Old 08-02-2011, 09:10 PM
Pepi's Avatar
Pepi Pepi is offline
Default confused on clearance
Hey George,
I am a little confused on the clearance. You say if the clearance
Originally Posted by george kujanski View Post
If your clearance, (regardless of cast or stamped) is more than say, .060", YOU ARE THROWING AWAY COOLING EFFICIENCY. I tweaked mine from about .250" down to about .100" and it made a drastic change in my engine temps with no other changes.
But then you say you tweaked yours down to .100". That is .040" GREATER then .060". Did you mean .010"?
I just pulled my pump, and it is cast, and I am getting about .063".
I measured it without pulling anything apart yet, so it has the divider plate still sealed on. I am debating if I should try to reduce that clearance or should that be good.
Thanks,
Pepi
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
  #1182
Old 08-04-2011, 05:06 PM
Pepi's Avatar
Anyone with experience on this matter have any thoughts as whether I should leave the clearance alone at .063 or try to get down to maybe .010?
Thanks,
pepi
  #1183
Old 08-04-2011, 05:15 PM
george kujanski's Avatar
Hi there......When I did that, I had a lot of clearance, and wanted to experiment if minimizing the clearance would help. My first try got it to the .100" dimension and tried it out with success.
Undoubtedly a smaller gap is better; at your dimension I would leave it alone. Some members do an interference fit without a gasket, the gasket provides the necessary clearance.
Next time I take mine apart, i'll close it up some more.
George
  #1184
Old 08-04-2011, 05:18 PM
Pepi's Avatar
Okay thanks George. I'll put it back on the way it is, guess I am lucky, and out only one gasket since I didn't take the divider plate off, and it is still sealed onto the pump.
  #1185
Old 08-09-2011, 12:30 PM
DanC's Avatar
DanC DanC is offline
Question 8 bolt Divider Plate "Key Hole"?
OK, I've been following this post with great interest and finally got around to pulling my 8 bolt pump this past weekend to see what I have.
What I had was a stamped steel impellor with 1/8" clearance.
Now I just picked up a Cardone with the cast impellor. It had a 1/4" gap. So I've pulled the impellor up to 1/8" clearance and then lightly hammered the plate down to create a .081" clearance to the vanes.
My question is, the divider plate center hole does not have a "key slot" in it like some of the pics I've seen. Is that good, bad, or no issue?
How I did it 101:
I pulled the impellor by enlarging the three holes to 17/64" and tapped 5/16-24, then used a puller to bring the end of the impellor flush w/ the shaft. I then used a 'Nissan' pulley (which is a little larger than the Pontiac divider plate hole), and hammered the plate flange down. Used drill bits to gage the clearances.
DanC
  #1186
Old 08-09-2011, 01:21 PM
Groucho's Avatar
Groucho Groucho is offline
Good thread. But, it's gonna be tough reading almost TWELVE HUNDRED posts when I need to research this the next time I do a Pontiac W.P.
Big Willie and Tomika's Street Racers
STUGOTS-SoCal
Adding more power since 1971
  #1187
Old 08-09-2011, 07:04 PM
69-er's Avatar
69-er 69-er is offline
Originally Posted by DanC View Post
...So I've pulled the impellor up to 1/8" clearance and then lightly hammered the plate down to create a .081" clearance to the vanes.DanC
It's been awhile since I participated in this thread. Did we discuss pulling the impeller out closer to the plate? I don't believe I did as I was concerned about water possibly flowing to the back of it, reducing efficiency. I massaged only the plate until I got the required clearance.
It worked beautifully, BTW!!
Larry
Larry
Current Project: 69 Camaro LS-2 Pro-Touring, complete build
__________________________________________________ _
Next in line: Numbers Matching 68 400, Finish interior and body work and paint
  #1188
Old 08-09-2011, 08:08 PM
Pepi's Avatar
I know, I started doing that when I had a question about the clearance. We need a summary posted, with questions and answers. I mean all the post with positive news and feedback and other thoughts are good, but the really important stuff will get lost in the 1200+ post.
  #1189
Old 08-10-2011, 09:17 AM
DanC's Avatar
Larry
Yes there are 21 posts about moving the impeller position in this thread. I didn't actually count them, but rather did a "pull impeller" search on this thread and it came up with 21.
I'm no engineer, but I'd think that once the water has filled the cavity and is swirling around in the pump, with the closed gap at the plate, that the water would be forced out of the two holes.
Anyway yesterday I found that my divider plate that goes against the timing cover has gaps where the flared water outlet meets the cast tube on the RH side of cover and a gap where the partial flange on the LH side meets the flush hole on the cover. Wondering if I should JB Weld a cone there for the flare to fit in?
DanC
  #1190
Old 08-11-2011, 09:00 AM
troy_barker's Avatar
troy_barker troy_barker is offline
Yep thats alot of post, I started reading days ago and still not finished. So...I skipped to the last page.
Anyway I have an 8 bolt setup with a cast impeller, the clearance between the impeller vains and the plate is 1/4 inch. I am guesssing that distance needs to be reduces to at least 1/8th?
Bring back my 67 GTO: Shes ALIVE as of 2-19-13
previously owned
78 Firebird
67 Nova
64 Nova
  #1191
Old 08-13-2011, 08:33 PM
DanC's Avatar
Thumbs down Cast vs. Stamped - No diff 4 me!
How I did it 101:
DanC
OK, finalized the install of my Cardone Cast Impeller WP and test drove this afternoon.
WP specs: 4-5/8 dia impeller, 11/16" vane height, .081" vane to divider plate clearance
Outside air temp 83 w/ 96% humidity (Cooler than usual - just rained). 180* thermostat
A/C 'on' and driving 60mph coolant temp still at 212*, same results as my stamped impeller was with it's 1/8" clearance. Temp was ~180* in traffic. Temp gauge markings verified with my infared thermo gun.
Checked timing and have 14* inital & 28* w/ vac adv hooked up. 60* total @ 3600
Disclaimer: These results are not typical (as per this thread). All tests were conducted using the same vehicle under uncontrolled conditions and no other changes made other than listed in my 08.09.11 quote above, including the performed JB Weld mod. No "key hole" on divider plate.
I'm glad I was never bothered by the temps, since nothing changed, but curiosity had gotten the best of me about these cast impeller and clearance claims. So this inquiring mind just had to know
DanC
  #1192
Old 08-20-2011, 09:46 PM
Blk 76 Blk 76 is offline
I know the pump on a small block chevy is totally different but my 1990 chevy truck has always run hotter than i think it should, could it be because of a stamped impeller? I do not know when they started using these and it makes me wonder what impeller is inside my pump.
  #1193
Old 12-04-2011, 11:18 AM
Brent Flynn's Avatar
Brent Flynn Brent Flynn is offline
DanC
Unless im reading this wrong, the reason you arent seeing any improvement, is, you are runnin WAY too much total timing... back it down where you are only running 36deg total.... you are bout to destroy some headgaskets if this is a Pontiac engine.... or any other engine, for that matter.... it will run hot like that. Im surprised noone else commented on this...
1968 Firebird 10.817/122.33 3600lbs trw 455, iron d-port heads/SD intake/q-jet, 9" tires 1.440 60ft
1962 Catalina 4100lbs trw 455, iron d-ports,perf RPM, 800holley, 9'' tires,(12.157@108.91)1.578 60' Oct 2010!!
  #1194
Old 03-12-2012, 06:04 AM
Old Goat 67's Avatar
GENTLEMEN,
Spoke with "rockdoc" last evening and he advised me he had procured a Cardone pump from Rock Auto with the CORRECT impeller.
http://www.rockauto.com/catalog/x,ca...,parttype,2208
http://www.cardone.com/Products/Prod...ear=1967&info=
Seems Cardone has a NEW pump that came out called "CARDONE Select [New]-Part Number: 55-11137.
Dave is going to post pictures when he has time, but he is on the road just now. I thought some of you may need this info ASAP.
Charles
  #1195
Old 03-12-2012, 09:21 AM
The links don't keep the info needed.
Search for part # PWP381 on Rock Auto for correct info.
Charles
  #1196
Old 03-13-2012, 09:45 AM
Email from Cardone contact says this today.
Charles,
I am in meetings most of the day, but just wanted to respond to your voicemail. No, the Select version of our 58-299 is not the impeller fix. I mentioned to Gary that I would give you both a call in a few weeks to resume discussions for this. I appreciate your patience considering the circumstances. Will be in touch.
Regards,
T
  #1197
Old 03-17-2012, 09:32 AM
Charles
Pretty, NO cigar!
Quote from cardone rep,
Name:	Water pump-new 001.jpg
  #1198
Old 05-01-2012, 05:06 PM
81v8gp 81v8gp is offline
I guess I would be save to say that this procedure would apply to my vehicle also. 1981 Grand Prix with a 265 V8. Same block as the 301 and my water pump has the same divider plate. I recently installed a new timing set, water pump and divider plate. Started the car up and temp ran up to 230. I have owned this car since new and the temp has never gone over 190. The weird thing is, when I would turn the heater to hot the temp would drop to 190. I tried changing the thermostat, sending unit and had the radiator boiled out, but nothing helped. A guy over at 301garage.com suggested I try this site. Well I am going to rip this apart tonight and see if the impeller is anywhere near the divider plate.
  #1199
Old 05-01-2012, 08:12 PM
Stuckinda60s Stuckinda60s is offline
Your heater acts as a radiator, that's why the engine cools when you put water through it.
Rich
The real democratic American idea is, not that every man shall be on a level with every other man, but that every man shall have liberty to be what God made him, without hindrance.
Henry Ward Beecher
"The problem with socialism is that you eventually run out of other people's money." Margaret Thatcher
  #1200
Old 06-27-2012, 01:49 PM
sixgunsblazing's Avatar
sixgunsblazing sixgunsblazing is offline
Grr.
Why the heck do replacement waterpumps only come with one gasket when you need two, one for each side of the plate? Fun to find out at 7Pm when the shop's closed.
