Old 12-21-2014, 01:02 AM
67'7F6'Bird's Avatar
The 1000th Post needed to be Very Important!!!!
http://www.dcimotorsports.com/produc...ir-five-heads/
See attached.
  #1002
Old 12-21-2014, 10:08 AM
455firebird1969's Avatar
Little more work left todo on the front end in order to drop the oil pan without pulling the engine.
I'm curious, as to why you used the OEM subframe on this build. When I see the amount of custom fabrication going into this car, that subframe seems like a lot of extra weight you could have eliminated. The fab work looks very nice, like the shop doing the work could have built it any way you wanted. It's going to be a bad machine regardless, 2015 is going to be a good year for Pontiac performance!
  #1003
Old 12-21-2014, 01:06 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Thanks for the kudos.
As with most projects like this one, they end up evolving over time due to various reasons, in hindsight maybe the subframe should have been replaced.
We’ve got a few more changes to make which will help with maintenance and shed some weight.
The major step in evolution for 2015 is swapping out the entire McCarty top end and stepping up to DCI Motorsports RA-V’s.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1004
Old 12-24-2014, 10:39 AM
RAIV-Z's Avatar
Axels arrived Monday, rear end just about complete.
Merry Christmas to all!
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1005
Old 12-24-2014, 10:53 AM
Best of luck with this. You have made some tough decisions. Looking forward to seeing this completed and you being able to enjoy it. Looks like 2015 should be a good year for you. I think this car is awesome. Lots of nice in this project despite the setbacks!
Bruce
  #1006
Old 12-25-2014, 01:47 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Extremely rigid-looking housing. Is that your own design, or something that's on the market?
  #1007
Old 12-25-2014, 11:49 PM
RAIV-Z's Avatar
It’s a Mike Hall “Hall’s Custom Race Cars” designed Ford 9.5 housing.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1008
Old 12-31-2014, 11:45 AM
RAIV-Z's Avatar
Got the 69 bird front end pieces cleaned up. Any guesstimates on how much weight can be saved by drilling holes?
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1009
Old 12-31-2014, 12:37 PM
LiL Jack's Avatar
LiL Jack LiL Jack is offline
Not sure about how much weight can be saved but it will make it look like chit.
First Pontiac powered street car in the 7's
7.940@170.84. 3460#s
  #1010
Old 12-31-2014, 12:50 PM
wreckmastr's Avatar
Not much!! It's not worth the time and effort. Not to mention it will look like Sh*t IMO
ET/mph talks, bullchit walks.
6.98 @ 199mph
4.53 @ 164mph
  #1011
Old 12-31-2014, 01:22 PM
Elarson's Avatar
Elarson Elarson is offline
For example:
a 1" dia hole in .090" steel (a guess) would save .02 lbs so (100) of them would get you 2 lbs savings. That should answer the question.
Eric
  #1012
Old 12-31-2014, 01:28 PM
Tom Vaught's Avatar
Boost Engineer
The other thing is EVERYTIME you drill a hole you should deburr the hole and remove sharp edges in the hole to reduce a stress riser crack from happening. So it could be very labor intensive to do it right.
If you were building a frame from scratch (and I know a couple of guys who have), they water-jetted each part (no stress riser issues) and welded the pieces together. This was for a Cobra Kit Car deal.
Not worth the bang for the buck and can cause other major issues.
Tom V.
  #1013
Old 12-31-2014, 02:58 PM
cosgrove cosgrove is offline
The 69 has a many more steel parts in the front nose assembly than you show in the picture. I altered every piece with a plasma cutter. Save every bolt hole but cut out large holes in the areas in between. The front end will bolt back together just fine. It will be rigid and light. Just don't run into anything. I weighed the pieces that were cut out. Twenty five pounds worth. Cleaning up the edges and using 1/4 inch bolts saved another ten pounds. This was a lot of work but some of the most economical weight savings on the entire car. I did this eight years ago and have made hundreds of passes with no issues. An aluminum filler between the radiator and nose hides it all.
69 Firebird, 536, Wideports, Cal Tracs, 275 radials, 3200#, a little spray 7.75 @ 173, 4.92 @ 142
  #1014
Old 12-31-2014, 04:39 PM
RAIV-Z's Avatar
Cosgrove,
You're right, the picture was missing a few items which are included in the pile below.
Piled up most of the steel parts, screws and bolts that make up the front bumper assembly and the weight came in at ~53lbs. The scale doesn't work below 25lbs so I can't weigh individual pieces today.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1015
Old 12-31-2014, 05:09 PM
Great info, thanks for sharing the technic you used to shave weight off of the multiple parts that make the front end on a 1969 Firebird. One option I'm toying with is removing the nose as an assembly, sealing it in a bag under vacuum and making a mold with fiberglass. My goal is to make a lightweight nose that will bolt to the fenders.
That pile of OEM parts is heavy compared to your whittled-down assemly.
  #1016
Old 01-10-2015, 05:48 PM
RAIV-Z's Avatar
If you come up with something that's light weight that will bolt up, send me a PM. I'm interested. Will need to support lights and directional being a street car in all In the meantime I'm moving ahead with unmodified factory steel parts.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1017
Old 01-10-2015, 08:25 PM
ponjohn's Avatar
ponjohn ponjohn is offline
There is a chassis shop that offers a round bar radiator support.
  #1018
Old 01-10-2015, 11:05 PM
RAIV-Z's Avatar
Got any pics, price, etc...
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
  #1019
Old 01-10-2015, 11:13 PM
ponjohn's Avatar
Ron Rhodes builds them 300.00 according to his post on YB.
Here is the thread... http://www.yellowbullet.com/forum/sh...support&page=4
  #1020
Old 01-30-2015, 11:08 AM
dci dci is offline
Parts are finally starting to come in for your heads Ed. Here are the custom order valves.These are from Victory in North Carolina and look like jewelry. Intakes are stainless 2.28", 11/32" stems, 6.450" long, exhaust are a super alloy 1.68", 11/32" stems, 6.450" long. The custom made exhaust guides should be here any day. I'm hoping today!!!
ID:	388815   Click image for larger version
ID:	388816   Click image for larger version
ID:	388817   Click image for larger version
ID:	388818   Click image for larger version
Don Johnston
DCI MOTORSPORTS LLC
330-850-5050 shop
330-628-3354 cell
Designer if the DCI Tiger Heads and the NEW DCI Ram Air 5 Heads !!!!!
