Kiddie pool on the passenger floorboard
79 GP.......It's not the Heater core.I noticed it after a hard rain.Most likely culprit(s)?
1. Bad door hinges, allowing the water to come in past the window weatherstrip by the dogleg area. 2.Rust around the top or side of the windshield glass. Take off the reveal molding and have a look. Vinyl top cars are especially bad.
Thanks. |
Another thing is to check the windsheild seal. Your summer sun bakes the butyl tape into crispy chunks.
so many pontiacs, so little time.................. moderator is a glorified word for an unappreciated prick.................. "Only two things are infinite, the universe and human stupidity, and I'm not sure about the former." --Albert Einstein "There is no such thing as a good tax." "We contend that for a nation to tax itself into prosperity is like a man standing in a bucket and trying to lift himself up by the handle." - Winston Churchill |
Remove the blower motor .
Reach your hand in a pull out all the rotted leafs and debris that is in the hvac box. Should be nice and gooey and possibly smelly. Fun stuff. There is also one small hole on the flat bottom that should be cleared . You will be able to see with a flashlight looking in. There is a flap/drain you should be able to feel that gets clogged shut also. The box fills in heavy rain and dumps into the car threw the lower venting. I drain some fresh water threw after cleared and soak it with Lysol. Let it air dry and put it back together.
"resurfacing Pa highways 2 long black strips at a time" 78 Olds Cutlass Drag car PONTIAC powered with 440 (destroked 455), th400, 12bolt with spool 4.10z Best to date 10.00@130.92 mph at 3250# 79 Grand Prix, will be new home for the 440 Goal 9.75z@135mph at 2900# 83 Malibu Wagon UUV Crate 350, Custom T5, 8.5 with Auburn posi 3.73z Making it the Ultimate Utility Vehicle Go, tow and show (not so much show, yet) |
