#101
Looks like this ends at midnight - midnight, cyber monday, etc.
1114 is shipped - no tax on my order. Pretty crazy. |
#102
Some theoretical Dyno numbers to consider for a street engine (DD2000 so take it with a grain of salt of course). If i install these heads on the W72 i'm planning for my TA, the numbers look pretty good. Rods are stock with ARP bolts, TRW Forged pistons, and Early crank. The cam might be a little small, but I was hoping the nice chambers and aluminum would make it be OK for Detonation. I will need to swap the springs for Flat tappet.
1979 Firebird Trans Am 301/4spd (Now 428) 1977 Firebird Formula 400/Auto 2007 Grand Prix GXP 5.3L |
#103
This poses an interesting question, my intended application for these heads is a 455 with flat top pistons according to the compression calculator on the JBP site a 72cc head on a 455 should come in at around 11.6:1 my thinking is that being aluminum and with careful selection of the cam this should be workable should it not?
A factory D-port intake runner volume is considerably smaller and can get a ported iron port with a runner volume ~170cc has better flow, use a the headers I have and factory bolts. If someone out there is listening offer a efficient cast iron d-port head and you will sell truck-loads but instead we have Pro-Comp Chinese knock-offs of a Edelbrock product that was already available. |
#105
Yes, they work fine even on a heavy street car albeit the combination has to work which is where lots of people fail and start pointing blame. The heavy pig of a car in my signature is a legit 3.75x4.120 400c/i with round port e-heads and a victor intake believe it or not. Still working on going faster too, plus it see's many MANY street miles!
'71 Holden HQ Monaro - 3850lbs race weight, 400c/i - 11.4 @ 120 '66 Pontiac GTO - 389, 4 speed street cruiser |
#106
Physics does not lie and port velocity is an important consideration in head selection on a street driven car. If it's not I'll eat crow and never mention it again. Sometimes this form is more about parts pushing and commerce then it is about information exchange.
#107
So it has the exact same port size as the E-heads but flows better if I am understanding everything? If that is the case, it has better velocity flow than the E-head, no?
Brad Hansen 65 Cat Ventura, 66 Cat Vert, 63 GP |
#108
Start eating because it looks like krisr proved you wrong. 11.4 in a street driven heavy car with a 400 is very impressive. When Pontiac engineers wanted a more powerful 400 they made RA4 heads. They had larger ports and no one complained about velocity. Just because a port is larger and flows more air doesn't mean the velocity suffers. Sometimes its just the opposite. Ive seen flow sheets where E-heads had more flow AND velocity than a stock d-port.
#109
This question comes up from time to time. 215cc intake runners just isn't a ton of port volume, especially for a 400 cubed engine.
We build small block chevys with 220cc heads, as thousands of other people have, and it actually works very well if the rest of the combination of parts are happy together. Look as LS engines since 1997, and how small those engines are. A few years later GM even went to a 260cc square port intake runner on stuff as small as 364 cubes and look how efficient those engines are. They have a very broad power curve. Hell I'm running 315cc intake runners on my 454. 100cc bigger runner on an engine that's only 54 cubes bigger than a 400. It has no trouble at all making torque any where in the rpm range. If it helps answer the other question, starting with a bare set of heads it usually costs me right in the $1,000 range to rebuild. That's new hardened seats, stainless valves, springs, guides, valve job as well as machining for positive seals if the head isn't already equipped to accept it. No porting. |
#110
Fair enough Bruce I have a few good recipes but aren't there just yet.
http://www.superchevy.com/how-to/eng...ons-measuring/ |
#111
Runner cc tells you absolutely nothing about port size. Comparing a Pontiac runner cc to a Chevy runner cc is apples to oranges
#112
I know I don’t understand this very well but, Wouldn’t it be very hard to compare port volumes of different heads? I would think the design, physical size and maybe other factors would make a big difference.
I assume a SBC 220cc port would be bigger than a 215cc Pontiac port if they were equalized for length, is that incorrect? If so, wouldn’t the whole intake tract effect velocity? It’s all very interesting but kinda confusing to my old mind. I have always been a fan of Jim Hand & built a couple engines using his style. I just read Paul Sandoval’s book & found it very interesting. I enjoy trying to understand all this. Thanks Murf Sent from my iPhone using Tapatalk Pro |
#113
Fair enough but what a comparison from a speed master 215cc port to a ported factory d-port heads? I thought the edelbrock heads were patterned after the factory roundports.
#114
Triple Black 1971 GTO |
#115
Port volume from different makes / manufacture is hard to compare. Even from head to head for the same make / manufacture maybe a problem. If you know the port length then you can using the port volume to calculate the average CSA. Using the average CSA and intake flow (CFM) at different lifts you can average port velocity. All of that said, cam it wrong and it still does not work.
Stan
#116
At the end of the day, while Im sure you could 11.5 to one safely under optimum circumstances, your margin of error gets smaller. You better get the cam perfect, timing perfect, and hope you never catch a bad tank of gas. Juice isn't worth the squeeze IMO.
#117
LOL!
#118
.060 over 455 with flat tops. I really would like to try a pair of these heads, but the 72cc kills it.
#119
I can help you boys in that dept if you want to go that route
Carburetor building & modification services Servicing the Pontiac community over 25 years |
#120
If you want to run small chamber heads on a 455 all you have to do it run dished pistons, I've been using small chamber heads on 455s with dished pistons since the 70s. One advantage of small chamber heads is they usually have a little longer short turn radius, said to help flow.
Detroit adjusted compression 2 ways for years, either piston configuration or the changed the combustion chamber size. Fine tuning was done with head gasket thickness, Pontiac factory head gaskets came in different thicknesses according to how high the intended ratio the factory wanted. |
