Old 12-31-2022, 08:42 AM
ponchjoe's Avatar
ponchjoe ponchjoe is offline
Default Correct Push Rods
Hi all,
I have a 68 400 that had a set of ‘73 #46 small valve heads. I am installing a set of 7k3s on it and was wondering what push rods would be correct? Are the ones from the existing heads correct so I can reuse them?
Ponchjoe
Old 12-31-2022, 08:52 AM
Gary H's Avatar
Gary H Gary H is offline
Yes, use the same length pushrods. Both heads take the same.
Old 12-31-2022, 09:15 AM
ponchjoe's Avatar
Thanks for the reply Gary. That’s what I’m coming up with in my research but always like to come back to the forum for the knowledge.
Old 12-31-2022, 09:52 AM
bulletpruf's Avatar
bulletpruf bulletpruf is offline
Originally Posted by ponchjoe View Post
Hi all,
Ponchjoe
If the heads or block have been decked and/or you're using aftermarket valvetrain, it's worth mocking things up to check to make sure your geometry is still good.
Please check out my YouTube channel for vintage/classic car and truck builds and shenanigans! https://www.youtube.com/watch?v=jq61KxKp1Is&t=14s
Old 12-31-2022, 10:26 AM
25stevem's Avatar
25stevem 25stevem is offline
You should also reuse the set of guide plates from both heads showing the least ware if you find any and the same with any of the push rods.
Look closely at the ball end that was in the rocker arm.
Many times when you compare the ball end that was in the lifter you will see how worn the rocker end is.
While your at it if you have 32 rockers from both heads look for worn contact area in the there ball socket and valve stem contact area.
On your 7K3 rocker studs look for ware grooves around where the rocker slot is.
If your not running a factory cam, but one with .450” lift or more then you should really step up to full 7/16” rocker studs and the needed. Poly locks to now make the rocker adjustment.
Your in there now so get everything as right as you can.
I do stuff for reasons.
Old 12-31-2022, 10:42 AM
25stevem's Avatar
Also note that your 7K3 heads do not have the outer exh manifold bolt holes on each end.
This makes having good sealing surfaces on the exh flange and manifold very important.
You should use a new grade 5 bolt in all location to clamp down the manifold.
Note, do not use a better grade 8 bolt because they will not provide the same stretch and in turn the needed preload.
Old 12-31-2022, 11:34 AM
Elarson's Avatar
Elarson Elarson is offline
Grade 5 and Grade 8 have the same modulus of elasticity and will have the same stretch when torqued the same amount.
Eric
Old 12-31-2022, 12:12 PM
ponchjoe's Avatar
Thanks for all the tips guys
Old 12-31-2022, 12:22 PM
Kenth's Avatar
Kenth Kenth is offline
I have found a lower grade bolt/screw will stretch more than a higher grade bolt at the same torque applied.
https://www.engineeringtoolbox.com/s...es-d_1426.html
https://view.officeapps.live.com/op/...gin=BROWSELINK
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 12-31-2022, 12:48 PM
ponchjoe's Avatar
Inspecting the 7k3s I found this. First question is why does Pontiac use the cap and the second can I just remove it instead of replacing one?
Old 12-31-2022, 01:03 PM
25stevem's Avatar
That caps proper name is a oil splash shield.
It’s needed because the stock set up uses a O-ring in the bottom of the retainer to block excess oil from coming down the valve stem.
That oil shield is part of that control system also.
The only way to dispense with those is to have your valve guides topped for what’s called positive valve guide seals.
Also while we are on the subject of these O-ring seals and they are original, it’s high time to change them, especially if the heads have sat for more then a few months because I can guarantee you they have become dried out to the point of cracking, and once they do that they leak excess oil down the stem.
Old 12-31-2022, 01:46 PM
ponchjoe's Avatar
Thanks for jarring my memory Steve. I remember the oring vs positive lock seals now. Appreciate all of your engine knowledge here.
Old 01-02-2023, 02:26 PM
Formulas Formulas is offline
that shield is cracked due to valve train instability as evidence by the wear on the stud
over reved improper, spring pressures or installed height whatever, that spring was dancing around hitting the shield and it cracked
Old 01-02-2023, 03:07 PM
Shiny Shiny is offline
Interesting.. perhaps what you're seeing is "localized" yielding of the threads if they are mating to stronger material or weren't formed well?
Is this a "known" behavior? Or does the application stretch the bolts to yield?
I understand the same "theory" as Elarson... elastic deformation, and therefore stretch, should be equal. If the bolts were "tightened to yield", then the difference would be quite noticeable.
Old 01-02-2023, 03:34 PM
Kenth's Avatar
Your 7K3s are modified with 7/16" studs and stronger dual valvesprings w/damper.
Pontiac never used oil shields on any Ram Air engine due to the stronger valvesprings used in those engines because the shields would brake.
Ram Air engines uses O-rings on valve stems in the retainers and PC-seals on intake valve guides instead.
Today viton PC-seals on all valveguides and oilshields is the "norm" and O-rings and shields are deleted due to most SS replacement valves are not cut for O-rings and stronger valvesprings than std are used.
FWIW
1966 GTO Tri-Power
1970 GTO TheJudge
http://gtoaa.org/
Old 01-02-2023, 10:34 PM
ponchjoe's Avatar
Thanks. Since I’m not changing the cam should I move the springs from the 46s over to the 7k3s?
Old 01-03-2023, 12:11 AM
Gonna need to check installed spring heights, spring pressure closed and open compare that to camshaft / RPM needs,
Could of just been over'reved alot the devil is in the details of which only you can figure out
