Old 12-06-2023, 07:15 PM
Tim Corcoran's Avatar
Originally Posted by mrennie View Post
Probably, but was looking for actual results if anyone had measured them on a tester. I have no doubt SM can give me specs but I have trust issues. Will likely measure them myself prior to doing anything but was just curious if anyone had some existing experience.
That's why I ordered mine bare, so I could control everything and get what I want/need for my specific application
Tim Corcoran
  #122
Old 12-06-2023, 08:11 PM
Steve C. Steve C. is offline
"That's why I ordered mine bare, so I could control everything and get what I want/need for my specific application"
Winner, winner, chicken dinner !
Old information here:
  #123
Old 12-07-2023, 11:00 PM
Dragncar Dragncar is offline
I took my fuel filter and put thicker O rings on. It will seal but its tighter on one cap that the other, like they are not exactly the same size. The outlet ends hole was only 3/8" and it uses a 1/2" hose. I drilled it out to 7/16" then a little more to 11.5mm.
The fuel pump has this very,very fine screen stuffed into the inlet(I guess) side. Its so fine and small enough that it will be a restriction. I will remove it.
  #124
Old 01-01-2024, 01:54 PM
performerrpm's Avatar
performerrpm performerrpm is offline
Send a message via AIM to performerrpm
so anyone put there out of the box edelbrock valves and springs in the speedmasters?...just wondering since i have somecomplet eheads im gonna have ported that wont be needing the edelbrock valves and springs
  #125
Old 01-02-2024, 02:12 AM
blueghoast's Avatar
Edelbrock valves are ussually short stem's, KRE's are longer and SM
Just somthing I noticed.
GT
  #126
Old 01-02-2024, 05:59 PM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
My SM same length as Eddy 72cc E heads -and if pull all the shims out the IH can be near 1.9" with them! I think they are Aussie made from the numbers on the valves.
I have a set of take off E head single springs I'll send you-went with duals for HR. Their valves may not be good enough for solid roller spring pressure-they will tell you that is you ask-some on the 409 heads.. Some of their valves are made by Ferrera but Ferrera will not tell you what quality but hinted more at the 5000 series level.
Skip Fix
  #127
Old 01-03-2024, 09:27 AM
thats good to know, i hate to waste some basically new valves if they will work with the sm heads i bought on black friday. sucks the eheads have ft springs but ill probably just order some edelbrock springs to go with it. after the valve job ill still be into the sm heads for less than 2k for the 310cfm version.
  #128
Old 01-03-2024, 11:39 AM
Unless changed Edelbrock uses a single coil spring.
  #129
Old 01-27-2024, 06:25 PM
i have a question about the known dip just below a couple of the intake valve seats.
i had to order a 2 gallon kit of a product by carboline called splash zone 788. while reading about it i seen its used to repair or smoooth out intake ports on both heads and manifolds. would this product be suitable to smooth in the small void in these casting or is it too close to the chambers to be a safe fix? i dont know how much that spot would really affect a street car if any at all but if it could be fixed without welding or anything to exotic i might woukd give it a shot
  #130
Old 01-27-2024, 06:34 PM
tom s tom s is offline
SZ is a remarkable product.Used a lot by pro head porters in intake manifolds and intake ports.Not sure how it will hold up under the valves.Reher Morrison uses it a lot.Might give them a call.Tom
  #131
Old 01-27-2024, 07:02 PM
steve25 steve25 is offline
Could you post a picture of this dip?
  #132
Old 01-28-2024, 10:55 AM
ta man ta man is offline
Any actual drag data or dyno numbers on these heads? I haven't seen any.... just forum discussion? Somewhere someone must be running them?
  #133
Old 01-28-2024, 11:11 AM
Default the dip
give me just a bit and ill see if my phone will take a good enough picture. its easier to feel than see
  #134
Old 01-28-2024, 11:12 AM
Default hp numbers
i seen the owner of pontiac speed shop mention he was near the 800 mark on fb
  #135
Old 01-28-2024, 02:00 PM
Default pics
i put a few of the overall head just because
ID:	627332   Click image for larger version
ID:	627333   Click image for larger version
  #136
Old 01-28-2024, 02:05 PM
Default couple more
its hard to see but its almost as if the valve seat is a bit smaller than the actual bowl area. these are the 78cc 310 cnc heads. its a really small area about quarter inch long and its right where the seat wall meet. u can see where the maching stops and cast starts, its right in that area.
i was gonna get so.e 80 grit sanding rolls an just kinda clean up.the rest of the as cast area and try slightly blending that area in...but then i seen the epoxy i mentioned.
what do you think
ID:	627335   Click image for larger version
