Old 11-25-2021, 05:58 AM
dhutton dhutton is offline
Lucerne Blue is metallic.
Spot blast any lingering rust.
Don
  #82
Old 11-25-2021, 07:14 AM
Skidmark's Avatar
Skidmark Skidmark is offline
Thanks Roger1 heading to your build thread now.
Dsutton, thanks I' be been wanting a small blaster.
  #83
Old 11-25-2021, 09:13 AM
Spot blaster something like this for small spots.
https://www.ebay.com/itm/23393412001...0AAOSwmXJgDofT
One other note. Wire wheels will burnish the metal and lead to poor paint adhesion. Always sand those area to give a tooth after wire wheeling.
Don
  #84
Old 11-25-2021, 10:17 AM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
You got this! I did my Firebird myself. I recommend taking all trim off, as much as you can so you dont tape around anything. I removed the hood and deck lid, painted the bottoms of them, then reinstalled to paint the car. All 4 corners on jack stands with tires removed.
And test paint something else first to get the spray pattern down before you hit the car with paint.
  #85
Old 11-25-2021, 11:17 AM
400 4spd.'s Avatar
Don
Fiber stripping wheels and Roloc style Bristle Discs will have the same effect. We always follow with 80 on a DA before anything else goes on the surface.
The Following User Says Thank You to 400 4spd. For This Useful Post:
  #86
Old 11-25-2021, 12:01 PM
unruhjonny's Avatar
if you're into watching videos to learn from others, there's a kid who restored his Fiero;
I would think that the specifiec videos pertaining to how he painted, and showing what he did wrong would really help.
Fiero restoration
Congrats to you for deciding to do this yourself - I will probably be doing the same... unless I can find someone willing to paint at a rate lower than insurance repairs - which is highly unlikely.
1970 Formula 400
  #87
Old 11-25-2021, 12:44 PM
Skidmark's Avatar
Thanks for all the tips.
Whenever I get a tip from one of you, I write it down. I'll refer back to them when I'm at that point of the process.
I had no idea that the wire wheels might somehow affect the adhesive qualities of the primer.
When and where possible I'll hit it with the 80 grit afterwards.
Definitely investing in a blaster.
  #88
Old 11-25-2021, 01:06 PM
roger1's Avatar
roger1 roger1 is offline
Blasting also leaves a good texture for epoxy primer. No need to sand that. Just make sure all the metal is cleaned. SPI waterborne W&G remover is what you want to use.
'69 GTO Convertible - Acquired October 2020. An all original project car. Restomod is underway PROJECT THREAD
'83 Chevy Choo Choo SS El Camino - LT1 350/4L60e, Owned for 30 Years, completed 2nd restomod in 2018 PHOTO
2019 BMW 440ix - Twin turbo I6, 8spd auto. PHOTO
'55 Chevy Bel Air Sport Coupe - Ram Jet 350 / T56 Magnum 6spd, Restomod Completed Sept. 2012, Sold Sept. 2021 PHOTO
  #89
Old 11-25-2021, 01:15 PM
Two more items of interest. When checking your body work. Don't use your bare hand. Use something like a piece of bedsheet as a buffer with your hand. It'll identify low spots easier.
Also, don't be afraid to spray metallic. It may be a bit tougher, but very doable for a newbie. I know. The biggest thing I found, was keeping the paint particles suspended by swirling/shaking the paint gun every so often to keep the heavier particles suspended. Mixing well before pouring into paint gun important here.
  #90
Old 11-27-2021, 12:38 PM
MUSLCAH MUSLCAH is offline
Paint tip #101….when you have a NEW mix of paint…and your opening it for the FIRST TIME…whether it’s a pint ,quart or Gallon…ALWAYS empty the unreduced paint into another another container….and put a splash of your reducer in the bottom of the can and stir well to get every trace of color off the bottom of the can…and dump that into your unreduced paint and stir well. You may have to do a few splashes ..to get it all. Then you can reduce your paint . This process assures you…that every tiny tint that made up your formula ..is now in your color and not stuck on the bottom of the can.
The Following 5 Users Say Thank You to MUSLCAH For This Useful Post:
  #91
Old 11-27-2021, 08:13 PM
Skidmark's Avatar
Totally makes sense. Great tip. Thanks!
  #92
Old 10-27-2022, 10:07 AM
Skidmark's Avatar
Default Update
So it's been a year since I started this thread. Currently building the garage where I will paint my car. I was able to buy all materials for garage for the same price I was quoted for someone else to paint it. (20k).
I am building the garage myself so finish date will be late winter 2023.
I'll start prepping the car for paint early spring.
ID:	601186   Click image for larger version
ID:	601187   Click image for larger version
ID:	601188   Click image for larger version
The Following 2 Users Say Thank You to Skidmark For This Useful Post:
  #93
Old 10-27-2022, 11:21 AM
roger1's Avatar
VERY NICE!
Beautiful property too.
Do you have a nice air compressor already? Put in large wires for where you are going to put it in case you upgrade later.
  #94
Old 10-27-2022, 02:05 PM
dataway's Avatar
dataway dataway is offline
Wonderful ... so much fun building things. You are gonna love it when it's done.
  #95
Old 10-27-2022, 03:54 PM
Skidmark's Avatar
Thanks guys.
Yeah Roger, I'm looking at a 60 gallon Ingersoll 230v. I have a bunch of 6 gauge I had left over on a hot tub I wired, I thought I might use that to wire it. I'm installing a 100 amp breaker box.
I framed the garage like the booth you have in your "gas station" (2 windows in back for fans and I'll make a frame for filters on lower half of garage door opening.)
I will use your thread on your GTO restoration as my guide for the painting process. No sense in reinventing the wheel. Lol.
The Following User Says Thank You to Skidmark For This Useful Post:
  #96
Old 10-27-2022, 04:06 PM
Good for you. Rather than pay someone to paint, you get a free garage! Nice tradeoff.
The Following User Says Thank You to tjs72lemans For This Useful Post:
  #97
Old 10-28-2022, 01:20 AM
dataway's Avatar
Yep, compared to paying someone for paint you'll probably end up with an almost free garage. Which also adds to your property value ... so better than free.
  #98
Old 10-28-2022, 06:30 AM
rtanner's Avatar
rtanner rtanner is offline
Originally Posted by Skidmark View Post
here are a few more
Learn how to buff and leave it alone
  #99
Old 11-14-2022, 09:30 AM
Skidmark's Avatar
First time out of the weather since 2014. Finally. Car covers caused more damage, all though minor, than the previous 40 + years combined. I think I actually slept better last night knowing my car has a roof over it again.
ID:	602147   Click image for larger version
  #100
Old 11-14-2022, 01:27 PM
dataway's Avatar
Very nice! Home at last.
Border Collie? Did he just help you build or did he draw up the prints
