Old 02-10-2000, 01:38 PM
Chiefpontiac's Avatar
Chiefpontiac Chiefpontiac is offline
Does anyone have an original '71 TA with either a 7041270 or 7041273 carb? I am gathering information on original Q-jet usage on these cars. My research so far indicates Trans Ams used the HO non-ram air carbs - 7041267 and 7041268. Any input is appreciated.
Aut viam inveniam aut faciam
1971 Trans Am 455HO M22; Cameo White / Blue
1971 GTO Convertible 455 M40; Starlight Black / Black
Old 02-10-2000, 02:22 PM
Rocky Rotella's Avatar
Rocky Rotella Rocky Rotella is offline
Between my dad and I, we have one of each. He bought his NOS and it's a 7041268. Mine is a 7041270 and supposedly off a 71 GTO. I know this doesn't help much, but if you need any info about either, please let me know. Both were replacement carbs dated 1978.
Old 02-11-2000, 01:20 PM
455ho 455ho is offline
What about a 7041262. I know it's off the 325 hp. motor. Does it flow the same as the H/O's or not. Thanks for any help.
Old 02-11-2000, 02:15 PM
The 7041262 uses the conventional booster ring stack and has small diameter venturi bores. This limits flow on these carbs to an approximate maximum of 750 CFM. The '71 HO and 4 speed carbs have had the booster ring removed to increase flow to around 790 CFM. The '73 and '74 SD carbs were developed from the high flow Q-Jets that Buick released in 1971. These carbs feature a conventional booster ring stack, but, had the venturi diameter increased to give an approximate 800 CFM capacity. These carbs are slightly more responsive and fuel effecient due to the extra booster ring that increases velocity past the venturi.
