Old 03-07-2021, 10:18 PM
napster's Avatar
napster napster is offline
They have a website?
http://texastransam.com/
  #62
Old 05-02-2024, 09:03 AM
napster's Avatar
Thought I would update a few things. Since the last post was awhile ago, I had the fans upgraded on the cooling system to Derale 16 inch fans and they flow 4,000 cfm. Another item upgraded was the whole car was rewired using American Autowire. The last item is the rear suspension. Goodbye leaf springs, Hello bolt on 4-link and coilovers. Ridetech is the system used. Here are some pictures of the rear suspension in stages.
ID:	633050   Click image for larger version
ID:	633051   Click image for larger version
ID:	633052   Click image for larger version
ID:	633053   Click image for larger version
The Following User Says Thank You to napster For This Useful Post:
  #63
Old 05-02-2024, 09:43 AM
So it uses the original leaf spring axle mount for the lower bars?
How close to being on the road?
  #64
Old 05-02-2024, 10:38 AM
napster's Avatar
John,
That is correct the kit uses the original leaf spring mounts for the lower bars.
It will be about 1.5 months. Other items are on the list and then it is off to the body shop.
