OHC-6 TECH Over Head Cam projects, questions and advice.
Old 01-08-2022, 01:53 PM
george kujanski's Avatar
That is a really nice setup!
George
  #102
Old 01-08-2022, 04:07 PM
63 bomb's Avatar
63 bomb 63 bomb is offline
Looking really nice so far! I like the Olds gold instead of Pontiac Blue for a color choice... I do have one recommendation for you. I would do the break-in with a carb instead of the Sniper (at least to break in the cam). The tune that the Wizard creates for these engines is not very good and it will take some time to sort it out enough to make it run right. I'm happy to pass along what I have learned with mine, but keep in mind that I am running the Quadrajet version of the Sniper so some of my settings are going to be a lot different than yours.
The Following User Says Thank You to 63 bomb For This Useful Post:
  #103
Old 01-09-2022, 03:14 AM
exotec exotec is offline
Thank you very much, much appreciated!
My brother said the same, that we should consider using a carb for first startup.
So my rebuild Q-Jet will have its pleasure as well
serwas
Karl
follow my project on instagram
  #104
Old 01-09-2022, 11:48 AM
Just curious if you are aware that you have a 1969 upper cam sprocket on your engine? Not an issue if you are aware that the cam timing mark on the 69 sprockets are 180 degrees off from the 66-68 models years. So the cam sprocket timing mark points down for the 69 sprockets. The sprockets are ID'd by the large cast P/N on the front. The other year sprockets don't have it cast like that.
I just noticed that going back over the pictures you posted. I found that out the hard way in the 1970's working on one of my early cars. Had to rotate the dist 180 degress to get it to run.
  #105
Old 01-09-2022, 03:13 PM
Thankx Jeff, I'm aware of this since I posted the same pics in the overhead cammer group forum - Fred was the first to notice it.
Anyhow my brother already mentioned, when all timing marks are aligned #6 does fire - which he thought is unusual. but with that info about the sprocket we did know why.
serwas
Karl
  #106
Old 01-10-2022, 09:11 AM
Your welcome Karl, just making sure you where aware of a possible timing issue.
  #107
Old 01-10-2022, 10:57 PM
amcmike's Avatar
amcmike amcmike is offline
Saw the engine on Holley's FB page, and never thought to look here since it was a swap! Can't wait to see this one finished. Any thoughts about painting the body to match the engine? I think gold would really pop on the Omega, especially with the black vinyl top. Best wishes on the project.
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman
  #108
Old 01-11-2022, 01:23 AM
Yes, was a nice feature for us cammers from Holley on FB and Insta
Body will be 1970 Oldsmobile Aspen Green
serwas
Karl
  #109
Old 01-11-2022, 07:29 AM
all back home and installed the subframe - fits like a glove!
ID:	581725   Click image for larger version
ID:	581726   Click image for larger version
ID:	581727   Click image for larger version
ID:	581728   Click image for larger version
serwas
Karl
The Following User Says Thank You to exotec For This Useful Post:
  #110
Old 01-11-2022, 11:23 AM
63 bomb's Avatar
I see you have the filler tube blocked off. Is that just for the transportation of the engine? It does need to be there to allow air into the crankcase during engine operation.
  #111
Old 01-11-2022, 11:35 AM
I still need to create the mash screen and than my brother did refuse to install it already.
serwas
Karl
  #112
Old 01-11-2022, 01:11 PM
Woe that is a tight bellhousing to firewall fit! Looking good though.
  #113
Old 03-16-2022, 12:31 AM
Little update on the paint job!
ID:	586391   Click image for larger version
ID:	586392   Click image for larger version
ID:	586393   Click image for larger version
serwas
Karl
  #114
Old 03-16-2022, 09:38 PM
gtospieg gtospieg is offline
Looking good!
  #115
Old 03-17-2022, 12:11 AM
mgarblik mgarblik is offline
You are doing such a nice job on this car. It looks great. With that houndstooth interior, it will be a stunner, not to mention the cool OHC engine.
  #116
Old 04-04-2022, 09:16 PM
Francis is back home and now wiring!
ID:	587981   Click image for larger version
serwas
Karl
  #117
Old 04-05-2022, 08:30 PM
jmt455's Avatar
jmt455 jmt455 is offline
Looking great, Karl!
"Keep your stick on the ice...and your head up."
1910 Buick Model 19 Touring
1923 Cadillac 5 passenger coupe
1933 Pontiac 4 door sedan project
1933 Sport Coupe project
1968 GTO, 428, THM400, 2.73 posi cruiser
1969 Chevrolet C10 Fleetside, 350, THM400
1958 Buick Caballero 4dr hdtp wagon
2018 Ram 1500 to tow stuff
2024 Buick Encore GX
  #118
Old 04-06-2022, 06:07 AM
Old Goat 67's Avatar
Beautiful!
Subscribed.
  #119
Old 04-06-2022, 11:16 AM
Looking yery nice!
  #120
Old 04-18-2022, 03:11 AM
let the assembly begin! starting at the rear and working through the car till the front!
serwas
Karl
