#141
George, Do your PMD caps have the spring clips or the aftermarket washer attachment? It looks like you could get them to mount using either of the attachment scenarios.
"Pride Precedes The Fall" 1968 Firebird Undergoing Transformation 1970 Formula 400 - Keylime Green, Stroked to 462 Cubes - Gone But Forever Remembered 2016 Mustang GT - GT with the Performance Pack, beats my former 12 Boss around the track. |
#142
Bird after US Mag Bandits
Here are a couple of pics outside.
Forgive the glare, or not! |
#143
This is my Firebird, fresh from a suspension overhaul by Global West, resulting in a 1 inch drop at the front, 2.75 inch drop in the rear.
Fronts: 17 x 7 torq-thrusts, 4" backspace, 225/45-17 tires Rears: 17 x 8 torq-thrusts, 4" backspace, 245/45-17 tires Have to admit I'm strongly considering U.S. Mag's Bandit wheels...
Raffi R. 1968 Firebird: 350 .040 over, #11 Heads w/2.05/1.66 valves, Tomahawk TC-03 cam (214/221 flat tappet cam, 112 LSA, .0450/.0465 lift w/ 1.5 rockers), 200-4R w/3.55 gears, Street Demon 625 w/ Edelbrock Performer, H-Pipe dual exhaust w/Delta Flow 50's. |
#144
2 different brand 17" redlines, how did you work that?
___________________________________________ the more im around people, the more i like my dogs |
#145
We couldn't get the same brand in 255 and 235
Diamondback will cut for you whatever size or manufacturer tire available to them per your order |
#146
Posted a pic of my combo a couple of years ago but have made many changes to suspension including DSE UCA/LCA, 2" drop coil springs, hollow sway bar, 3" drop rear with composite spring, C6 Z51 13.5" front and 13" rear disc.
Front Nitto 255/45 and rear Nitto 285/40 on 17" YO snowflakes. |
#147
That is SICK formula JG! Love the color too. What paint is that?
1971 Base Firebird..505ci IA 2A Round port E-heads by Butler 348 cfm.. Comp street SR 266/272@.050 Victor intake/Quick Fuel Q950. 1 7/8" Dougs headers..3" mandrel bent exhaust with Hooker Max Flow mufflers, T-350 well built with 10" 4000 stall nitrous Continental converter..3.73 posi . Caltracs and 10" slicks. Belt driven water pump, alternator, Pwr steering and brakes,Flex fan. 11:1compression, straight 93 octane pump fuel. 10.35 @ 129.88 with 1.45 60ft N/A at 3700lbs race weight. |
#148
Looks like Nocturne Blue. I had a 79 t/a in that color. It is nice.
#149
Thanks guys.
Actually it's a custom version of a (closes your eyes) Toyota color called "Dark Emerald Pearl Mica Metallic". We added a touch more blue, black and pearl and this is what we got when we painted it in '95 and if I were to do it again I wouldn't change a thing with this color, almost 20 yrs later and I personally still love it. If I can sort out the brake bleeding I'll get it out of the garage and take another pic in the daylight. |
#150
IIRC the color was supposed to be Brewster, but the paint & body peeps said the paint shop mixed it incorrectly. It still looked great, a Dark Emerald Metallic if you will. It too had blue tone mixed w the emerald. IIRC it was the same Brewster paint code # on the chart, just wrong application. BTW - Yours looks great. How's the ride? |
#151
Thanks again for the compliments.
I can't speak on the ride just yet there are 3 areas I'm trying to address (brake bleed issue, toe-in aglinment and 17"YO hub bore oversize) before the snow hits. Hope to have these all worked out this weekend though. |
#152
-Daryl |
#153
Ladies and Gentlemen, the 72 Blackbird has found her new shoes
US Mag 18 x 9 Bandits 275/40R18's F/R H-O Racing 600 lb. front springs/WS6 rear leafs |
#154
#155
Zyman,
The PMD caps do really set the Bandit wheels off- I'm wondering if the Pontiac Chevron caps will work the same way. But the for the meantime the caps that come with the wheels look good enough for me. Geno |
#156
For all you guys who bought those new throwback wheels, how do you like em?
461ci, Edelbrock 72cc heads, KB 15cc dished pistons, comp xe274, PRW 1.5 roller rockers, Performer RPM intake, Holley 80508 750cfm, RARE oversized manifolds, Pypes X-pipe Exhaust |
#157
Front
CCW 18x8.5 5" bs Michelin 245/40R18 Rear CCW 18x10 5.5" bs Michelin 275/35R18 0.125" spacer Mods 73 Chevy Nova 10 bolt rear rolled fender wells Disc conversion front & rear Lowered 2 inches
- Tom |
#158
#159
69 gto
I have a 69 gto 15 inch rims. The tires on the front are 215\65\15. I would like to go to a little bit taller tire to fill the wheel opening, say a 225\70\15. The 225 are 27.4 inches tall and the 215 are 26inch high. Would 27.4 be too big around?
#160
I would love to see a full car shot with the black painted Year Ones !
