID:	526961   Click image for larger version
ID:	526962   Click image for larger version
  #70
Old 12-17-2019, 09:27 PM
Thanks for sharing those with us
Super Cool Stuff from back when.
Looks like that one was the best all-around keeper in a hind-sight way.
Current owner really has it dressed out to Kill/Die for
  #71
Old 12-17-2019, 10:51 PM
The current engine except for the exhaust manifolds is how it went with the 63 wagon.At one time the current owner had a M/T cross ram on it.I sold it with the 2-4 and a tripower.Tom
  #72
Old 12-18-2019, 11:18 AM
Jim Moshier's Avatar
Jim Moshier Jim Moshier is offline
AMAZINGLY very cool stuff Tom, thank you for sharing.
Jim Moshier
1971 Grand Prix 462ci SD Performance 6x heads
1962 Catalina 389
1968 Firebird 400-455 I haven't decided
"If we ever forget that we're one nation under GOD, then we will be a nation gone under." - Ronald Reagan
  #73
Old 12-18-2019, 11:29 AM
The really cool deal with the factory heads was the valve cover rail had the CCs of that chamber stamped on it.Tom
  #74
Old 12-20-2019, 04:27 PM
Was at the machine shop today and it looks like these blocks have the pad for the block mounted starters!Tom
  #75
Old 12-21-2019, 11:11 PM
carcrazy carcrazy is offline
Wow....what a great find! Look forward to seeing what you do with them!
  #76
Old 12-22-2019, 10:30 PM
Hooter's Avatar
Hooter Hooter is offline
Looks like the price on my 62 GP is going up lol. Nice find.
67 Bonneville ragtop
  #77
Old 12-22-2019, 10:40 PM
Brad,if I get it done in the car(if ever avail)you can have your choice of the original 389,the 421 in it now or the alu engine or all 3!Tom
  #78
Old 12-22-2019, 10:42 PM
I actually sent a text and pic to someone with a pair of M/T hemi heads that I would consider a trade for stuff he has that I cold use.MAYBE one would get matched with a set of heads!Tom
  #79
Old 01-19-2020, 01:51 PM
pont406's Avatar
pont406 pont406 is offline
Here is Herb's Aluminum block and M/T "Side Port" heads, BTW the crossram setup is there to cause you to look twice LOL
Name:	herb aluminum block.jpg
ID:	529145   Click image for larger version
Name:	herb aluminum block 2.jpg
ID:	529146   Click image for larger version
Name:	herb aluminum block 3.jpg
1966 Lemans, 3700Lbs, 406 ci, #96 Heads, Crane 467/494 cam, RPM Intake, Q-Jet, 11 inch Converter, 3:90 gears, 3 inch exhaust, Best ET 12.62@107 MPH 414ci shortblock coming soon!
  #80
Old 01-19-2020, 01:57 PM
pont406's Avatar
the block numbers
ID:	529148   Click image for larger version
Name:	61 mickey exp.jpg
