Old 04-14-2016, 06:15 PM
67'7F6'Bird's Avatar
67'7F6'Bird 67'7F6'Bird is online now
Originally Posted by mike leech View Post
Mono leaf looks like the weak link. Otherwise solid set up.
These are the Springs.
https://www.calvertracing.com/splitmono-leaf.html
Steve
  #82
Old 04-17-2016, 12:33 PM
69FIREBIRD76MM's Avatar
Default rear end 9"
On that 9" rear did you go with the chevy ends or new torino style ends? Also did you buy the third member at Strange or just housing and axles? The reason I am asking cause I want buy strange housing and axles for my 69 bird. But I herd the axles are cut differently than everybody else and they only fit their posi units, is this true? Sorry for so many questions.
  #83
Old 04-17-2016, 04:10 PM
This was complete from strange, minus brakes. Ford big bearings, gm bolt pattern for wheel studs. You will have to call strange for more axle info.
  #84
Old 04-17-2016, 08:15 PM
73 TRANSAM 73 TRANSAM is offline
I have two sets of Strange axles. They are both for Dana 60, 35 spline and 40 spline. The only one different is the 40 spline axles. I know MW has a two style and you will need to let them know your setup.
  #85
Old 04-20-2016, 12:23 PM
Headers are under construction.
http://maddogheaders.net/products/pontiac
  #86
Old 04-20-2016, 05:59 PM
Header Pipes will be 2.25" with 4.00" Collectors.
  #87
Old 05-05-2016, 06:40 PM
Camshaft has been Delivered. Just waiting on the Connecting Rods which are in transit.
  #88
Old 05-05-2016, 10:16 PM
We are going Dry Deck.
  #89
Old 05-10-2016, 09:51 PM
BME Aluminum Rods Delivered.
  #90
Old 05-14-2016, 07:42 PM
Don is doing some initial Mock up.
ID:	428427   Click image for larger version
ID:	428428   Click image for larger version
ID:	428429   Click image for larger version
ID:	428430   Click image for larger version
  #91
Old 05-15-2016, 02:35 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Looks good... except for the two missing counterweights...
  #92
Old 05-16-2016, 10:12 AM
dci dci is offline
I wish they would make a forged crank with them. Unfortunately whoever designed and helped with them didn't have the foresight.
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
Designer if the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!!
  #93
Old 05-16-2016, 10:14 AM
dci dci is offline
Steve is going to have really nice street engine when we are done. I have used BME rods in several street builds through the years and some of my customers have close to 50,000 street miles on them. Very nice durable pieces for sure.
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #94
Old 06-17-2016, 11:31 AM
dci dci is offline
Making some more progress on Steve Pages DCI RA5 build. We have the short block assembled and ready for the heads as soon as I get them finished. Then we are ready for initial start up. Trying real hard to get this thing done or Steve by the end of the month. That way he has some time to get it i n the car and get it ready for Norwalk.
ID:	430987   Click image for larger version
ID:	430988   Click image for larger version
ID:	430989   Click image for larger version
ID:	430990   Click image for larger version
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #95
Old 06-17-2016, 11:32 AM
dci dci is offline
Some more pic's !!!!!
ID:	430993   Click image for larger version
ID:	430994   Click image for larger version
ID:	430995   Click image for larger version
ID:	430996   Click image for larger version
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #96
Old 06-17-2016, 11:34 AM
dci dci is offline
A few more!!!!
ID:	430998   Click image for larger version
ID:	430999   Click image for larger version
ID:	431000   Click image for larger version
ID:	431001   Click image for larger version
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #97
Old 07-05-2016, 03:13 PM
dci dci is offline
Steve's headers came in today and they look Awesome !!!!! We built the master for these so we knew that they would fit with minimal hassle and cussing LOL. These are 2 1/4" primary with a 4" collector. We can do them in any tube size up to 2 1/4". We went with 2 1/4" for Steve's engine because he is going to blow it eventually. Notice we notched all of the bottom bolt holes in the flanges so they can all be put in before sliding the header on.
ID:	432116   Click image for larger version
ID:	432117   Click image for larger version
ID:	432118   Click image for larger version
ID:	432119   Click image for larger version
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
  #98
Old 07-28-2016, 12:07 PM
Hi Don,
Are the Lower Header Tubes in line with the bottom of the Oil Pan or do the tubes sit below the oil pan? Any Pictures would be Great!!!
Thank you,
Steve
  #99
Old 07-28-2016, 01:09 PM
Mike Davis's Avatar
Don, will there be headers available for the 64-67 A body?
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
  #100
Old 07-28-2016, 01:52 PM
GTOGEORGE's Avatar
Hey Don...........how about Zoomies for a BAD ASS 1974 GTO tube chassis Blower car?
GTO George
