Old 06-20-2015, 11:02 PM
blubomber's Avatar
blubomber blubomber is offline
I think '67 or '68 was the last year for the cone shaped lens. It was mounted on top of the inner fender on the passenger side. In '69 the lens was the one used on the reel out trunk lights. Some of those lens seem to have some red paint residue on them but not to the extent that the cone shaped lens did where you can see that they were half red and half clear. The mounting bracket was moved up front to the radiator support as well. I don't know what the last year for the reel out lights was.
'69 Bonneville convertible
Warwick blue/ parchment interior
53 option accessories
2 more to go :-)
  #82
Old 06-21-2015, 11:05 AM
Jeff Hamlin's Avatar
Don't know if this is bases for a conclusive use in '69 but the accessories cat does show a coned shape service/reel-out light.
And I do agree this was the last year for the lights, as I have never found any in a 70+
  #83
Old 06-21-2015, 11:28 AM
blubomber's Avatar
Jeff, good catch on the Catalog picture. I never noticed that before. I have never seen a cone shaped lens on a '69 so I just assumed they were not used.
Any info on the red paint. I have seen and had several puck style lens that had the remnants of red paint on them but not like the half and half arrangement on the cone shaped lens.
BTW...PM me about where you are in VA Beach. I am up the road in Fredericksburg VA
2 more to go :-)
  #84
Old 06-22-2015, 12:16 PM
blubomber's Avatar
Default Brougham emblem
Desert Valley Auto just north of Phoenix ghs a '69 4 dr Bonneville Brougham with the sail panel Brougham emblems still on it. They may be the same as those in '67.
2 more to go :-)
  #85
Old 06-22-2015, 01:48 PM
67GP428's Avatar
67GP428 67GP428 is offline
Thanks. I called them already. They might have them? Have to email the picture/size. At $45 ea.
  #86
Old 06-22-2015, 02:24 PM
blubomber's Avatar
I can't attach the picture from their web site for some reason.
On page 2 of the 1969 Pontiac's are two pictures of the car. It is a sun faded red 4dr.
Inventory #69PO0996D
2 more to go :-)
  #87
Old 06-22-2015, 07:03 PM
67GP428's Avatar
Here's some pictures of my '67 hockey puck style reel out light. There is red on only half of it? I know '67 light brackets on had 2 mounting points. '66 and older had 4 mounting holes. I cleaned it up, with new red paint and installed it in my '67 GP for now. There was holes already in the fender well. Maybe at on time it had one installed on it???
Name:	67 UH LT3.jpg
ID:	401149   Click image for larger version
Name:	67 UH LT2.jpg
ID:	401150   Click image for larger version
Name:	67 UH LT.jpg
  #88
Old 06-22-2015, 07:07 PM
devauxmidwest's Avatar
devauxmidwest devauxmidwest is offline
How does the light turn off and on?
  #89
Old 06-22-2015, 07:24 PM
67GP428's Avatar
There's a little switch than is mounted on a bracket on the pass. side if the firewall. Then from there, gets it's power from the fuse block.
  #90
Old 06-22-2015, 08:11 PM
Thanks.
  #91
Old 06-22-2015, 08:14 PM
67GP428's Avatar
Welcome. Let me know if you want a picture of the switch/bracket.
  #92
Old 06-22-2015, 08:21 PM
Please, that would be great.
  #93
Old 06-22-2015, 08:22 PM
blubomber's Avatar
there are dimples on the firewall where the holes are drilled for the light switch bracket.
GP428, did you see the '68 Bonneville Brougham 2 dr couple loaded with options like your '67 located near? you on E-bay
2 more to go :-)
  #94
Old 06-22-2015, 08:23 PM
Did you paint the metal part of the lamp? It looks new.
  #95
Old 06-23-2015, 05:40 AM
FWIW;
Here is an NOS SW underhood kit.
Unfortunately don't have copies of the installation sheet.
  #96
Old 06-23-2015, 07:34 AM
blubomber's Avatar
In the service manual there will be a diagram that shows how the wiring is routed and where the wire retainer clips go along the inside of the fender.
Thanks for the pictures. I never realized that the red paint on the lens was only on the side. I just figured that the paint on the top of the lens had worn off over the years.
2 more to go :-)
  #97
Old 06-23-2015, 10:29 AM
Originally Posted by Jeff Hamlin View Post
FWIW;
That switch set up looks like unobtainium. Any interest in selling it?
Old 06-23-2015, 10:46 AM
blubomber's Avatar
the actual switch can be obtained from a GM dealership. The wiring is easy as well. The hardest part to find is the switch bracket but they are out there in junk yards. Same part was used in many GM cars.
2 more to go :-)
  #99
Old 06-23-2015, 11:24 AM
David Brown's Avatar
David Brown David Brown is offline
Send a message via ICQ to David Brown
Is there a difference between the under hood light switch and the brake light switch that is activated when you push the brake pedal? They sure look similar.
  #100
Old 06-23-2015, 12:11 PM
blubomber's Avatar
I doubt it. It was just a simple switch that was common to GM cars. The only thing you have to do is get the switch height correct in the bracket so that the light turns off when the hood is closed. That is what the height adjustment locking nuts are for.
2 more to go :-)
