Old 12-16-2019, 10:58 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Default Date codes under hood.
Delco-Remy products “did not” use the letter “I” in their date codes.
Carter was the same, no “I” in their date codes.
The letter “I” was used in date codes on all other components.
Engine Block (I 14 4) = Sept. 14, 1964
Intake Manifold (I 15 4) = Sept. 15, 1964
LH Cylinder Head (I 11 4) = Sept. 11, 1964
RH Cylinder Head (I 17 4) = Sept. 17, 1964
ID:	526895   Click image for larger version
ID:	526896   Click image for larger version
ID:	526897   Click image for larger version
ID:	526898   Click image for larger version
  #82
Old 12-16-2019, 11:06 PM
60sstuff's Avatar
Air Cleaner base stencil and OEM filter screen.
Carter AFB tag 3896S (J4) = Sept. 1964
Early 65 aluminum fuel line (four bends only).
Transmission kick down switch.
Little Fuse switch, dated (9-4) = Sept. 1964
ID:	526900   Click image for larger version
ID:	526901   Click image for larger version
ID:	526902   Click image for larger version
ID:	526903   Click image for larger version
  #83
Old 12-17-2019, 11:19 AM
dld's Avatar
dld dld is offline
You may find this interesting . My Baltimore 12 C car with a build date of 12/19/64 has the same dates codes on engine and heads L/11/4
ID:	526926   Click image for larger version
ID:	526927   Click image for larger version
The Following User Says Thank You to dld For This Useful Post:
  #84
Old 12-17-2019, 11:33 AM
gto19's Avatar
gto19 gto19 is offline
Who did you have rebuild your master cylinder?
Also can we your 66? I hear it’s amazing!
  #85
Old 12-17-2019, 03:13 PM
dld's Avatar
dld dld is offline
Angry
misread your date code
  #86
Old 12-17-2019, 03:46 PM
Sloan66's Avatar
Sloan66 Sloan66 is offline
Thanks Chris, great detail. Amazing how Gunk works but leaves remnants of the OK 5 stamp. Did you re-gasket much? Wish I would have been forward thinking like you and kept hoses and other items we all just ignored back in the day. again thanks for taking the time to do this, very helpful.
Was the headliner color an optional selection or was that standard for this color combo?
The Following User Says Thank You to Sloan66 For This Useful Post:
  #87
Old 12-18-2019, 12:51 AM
Way cool car.
The Following User Says Thank You to eaglesan13 For This Useful Post:
  #88
Old 12-18-2019, 01:22 AM
60sstuff's Avatar
Kevin,
I was happy to still be able to see the Black OK-5 stamp on the cyl. head.
If I found a soft OEM heater hose in a wrecking yard, I’d pull it. It paid off 40 years later.
Gaskets were replaced on the valve covers. Previous Owner/Mechanic switched the covers around, plus I wanted to see how clean it was inside. Just fresh oil everywhere.
I replaced the gasket on the rebuilt Original water pump also.
The Med. Slate headliner only came with the Black interior.
Thanks, Chris.
ID:	526990   Click image for larger version
  #89
Old 12-19-2019, 09:11 PM
60sstuff's Avatar
Default In a Rush ......
I’m not sure how this task was done at the Assembly Plant.
Probably a type of cover was laid over the chrome valve covers, then the engine paint was sprayed on.
The starter wire clip on 65-67 would be in place when the valve cover bolt was installed, and likewise for the oil dip stick tube.
Typically you will see some excess paint on the chrome in these areas, but I’ve never seen one this bad.
You can see how the paint ran down the backside of the clip.
Chris.
ID:	527117   Click image for larger version
ID:	527118   Click image for larger version
ID:	527119   Click image for larger version
ID:	527120   Click image for larger version
  #90
Old 12-22-2019, 04:55 PM
60sstuff's Avatar
Default BRACKET, Heater Water Hose.
My records show in 1965 the “plated” bracket that supports the long heater hose on “non-air condition cars” as shown in post 72 was about a half year style.
Seems about (Dec. 64 - Jan. 65) in most plants the change was made from the plated bracket to the black painted bracket. Obviously a cheaper design.
My plated bracket shows several places of blue engine paint on the backside where it was pressed against the cylinder head.
Chris.
ID:	527271   Click image for larger version
ID:	527272   Click image for larger version
ID:	527273   Click image for larger version
ID:	527274   Click image for larger version
  #91
Old 12-22-2019, 06:19 PM
bill ryder's Avatar
bill ryder bill ryder is online now
Hi Chris Why do you believe the attaching bolt head is painted engine color? Removed and reinstalled with the bracket???????
"Bill"!
  #92
Old 12-22-2019, 06:55 PM
60sstuff's Avatar
"Bill"!
Bill,
With this car, yes (r and r).
You couldn’t see this bolt, or the blue paint on the front of the engine when I received the car.
The degrease process with Gunk revealed the OK-5 along with that blue bolt.
  #93
Old 12-27-2019, 11:02 PM
bill ryder's Avatar
Hi Chris.. Would you mind showing some good trunk pictures? Especially where the spatter paint starts and stops towards the rear area and behind the back seat area.
THANK YOU SIR!!!!!
bill
  #94
Old 12-29-2019, 06:11 PM
60sstuff's Avatar
Default Trunk, spatter paint
Hi Bill,
Hope these photos are helpful.
The spatter paint wasn’t a precise application as seen in this Baltimore built car.
It looks pretty nice for the most part, but I’m not sure what was done at the (rear end panel, both braces and the strike anchor)?
These areas were painted with a brush in a dark gray color.
Extremely sloppy job and I’m not sure of its purpose??
Chris.
ID:	527695   Click image for larger version
ID:	527696   Click image for larger version
ID:	527697   Click image for larger version
ID:	527698   Click image for larger version
  #95
Old 12-29-2019, 06:16 PM
60sstuff's Avatar
Default More
Gray paint seemed to be applied above the spatter in these areas.
ID:	527700   Click image for larger version
ID:	527701   Click image for larger version
ID:	527702   Click image for larger version
ID:	527703   Click image for larger version
  #96
Old 12-29-2019, 06:19 PM
60sstuff's Avatar
Default Spatter On.
Some messy areas.
ID:	527705   Click image for larger version
ID:	527706   Click image for larger version
ID:	527707   Click image for larger version
ID:	527711   Click image for larger version
  #97
Old 12-29-2019, 06:28 PM
60sstuff's Avatar
Default Last
You can see where some of the spatter went onto the exterior painted lip above antenna.
ID:	527713   Click image for larger version
ID:	527714   Click image for larger version
ID:	527715   Click image for larger version
  #98
Old 12-31-2019, 04:46 PM
60sstuff's Avatar
Default HIGH FIDELITY
GTO quality sound system, LOL.
I’m too damn old for crawling around in a trunk compartment!
So, I pulled the rear seat speaker cover off the magnet to see the part number and date code.
It’s the same date as the front speaker, 40th week of 1964.
Happy New Year everyone.
Chris.
ID:	527898   Click image for larger version
ID:	527899   Click image for larger version
ID:	527900   Click image for larger version
ID:	527901   Click image for larger version
