Old 06-08-2010, 01:14 AM
codyyy's Avatar
codyyy codyyy is offline
Looks extremely good. I can't wait to get that far, I'm almost done with the frame and then I'll probably move to the underside of the car. I'm not sure what to coat it with though, part of me wants to go with POR-15.
  #82
Old 06-08-2010, 06:53 AM
2002Z4CSS's Avatar
Wow, really looking nice so far.
1971 Pontiac GT-37
  #83
Old 06-10-2010, 11:57 PM
webfoot's Avatar
webfoot webfoot is offline
July 10th: body back on frame party at my house! Who is down?
-Jeremy
1968 GTO 4-spd convertible, console, factory gauges, hidden headlights, 3.90:1 posi, AM/FM radio.
1962 Catalina convertible, Starlight black w maroon interior & white top.
  #84
Old 06-11-2010, 11:08 AM
goatman-68's Avatar
goatman-68 goatman-68 is offline
If I happen to get a free round trip airline ticket in the mail, I'll be there.
  #85
Old 06-11-2010, 11:56 AM
webfoot's Avatar
Hehe! It should be good and stifling hot by then.
-Jeremy
  #86
Old 07-11-2010, 10:03 PM
webfoot's Avatar
Success!! This was waaay easier than I thought.
-Jeremy
  #87
Old 07-12-2010, 11:47 AM
nh68gto's Avatar
nh68gto nh68gto is offline
Looks great. You are getting closer and closer!!!
Send it! It’s going home on a trailer.
  #88
Old 07-13-2010, 05:29 PM
goatman-68's Avatar
Looking good Jeremy...... I think I would take a break and do some insulating and a furnace install. That way you can have fun all winter.......
  #89
Old 07-13-2010, 06:04 PM
Looking like it's coming together nicely...
and PS- Thanks for re-arranging the spacing between or reducing the size of the pics (whoever did it?). Makes the thread SO much easier to read and view!
  #90
Old 07-13-2010, 06:26 PM
webfoot's Avatar
Must've been a mod.
I appreciate the comments, this has really been an experience!
-Jeremy
  #91
Old 07-13-2010, 09:53 PM
6869GTO's Avatar
6869GTO 6869GTO is offline
Great to see body back on. Looking forward to more pics. Love the balance weights.
Leo
  #92
Old 12-28-2010, 09:08 PM
webfoot's Avatar
Got the motor fired, still have some time before its broken in fully and have a buddy over to adjust the timing. Here is a short vid....
http://s102.photobucket.com/albums/m...t=MAH00027.mp4
-Jeremy
  #93
Old 12-28-2010, 10:54 PM
webfoot's Avatar
Post-breakin update time. Have one loose rocker (you can hear it in the vid initially) and one small oil leak from the front of the motor. Cant tell where that is coming from yet. NO rear main oil leak so I'm glad to see I did that right. Used the graphite rope seal. I did it in 3 or 4 sessions since I was doing it by myself and shutoff when the temp started to climb. Upon the final leg the oil pressure needle decided to leave this world. I hope that is not going to be a pricey fix. Noticed on the final leg everything must've started to be happy with their new home cuz the temp remained pretty stable. I flogged on it pretty good and I have to say (with the exception of the loose rocker) it sounds pretty badass thru the RA manifolds.
-Jeremy
  #94
Old 12-29-2010, 10:07 AM
goatman-68's Avatar
Hey Jeremy, congrats on your startup. I listened to your video and didn't exactly hear the lifter noise but did notice that the ignition timing sounds very retarded. That could also be partially responsible for elevated water temp. Did you set the timing or just ballpark it??
  #95
Old 12-29-2010, 12:52 PM
webfoot's Avatar
Since it was just me I had to run it at whatever it would run at since it wont idle. (due to the timing ) I agree the timing is probably retarded. I had the distributor all the way advanced for it to run. Need to pop the distributor out and move it over a tooth I think.
-Jeremy
  #96
Old 12-29-2010, 02:26 PM
Shouldn't have to pull it out to adjust the timing...unless your distributor is bumping up against something and you physically can't get it to move any further?
Old 12-29-2010, 02:32 PM
webfoot's Avatar
Yep, the vac advance can is bumping into the head.
-Jeremy
  #98
Old 12-29-2010, 06:18 PM
Ah, yes.. a pull and reposition should do it.
Old 12-30-2010, 06:49 PM
webfoot's Avatar
Well, it turns out the "loose rocker" noise was due to some intake bolts backing off and exhaust leaking thru the crossover. Got the timing closer to the range and sounds MUCH better now. I'm pretty stoked! Now to replace a radiator in my pickup....
http://s102.photobucket.com/albums/m...t=MAH00028.mp4
Not sure if I mentioned previously but this is my first complete motor build.
-Jeremy
  #100
Old 12-30-2010, 07:32 PM
I noticed that looks like a Chevy carb?
