#81
Had them both setup like that, one for many years, Just recently switched both to EFI and all that was needed was a spring change in the regulator. |
#82
Mchell, my 340 Tanks pump is very quiet, I can barely hear it with the key on/engine off. My Holley Black was a great pump but very loud and I personally feel it is better suited for a racecar with either a fuel cell or sumped tank & not a stock tank like I had. Your car must be pretty loud not to hear it. I didn't want cutouts since I prefer it quiet as possible without a power loss. Track is US 13 Dragway in Delmar, De.
Slowbird, there is no sending unit. The pump has I think 1/4 NPT in/out and is in the tank. Very good system, I'm using a Weldon regulator and 8an supply and return lines
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' Last edited by OCMDGTO; 09-24-2020 at 08:47 PM. |
#84
Actually, I’ve been told my car is very quiet...until it’s wot... I did spend some time experimenting with line and pump mounting along with sound dampening...seemed to work. Not silent by any stretch but not noticeable when running. No sump or cell. Sucking directly out of the tank. The worst possible scenario. How was the weather when you were out?....makes a difference ...
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile |
#86
Weather was high 60s/low humidity and lots of those runs were 85/humid. You car is killing it, really nice combo
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
