#1441
![]() Quote:
Figure of speech everyone understands. Ever heard someone say they were so hungry they could eat a horse? Do you really go on to believe they could really eat a horse? You police officers take things too literally. Thanks too all who have defended me, and really understand these things.
#1442
![]() Quote:
It should have came back with me so I could measure it very closely to see how I could have missed it. That way, at least I learn something else from this whole experience. Having questions without answers is frustrating.
#1443
Paul,
I want to remain cool with you but when you say the bearing spun and was eaten up, being a cop has nothing to do how that's interpreted. That's not a good look! The guys here will eat that up. I say you and I figure out what we spoke about and move on with our lives. Sent from my SM-G955U using Tapatalk |
#1444
![]() Quote:
BTW, I've defended you plenty in my conversations with Joe.
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears 66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
#1445
That's what I was trying to say. It's a figure of speech, in a language that everyone can understand here, rather than Paul going into great detail of exactly what happened and confuse most people in here. His spun bearing was not meant in a literal sense, but just to explain a situation in a common language for everyone, to "dummy it down" so to speak.
If you want a final explanation in more detail read post 1400. And yes, there were many throughout this thread that threw stones at Paul, threw him under the bus (another figure of speech) and blamed him. I have a list. Now I have to go take a chit. Wait a minute you don't take one, you leave it. But everyone knows what that means right? ![]() |
#1446
![]() Quote:
It takes considerable knowledge just to realize the extent of your own ignorance. Dr. Thomas Sowell |
#1447
I'd predict that we will ALL be measuring across the skirts tips from now on.....
I know that I will. Religiously. Twice. ![]() Better to learn from someone else's experience (much less expensive for me...). Glad this all got figured out. ![]() ![]() ![]() ![]() ![]() |
#1448
![]() Quote:
Sent from my SM-G955U using Tapatalk Last edited by Va68goat; 09-24-2019 at 03:22 PM. |
#1449
![]() Quote:
Lots of good questions could be answered by this burnt offering to the god of speed.
I could explain all this to the girl at the parts store, but she'd probably call the asylum. White '67 LeMans 407/TH350/Ford 3.89... RIP Red '67 LeMans. 407/TH400/Ford 3.25 Last edited by chiphead; 09-24-2019 at 03:57 PM. |
#1450
I do know that about 95% of the novices that use the term "spun a bearing" have no idea what that means. And they use that same term for every bearing problem they see. You'd be surprised how many people don't know that it means the bearing shell itself rotated. They see a trashed bearing .... "Hey look, it spun a bearing".
It has without a doubt become a generic term for bearing damage outside the world of engine builders. If I was talking to a novice ... yeah, rather than explain the intricacies of a bearing clearance issue, contamination, oil starvation, or machining issue ... it's quite possible I would say ... "Yeah bro, it spun a bearing, I gotta tear it down again." |
#1451
Since I think too literally and I only understand "cop jargon". I found a place for the piston. I call it "exhibit A"! Thats just a figure of speech of course...or is it?
![]() Last edited by Va68goat; 09-24-2019 at 04:46 PM. |
#1452
I like that, I keep an oil pump shaft that broke and cost me a motor.
#1453
I normally measure the piston at the "Gauge point" provided by the piston manufacturer just like Paul did. In an abnormal situation like our funny car engine I measure at the tip of the skirt because I know that is the largest diameter of the piston......and I know I need at least .0125" clearance between the tip and the wall to keep that engine alive. If I was building the same engine as Paul was, I would not have measured the tips. Until NOW! As it was said, all of us who build engines will be measuring them now after this debacle. All these years and still learning.
#1454
![]() Quote:
#1455
![]() Quote:
But Joe wouldn't know this, he's new to cars. I think he's said that himself about 100 times in this thread. Which is why Paul explained things initially in layman's terms. |
#1456
I got a question.....”IF” a bolt or debris/whatever DID go down the intake during the many.many, times the engine has been worked on, was there a mark on the combustion chamber? No scoring on cyl? Or “ multiple” dings and witness marks as it was bounced around?
GOD does business with people that mean business! |
#1457
![]() Quote:
#1458
![]() Quote:
You're not paying close attention. You may be suffering from selective comprehension. Paul mentioned that I was a cop..not me (see picture). As I said before, I may be new to cars but I'm no fool. I have a group of friends that are helping me that know as much about cars as you do or more. If Paul used a "laymans" term to tell me about the failed dyno when I am inexperienced with cars, why he wouldn't he have described the issue instead of using the term "Spun bearing". As I said before, you and Paul both jumped when I said the motor "blew up" on the dyno correcting my laymans term of the failed dyno but yet Paul uses a laymans term to describe the failed dyno on this forum? Come on. You have no idea how much worse you are making this situation. This piston has been inspected by two machinist. I have saved everything since the failed dyno and as I said before, Virginia and Arizona are both one party consent jurisdictions. I have protected myself..believe that! You really don't want to push this where it doesn't need to go. You will be doing Paul a favor by just reading and not typing or feel free to call me..you have my number! As far as I'm concerned, Paul and I are ok, we need to keep it that way. shoebox1.1, It's a "theory" that something fell into the cylinder. There was no damage that Paul or my friends found in the cylinder. Paul said it could have been a piece of a gasket that could have gotten in there. There was a slight impact mark on the head as well. I was told that theory of something falling in there is as plausible as the piston hitting the head. Last edited by Va68goat; 09-24-2019 at 10:14 PM. |
#1459
Did the head get resurfaced or do we have a pic of that as well?
#1460
shoebox1.1,
All the work was done in my garage so no resurfacing was done on the head while he was here. |
Closed Thread |
