Old 08-12-2020, 05:47 PM
gtobob67 gtobob67 is online now
Here's a 428 block that needed a tensioner added. This is an LS one modified to fit.
Name:	LS chain tensioner on 428.jpg
The Following User Says Thank You to gtobob67 For This Useful Post:
Old 08-12-2020, 05:49 PM
Scott65's Avatar
Scott65 Scott65 is offline
Milodon single idler won't make noise and is accurate when properly set up. Mine's been in service for 10 years now.
The Following User Says Thank You to Scott65 For This Useful Post:
Old 08-12-2020, 06:09 PM
firechicken's Avatar
firechicken firechicken is offline
I have a Milodon single idle as well for about 10 yrs. and is very quiet. I don't know what sound it makes because I've never heard any. No more chains for me.
The Following User Says Thank You to firechicken For This Useful Post:
Old 08-12-2020, 09:44 PM
Tim Corcoran's Avatar
OK the Milodon gear set sound like a viable option but I have always wondered how do you degree the cam in using gears is there an adjustment?
Tim Corcoran
Old 08-12-2020, 10:29 PM
Scott65's Avatar
Yes, you can time the cam. Here's a link, instructions tab is at the bottom, I didn't check it, but there's a separate pdf also available, Google. They also offer a video which I didn't use. Not sure it was even available when I did mine.
Edited to add: I would HIGHLY recommend you take their advice and do this with the engine out and on a stand.
Old 08-12-2020, 10:41 PM
Mike Davis's Avatar
I have run the Milodon gear drive in the past. Really nice piece. Quiet and accurate. Will be putting another in my next race engine.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 08-13-2020, 07:46 AM
GTOLou GTOLou is offline
Originally Posted by Gary H View Post
I bet a .010 chain will fix it. You'll be surprised how much tighter it's going to be.
I agree with this - at least try it.
Old 08-13-2020, 11:45 PM
Dragncar Dragncar is offline
I have a new .010 under Cloyes chain. The good one, made in Germany. 25$. The complete Cloyes billet .010 chain sets are about 160$. You would have to buy the gears. Cloyes will give you the part numbers and you can buy them from Summit.
My block has been line bored and it is not even close to fitting my block. I ordered a std chain.
Old 08-14-2020, 12:11 AM
Originally Posted by Tim Corcoran View Post
Unknowingly at the time I let a butcher put this engine together, a pontiac guy butcher. Unfortunately this is not the only thing he ****ed up.
If you don't want to throw out his name , could you tell what city and state he works from ? The hint could benefit others
Old 08-14-2020, 12:15 AM
I've seen numerous double-strike partial VIN's on blocks before, but never with 2 completely different VIN's.
Thats funky
Congrats on the tensioner. I hope it works long and well.
Old 08-16-2020, 11:29 PM
TransAm 474's Avatar
TransAm 474 TransAm 474 is offline
We ran into this issue a few months back on a 455 Olds engine we built. We bought a new Cloyes Street True Roller(Cast Gears) set $60, and it was waayyy too lose. After doing some research over on the Olds Forum, I quickly found out it was a common issue with that set. Everyone said to order the Cloyes Street Roller( Billet Gears) Set $85, as it fit much tighter, and sure enough, it cured the issue for us, the new set fit perfectly snug. Both sets were standard length. Not sure if there had been any same problem with our Pontiacs or not, but just thought I would share our experience.
1978 Trans Am
Pump Gas 461 Stroker
Old 08-17-2020, 12:31 AM
The name of the shop was Brooks Racing, in the Phoenix AZ area. Stay clear
Tim Corcoran
Old 08-17-2020, 12:06 PM
tooski tooski is offline
Unfortunately I had them do my block, too. I was told under a week turnaround (I now know why!) Three months later I got the block back in time for me to leave AZ. When I got back and was doing the assembly, I couldn't begin to install the cam. Just looking at the bearing I could see it was no longer round. How could the builder not see the bearing deforming during installation.?
Frank M.
75 Firebird
68 Firebird 400 RAIII
66 Chevy II 461 Pontiac in AZ
