Old 02-09-2024, 03:15 PM
Red drums came with Rally wheels in '66 so they've been replaced or just painted by a P.O.
Old 02-09-2024, 03:31 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
If the owner of this ‘66 GTO wants to educate himself on his car I would suggest visiting johnta1 website (post 99) as it is extremely informative on Pontiacs.
I’ve consulted it many times over the years.
Since this motor was pulled for service and painting count the freeze plugs on the lower side of block.
389 has two plugs on each side.
400 has three plugs on each side.
The Following User Says Thank You to 60sstuff For This Useful Post:
  #103
Old 02-09-2024, 08:39 PM
The engine unit number / sequence number 698534 does seem to be in range for a later build in late June.
But its a baby step in authentication process.
The date codes on things like the block, heads, intake, exhaust exhaust manifolds, and brake drums all look like this :
Fake looking slot head screw - then a Letter - then 2 or 3 numbers - then another fake looking slot head screw .
@F 18 6@
Just an example:
F is 6th month = June
18 is the day
6 is the year 1966
You need to locate all of those casting dates and photo document them now while you have the chance.
Dates are cast in raised digits you can feel with your fingers - like brail.
On the block - it is close to the hole that the distributor goes down into.
On heads - it is underneath the area that the valve cover would normally hide from view.
In between the area where you see springs and rocker arms - it is plainly visible
On intake I think it is almost hidden behind/underneath a carburetor
Been a while now since I had a 66 intake in front of me.
Exh manifolds and brake drums - you will see them plainly.
Your distributor should be cast iron , and have a stainless steel band wrapped around its lower neck.
Verify the numbers and letters on the band.
You want to photo document all these things.
This is how you document a car - the papers are only as good as the parts ON the Car.
Paper is paper
We can help with this
Realize the car isn't sitting at your house , but try to get more data and proofing pics each time you go.
Its easier to do now while you have easier access if the engine is out or the wheels are off.
  #104
Old 02-15-2024, 10:52 PM
Tedd930 Tedd930 is offline
Hello sir,
I was able to get this pick of top of the block next to the
Distributor hole. Attaching the photos thank you again for all your knowledge . The e car is still on the lift and I can’t get to the spare yet .. thank you . Looks like I am 2 weeks away from my first drive .
The Following 3 Users Say Thank You to Tedd930 For This Useful Post:
  #105
Old 02-15-2024, 11:14 PM
The
@F 20 6@
Is the casting date code
June 20 1966
Your car body was built June 5th Week , 1966
So that works out nicely.
The engine parts , and everything else , should pre-date the Build Week of the car body.
Get all the date codes you can from your engine components that I mentioned before , when you can.
That is the stuff that potential future buyers will highly appreciate.
It can even help with judging at certain events in certain conditions.
  #106
Old 02-16-2024, 12:29 AM
MUSLCAH MUSLCAH is offline
You’ll get more love with that car....buy leaving it alone. Just buff what’s there....polish the chrome and stainless and interior.
Even some body scars add to the story.
Anyone can have a nice paint job.
Heck...I have cigarette burns on my dash ..( when I bought the car )right above the ash tray on my 67 GTO...I have no plans of fixing that...
The Following User Says Thank You to MUSLCAH For This Useful Post:
  #107
Old 02-16-2024, 01:00 PM
Not too terribly far off from mine at the same plant and also was sold new at Taber Pontiac. Could have even been on the lot at the same time...
Sent from my moto g stylus (2021) using Tapatalk
The Following 2 Users Say Thank You to Greg Reid For This Useful Post:
  #108
Old 02-16-2024, 08:21 PM
Greg is there any chance you could photo the dates on your heads distributor and exhaust manifolds.
Even if not correct dates it might help Tedd find his dates.
Pretty cool they both came through same dealer and the same color.
  #109
Old 02-16-2024, 10:47 PM
I didn’t realize there are head numbers as well, I can easily retrieve those as well as the exhaust manifolds
And the spare tire on Monday. And Barron I spoke to Ron B The Original owner .. you were right! He bought the car because he saw it advertised so cheaply at the dealer and he purchased it off the showroom floor. He realized it was a stripped down model but he was young and didn’t care he could afford it. He also found a ton of old literature he gave me I will post it later .. Thank you .
The Following 2 Users Say Thank You to Tedd930 For This Useful Post:
  #110
Old 02-16-2024, 11:20 PM
Default A few pics
Attached a few pics of some paperwork and original shift knob given to me he has a lot more just working through 50 plus years of paperwork . Kinda cool so far !
ID:	628751   Click image for larger version
  #111
Old 02-16-2024, 11:29 PM
Super cool stuff about the original owner.
He probably knows if the wheels were black or blue too.
Yes please do get the date codes on those parts.
I listed in a recent (long) post on what/where to look for.
Document as much as you can concerning originality.
  #112
Old 02-16-2024, 11:35 PM
That shift knob was an extra cost option , not listed on your billing data.
But that doesn't mean that it wasn't there when he bought it from the dealer.
They could have popped it on there for a little bling , or by his request.
Its a fancy piece and desirable.
  #113
Old 02-17-2024, 10:40 AM
I was able to get this pick of top of the block next to the Distributor hole.
Block code pictures for comparison purposes. Different foundry?
ID:	628764   Click image for larger version
The Following User Says Thank You to Pepper Judge For This Useful Post:
  #114
Old 02-17-2024, 11:14 AM
242177P's Avatar
242177P 242177P is offline
Same foundry, different line. Semantics.
(Note the big ol' #1 and #2)
The Following User Says Thank You to 242177P For This Useful Post:
  #115
Old 02-17-2024, 11:17 AM
johnta1 johnta1 is online now
Same foundry, different core box (or whatever they are called)?
edit: tree'd looks like
  #116
Old 02-17-2024, 12:56 PM
Agree
Numerous core boxes / molds and pouring lines to handle production demands.
At one foundry
  #117
Old 02-20-2024, 08:24 PM
Default Manifold numbers and spare tire pics
Baron ,
Exhaust manifold and spare tire attached
ID:	629060   Click image for larger version
ID:	629061   Click image for larger version
ID:	629062   Click image for larger version
ID:	629063   Click image for larger version
The Following User Says Thank You to Tedd930 For This Useful Post:
  #118
Old 02-20-2024, 08:26 PM
Default More pics of trunk and engine
See attached please review and confirm thank you.. also attached thermostat housing
ID:	629065   Click image for larger version
ID:	629066   Click image for larger version
ID:	629067   Click image for larger version
ID:	629068   Click image for larger version
  #119
Old 02-20-2024, 08:46 PM
Yeah, when I get home. I'm away for a couple of days. I may have thrown one of the manifolds away because one of the mounting ears was broken off. I kept the other one because it still has the flapper that works and I know that's kind of rare. The distributor I could have sworn that I had but I have not been able to find it recently. I remember it had a metal tag on it. I actually looked for it not long ago.
By the way, my engine is not the born with engine, it just happens to be the correct engine for my car. The guy I got the car from called me up one day and said he had an engine that he thought I'd be interested in. It was complete from carb to pan and ran like a top right in the junk car that it was sitting in. Even the choke worked.
  #120
Old 02-20-2024, 10:50 PM
242177P's Avatar
No spacer on starter solenoid. Low torque replacement.
