#101
good eye, held for ransom !!!
#102
alright, i have noticed a mix match of j-nuts or u-nuts on this car...are you guys seeing these two different ones on your 70 cars as well ? The part numbers i came up with is, 1970 - 3784845 1971 - 1494253 (which i presume is the bottom picture)
This style i have noticed to be on 71 and 72 year as well. Last edited by formula400; 06-28-2012 at 03:17 PM. |
#103
My car is full of the above J nut
#104
so far, i'm only noticing those on the radiator core support on this car. The rest so far are of the 71-72 style
I assume your car was built before july ?? Maybe in april ?? |
#105
my 70 Core had the welded "square nuts" on the bottom, the other style pictured was used for the canister return line though
#106
3rd week of July NORWOOD. Those also were used on the front fender to wheelhouse
#107
Yes, they used different types. My understanding is only 70 used the square nuts. after that they went to the rounder, extruded/stamped nuts -- although a few were used in 70. What do your 71s have on them?
#108
The norwood 71 and 72 cars here have the "square" style i did not see any of the hex ones. I looked at a van nuys 71 today and seen a mix match of both styles on that one.
#109
Subscribed
#110
By "square" I meant the clip/U-nut assembly. (actually rectangular)
#111
$285,000... sort of pissed me off. helped the guy, never made a single penny, sourcing him all kind of hard to find NOS parts(some I myself needed badly)... under the assumption this was for his collection.. he got the 1st place at the Nats, giving him the provenance as a good correct car and hit a $285,000 bid.. really pissed me off. It was a VN car as well. If I am not mistaken...there were only 3 VN manual cars made?? I must be wrong, seems like too low.. but some reason that number of 3 is stuck in my head..
#113
None of the "zinc" looking parts were zinc.they were white cadmium..or basic cadmium(cad is silver )..anyway, there are very few shops that plate in real cadmium. To do so, you need a special EPA license, subject yourself to intrusive inspections etc.. If not mandated for aeronautical use, would most likely be banned. ANyway, contact Chris at:
Aero Propellar Broomfield Colorado.. They are quite fair, something like $75 for 12 lbs cleaned.. or for a little more will clean your parts.. If you need any 1970 only parts PM me..I have a ton of NOS and original parts that you will need to do this car correct.. Plus you are welcome to ask any questions..I was the guy who provided all the correct finish,part etc info on the 70 RAIV that won 1st at the Nat's a few years back.. |
#114
Glad you posted these pictures..I have found 2 of these that brackets were gold cadmium as well. The majority were painted..But I have two that without a doubt were gold cad.. Please do this car justice and have the plated parts done with real cad vs zinc..even if the plating shop tells you they are doing cadmium...most are not.. I think there are only 6 or so still licensed to use real cadmium.. Plus, cadmium is a muted silver and gold finish vs the shiney,almost electric finish of silver and gold zinc.. Just looks out of place on 40 yr old cars.. And being a RAIV..odds are will not be redone again.. I really hope you do it with real cadmium.. If you have already done zinc, it removes easily using muratic acid.. eats zinc right off.
#115
Your TCS valve looks newer..I have originals.. Plus I have a couple NOS 1970/71 Fan Shrouds. Noticed yours is broken.. The originals are hard to find, there were2-3 different parts numbers for 1970/71...
#116
There's Mister Bill. We were wondering why you hadn't chimed in yet.
Like F400 I have also found that the gusset bracket nuts were of the round type in 70 -- assembly part #...253 ( shorter version of the '258 used on the inner fender) |
#117
This is great documentation on a great car. Would you mind posting a few more pictures of the stripe details? It's interesting that they may be the original stripes even though a re-paint. I can tell by the 'line' at the radius of the roof stripe that they are original stripes. Repro's like the one's I've recently developed do not have that 'overlay' of the gradient.
http://www.starspangledbannerchallenge.com/ |
#118
Cal emission decal
here is the 70 nos GM emission decal
#119
70 nos Cal. charcoal canister
here is another neat item I picked up when I was in San Diego, still in Rochester box
#120
70 nos
I've had these awhile, the guy I got them from, got them in 78. They are the orig. 70-2 red, not wrong color GM was making later
