Old 10-02-2023, 08:56 PM
grd777 grd777 is offline
Default need to be educated
had some gas coming out of ,i think a one of the vent tubes . i have work mostly on ford but not sure what all these tubes tube. can some one give a education on these tubes
Old 10-02-2023, 10:01 PM
RAJ7395's Avatar
RAJ7395 RAJ7395 is online now
Please share the model, year, engine, and if California emissions or not. That will help pinpoint exactly what the lines are for.
They look like the 70 bird California fuel tank vapor recovery lines but I want to be sure.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int
1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int
1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int
Old 10-02-2023, 10:05 PM
1972 formula 400 with air it is a Canadian car
Old 10-03-2023, 08:05 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Not sure this will help but when I had a stock tank set up in my car I had a leak in the front passenger corner. Turns out there is a vent there that has a short rubber hose that goes up above the rear. The original rubber hose had cracked/dry rotted and let gas spill out. There was also an obvious vent on the filler neck.
Chris D
Old 10-03-2023, 09:59 PM
not sur that my issue .just want to know how all this works
Old 10-03-2023, 10:23 PM
Trevor78 Trevor78 is offline
Do you have the 1972 Service and Assembly Manuals? Full of that fuel system info, I've had to upload it in the past.
Old 10-05-2023, 12:27 PM
unruhjonny's Avatar
did you remove the clamps from those hoses?
Because they should all be secured.
1970 Formula 400
