Old 03-08-2014, 11:51 AM
pugslyx234 pugslyx234 is offline
Thanks Fatguyterry I appreciate the help. Ok I got a little aggravated.
  #102
Old 07-19-2014, 12:24 PM
Default Wife and I painted
We finally did it but I got some issues like tiger strips on lid and runs in my clear.
ID:	370613   Click image for larger version
ID:	370614   Click image for larger version
  #103
Old 07-19-2014, 12:29 PM
Default more pics
More pics and I was hoping to do a better job but it was hot mid 90's and being in a suit and respirator, my glasses were fogged couldnt see *****z all excuses i know but its DONE, now gotta learn how to get the runs outta the clear any help is appreciated.
ID:	370616   Click image for larger version
ID:	370617   Click image for larger version
  #104
Old 07-19-2014, 03:39 PM
1966geeto 1966geeto is offline
Clear you can fix tiger stripping not so much some great tricks to cut and buff out clear just be careful .Looks great making progress.
  #105
Old 07-19-2014, 03:45 PM
Use glazing putty as a leveler so you can watch your edges almost like blocking skim coat it level with the run then wet sand watching the edges until hey are gone then . stage buff works great won't burn through the clear ol body guy showed me it .If the run is real bad use a new razor blade and take it down a notch then wet sand good luck just watch the edges you don't want to be spotting it back in PIA.
  #106
Old 07-21-2014, 12:31 PM
Thanks for the info so take the glazing putty and put it on beside the run above and below it then sand it down with say 800, 1000, 1500 wet?
  #107
Old 07-21-2014, 04:59 PM
Yes if your run is bad more aggressive to start with works great seen it done and used the technique myself..
