Motor mounts
It seems like I'm replacing motor mounts every year. Has anyone found a good one for use on the 69 Firebird? I drive it hard, but it should still last longer than these do.
When people tell me they HAD to sell their car when they started a family, I show them the three car seats in the back of my 69Trans-Am..............and we didn't even use car seats back then!! Last edited by azbirds; 05-11-2019 at 10:57 AM. Reason: spelling |
NAPA motor mounts
I installed NAPA motor mounts on my GTO, haven’t had problems but I don’t drive it much or hard. What brand are you using?
Ron |
You may want to look for some pics of the modifications that can be done to a new mount to help prevent breakage. I think there's a good photo in Jim Hand's book showing his method.
'65 Tempest 467 3650# 11.30@120.31 |
Put a solid on the drivers side , stock in the passenger side .
I did this after destroying both side of auto parts store ones and then broke the drivers side Mity mount . Left the passenger mity mount on and put the solid on the drivers side three years ago and no more issues. Do a search here their’s a few topics in it
74 Formula 469, 6X-4's, 72 Intake, Ramair Manifolds. 3 inch exhaust with x-pipe Custom Roller Cam, 1.52 Roller Rockers Quadrajet done by Cliff 3:42 gears 12.075 @ 112.70 12.092 @ 112.43 12.128 @ 111.71 |
I believe it has AutoZone mounts last install. My TA is a stick and I know when it fails because the Z bar falls off the stud on the block. I will see what NAPA has first and mighty mount 2nd. It's fun driving home with no pedal! Thanks for all the suggestions. I'll have to look at Jim Hands book, it's around here somewhere.
When people tell me they HAD to sell their car when they started a family, I show them the three car seats in the back of my 69Trans-Am..............and we didn't even use car seats back then!! |
I had the same issue with my 69 Firebird conv 350ci. I was replacing the drivers side mount 2-3 times a year. I believe it was only making approximately 450RWHP based on its 115mph trap (Low 12s, traction limited)
My fix seemed to work well and I have not had to replace a mount in over 10 years. I was close to buying solid mounts however I had an idea that I wanted to try before doing so. What I did was I mounted a turn buckle at the back of the engine on the drivers side upper transmission bolt and down to the frame. I lightly preload it by hand and safety wire it to keep it from loosening up. And when I say preload, I really mean just finger tight... I left a very small amount of slack to allow slight movement. On track days I would snug it down by hand removing any and all slack. This was a real cheap mod and did everything I needed it to do. It limited twisting under load yet allowed me to run the rubber mounts instead of solid mounts. You just have to remember to remove it when pulling the engine... LOL SPEED SAFE, NICK
"The grass is not greener on the other side, its just fertilized with different $h!t" Last edited by AIR RAM; 05-11-2019 at 04:51 PM. |
I have 4 years on my mounts no issues..I don't drive mine too hard
Any rubber mounts available today are bottom-feeder Chinese or India-sourced crap.
MityMounts are those same bottom-feeder parts, with a few machine screws crammed into position, and the decimal point on the price moved one place over. As said, about the best you can do is to install a torque-motion limiting device. GM used cables-and-brackets, some guys use rod-ends and turnbuckles. There's as many ways to do it as there are guys creating them. |
I've thought about a limiting device but it has to be hidden very well. I like the idea of it in the back but I will have to see how it would work with my Z bar and linkage. The NAPA mounts I just picked up don't look bad, but a $7 you have wonder how long they will last. I shock people with this car because you don't see 69 TransAm's running hard in autocrosses, so going easy on it is not an option.
Just put solid mounts on it you'll never know the diff.
And know more broking mounts. I run them on all my cars And no problems at all. GT. |
I have Butler poly mounts, and no issues.
1965 Pontiac GTO 455/469 w/ #48 Heads, '65 Tri-Power 9.25:1 CR Stump Puller Cam Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00 3.55 Rear Differential Front: 225/60R15 Height: 25.6" Rear: 275/60R15 Height: 28" |
I got the basic rubber mounts from Napa 9 years ago. Took 9 years before the settled to where the oil pan is sitting on the subframe no breakage or cracks in that timeframe.
It is easier to fool a man than it is to convince he has been fooled |
Had the same problem breaking motor mounts on my 400 & just put on a set of Butler's solid mounts. Wish I did this year's ago
Chris D 69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60' |
I ran with a stick shift turbo car making 700+ poly mounts and ran a chain from the back of the drivers head to my frame. could not see it it worked great. Go with a solid mount or a mid plate which I have now.
Same here.
66 GTO, 495, M22, Strange S-60 w/4.10 Sold new at Ace Wilson's Royal Pontiac http://www.youtube.com/watch?v=cUHC-Z8xhtg |
There are aftermarket options - I've used Tuff Mounts in a few other projects and they have an EXCELLENT name down under for surviving in +1500hp cars.
http://musclegarage.com.au/index.php...ory&path=80_89 |
I have used a chain for years with stock Pontiac Mounts and never had an issue.
Manual Trans vehicle and I beat the crap out of the engine/trans/rear axles shifting. I have a good rear axle now (Ford 9"), The three of the 8.2 stock rears and one 12 bolt did not survive. You want the chain or strap to have about a slight clearance to reduce vibration and let the mounts do their job. Lots of posts on this issue. Tom V.
Has anyone fab'd a mount like the A-bodies with a bolt rather than the method the first gen F bodies and X bodies use?
Does anyone have a pic of a chain setup that will mountvto the back of the head and not interfere with the z bar? I want to keep it simple
