#81
Five More
Tim Corcoran |
The Following 2 Users Say Thank You to Tim Corcoran For This Useful Post: | ||
#82
Five More
Tim Corcoran |
#83
Last 3
When I showed the IH the .953 is my eheads the .976 is the speedmaster the .918 is the speedmaster with a .055 spring locater You will notice in some of the pictures I am showing my older style combustion chamber eheads compared to the streetmaster heads
Tim Corcoran |
#84
Heads look good and you can't beat the price. I wanted to get a pair of the assembled non-CNC ported HR heads since the assembled weren't much more than bare heads. I don't need them so I didn't get them, but I will get them in the future if I have a need.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
#85
Unless something has changed 1.65 will work out the box. 1.5 will need work to fit
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
The Following User Says Thank You to chiefbigb For This Useful Post: | ||
#86
Mine came in yesterday as well. I'm going to try to pull the 463 out of my 78 T/A next week (weather pending), I'll match them up and do some comparison pictures with my KRE D-ports once those heads are off.
Johnny US Army Retired 1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph 1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car. 1980 Formula 350 Pontiac back burner project 1972 LeMans 350 Pontiac |
The Following User Says Thank You to Johnny406 For This Useful Post: | ||
#87
HUH?
Tim Corcoran |
#88
i think chiefbigbmight have got the ratios confused as to what fits
http://performerrpm.myphotoalbum.com/view_album.php? |
#89
I recently installed a set on a 406. 1.5 ratio rockers have the pushrod up against the intake side of the hole. A 1.6 rocket centered it in the hole.
#90
Mock up pics
#91
Moved the holes towards the intake side about where the valve cover rail is and had plenty of room.
#92
Thanks for the clarification that is good info. It's the opposite of what we see on iron heads and E-heads that's why I was confused. You wouldn't have a photo of the rework would you? Curious how big and how far down I will need to go.
Tim Corcoran |
#93
Best I can do. Looking at the hole next to the pushrods you can see a bit. Moved the entire hole that direction top to bottom
#94
Does anyone know what the valve spring open/closed pressure is on the SM HR heads?
#95
Here's what mine looked like when it had 1.5s. Fortunately only used them for break in then switched to 1.65s.
#96
See post 66.
Illinois Outlaw Gassers 6.27@107 9.97@131 |
The Following User Says Thank You to Bill Eveland For This Useful Post: | ||
#97
The heads I received the holes for the rocker studs were not deep enough to install the studs all the way. I will have to cut an 1/8" inch off the studs to get them fully seated. Has anyone else had this problem? Has anyone cc's these to see if they are actually 78 cc's?
Tim Corcoran |
#98
Murf |
#99
I had old studs and guideplates from my E heads when I switched to a shaft and they fit fine even before the tabs were popped off. But the first one before I popped tabs off felt a little "tight" at the bottom.
#100
Used a hack saw and cut mine a bit.
