Old 12-02-2018, 10:07 AM
Jeffs64Cat Jeffs64Cat is offline
Wow! It looks great.
Thank you Stuart!
Jeff
  #102
Old 12-02-2018, 06:22 PM
tempest1964's Avatar
tempest1964 tempest1964 is online now
Man, I love that red color!!
  #103
Old 12-02-2018, 08:10 PM
Thank you. Yes I’m a fan of red. Picked this color as it matched the interior the closest.
Thecoatingstore.com is where I brought all my paint from the epoxy to the Clear.
Urekem paints.
Jeff
  #104
Old 12-23-2018, 11:48 PM
Set up with new tires and wheels
ID:	500828   Click image for larger version
ID:	500829   Click image for larger version
ID:	500831   Click image for larger version
ID:	500832   Click image for larger version
Jeff
  #105
Old 12-24-2018, 12:04 AM
OZZIEVILLE 67 2 door's Avatar
OZZIEVILLE 67 2 door OZZIEVILLE 67 2 door is offline
Looking real good Jeff
Sent from my SM-T585 using Tapatalk
Old 12-24-2018, 02:39 AM
brut4s's Avatar
brut4s brut4s is offline
Wow!
  #107
Old 12-24-2018, 08:15 AM
67GP428's Avatar
67GP428 67GP428 is offline
Very Nice!!!
1965 Pontiac 2+2 421 HO auto
1967 Pontiac Grand Prix 428 4 speed- sold
1968 Firebird 400 auto - sold
1967 Bonneville Brougham 2 dr. hardtop. 1969 AMC Rebel SST wagon-sold
  #108
Old 12-24-2018, 10:39 AM
MUSLCAH MUSLCAH is offline
Very nice !
  #109
Old 12-30-2018, 02:22 AM
Marv Marv is offline
Bloody awesome
  #110
Old 12-31-2018, 04:35 PM
421mike 421mike is offline
Send a message via Yahoo to 421mike
Default 64 Cat
Your car looks wonderful. Just one question, how is the ride with all the new suspension? Does the new sway bars tend to give it a stage coach ride?
  #111
Old 12-31-2018, 04:43 PM
It rides and handles like a dream. Never rode in a stage coach so wouldn’t what to compare it too. I do know I can hit a curve at 60 and it hugs the road. It’s very responsive.
Jeff
  #112
Old 12-31-2018, 04:49 PM
Default Break in day
Got her out yesterday and put Two hundred miles on her. Drove wonderful. Handling was A1.
ID:	501429   Click image for larger version
ID:	501430   Click image for larger version
ID:	501431   Click image for larger version
ID:	501432   Click image for larger version
Jeff
  #113
Old 12-31-2018, 07:22 PM
Looks great..nice stance too. The only thing I would tweek....would be those tail pipes. Tuck them up. But that’s just me.
  #114
Old 12-31-2018, 09:29 PM
Poncho60 Poncho60 is offline
Very nice ride! Just driving down the road, swaybars shouldn't affect much of anything (on straightaways). On turns different story but basically help to keep the car "flat".
  #115
Old 01-01-2019, 08:47 PM
I think it looks badass! Great stance, awesome Red paint! I know it turns heads going down the road. Enjoy!
  #116
Old 01-02-2019, 11:07 AM
Young Pontiac Guy's Avatar
Young Pontiac Guy Young Pontiac Guy is offline
Cat looks fantastic Jeff!
Joel
  #117
Old 02-15-2019, 08:07 PM
Default Upgrades
Finally got 500 miles on the Cat after all the carburetor problems. The rebuilt Carter 3326s had a flat spot right off idle while cruising down the road in all gears. Had the top off six times in one afternoon. Drove it the final miles to get it broke in and ready for first oil change.
Pull gas tank because of a incorrect read on the sending unit. Brand new unit when installed. While the tank was out I installed a vent and return fitting. Because I’m going efi.
Ran a new 3/8” steel line back to tank for return line. Installed a Tanks Inc. vent/ rollover valve next to filler cap.
Drilled and tapped a 1/2 Npt for temperature sensor for Fitech EFI. Drilled 7/8” hole in Exhaust and welded a weld in O2 bung. Installed a Fuel Command Center 2.0 next to battery ran line through the fender. Wired up a relay for the fuel pump. Installed the Fitech unit and finished all wiring. Primed fuel system and checked for leak. Then setup ecu for my motor and fired it up. Warmed it up to operating temperature and shut it down. Setup IAC Steps and started it again. Ran system in garage. Then took it for my first test after 500 miles oil change was done.
I’m very pleased with this system it woke up the beast in my engine. Ran strong, throttle response is amazing. No jerking or jumping in any gear like when carburetor was on it.
I’ve got over 400 mile on the Fitech Go Efi 4 600 system and wish I had done it sooner.
Jeff
