Old 07-08-2020, 11:39 AM
NAPA68 NAPA68 is offline
Default Balancing Ralley II's
I thought I would take the time to post my experience in order to save someone else a headache.
I have been pulling my hair out trying to get a couple of sets of Ralley II's to balance out correctly. Up until recent, I was using a couple of shops to handle the tire work for my shop. Frustrated with the results, telling me the tires are out of round, the rims are bent, etc........I bought my own balancing equipment. I have also found out on the Ralley II's, there is no real consistent or concentric way to mount the wheel to the balancer using the cone method. If you rechuck the wheel, the balancer would give you different readings.
Using a pin plate (like you have to for Honeycombs) is the most accurate way to mount the wheel to the balancer, as you are replicating how its mounted to the car. I also rechucked the wheel indexing it differently than how I balanced it, and the results are the same
While some of you may already know this, I thought I could save someone the BS of getting the vibrations out of your car. I'd ask the question to your tire shop and request that pin plates are used (otherwise known a lug centric balancing). It is a bit more labor intensive, but the results are worth it.
Tim
ID:	544531   Click image for larger version
ID:	544532   Click image for larger version
Old 07-08-2020, 02:37 PM
Bluesugar Bluesugar is offline
well I really appreciate the insite to this,...wish I was close to you so you could balance my wheels!!
Old 07-09-2020, 03:47 PM
Rocky Rotella's Avatar
Rocky Rotella Rocky Rotella is offline
Interesting! Where did you purchase the pin plates?
Old 07-09-2020, 10:09 PM
JAL71TA JAL71TA is offline
Great info...I have been trying to find a shop close to me that can balance my honey comb wheels for awhile now. Nobody knows how to do this anymore.
Old 07-10-2020, 07:50 AM
Rocky,
Here is the link.......
https://mt-rsr.com/collections/balan...nge-1-175-2-75
If a person were only to do say the GM 5-4 3/4, you can purchase a plate that does the size and some others. I wanted to be sure to be able to do the Ford, Chrysler, AMC, and older light trucks as well. Hence, why I bought the 4 plate kit.
The thing one needs to pay attention to, is the size of the shaft on the balancer. While to 40mm shaft is common, there are other sizes.
Tim
Old 07-10-2020, 10:15 AM
74Grandville 74Grandville is offline
Yup
Rally II's are lug centric, not hub centric.
when i worked at a tireshop, we used the pin plate for pretty much everything. thinking back, the only wheels that are hub centric are some trucks with flat lug nuts.
1979 Firebird Trans Am 301/4spd (Now 428)
1977 Firebird Formula 400/Auto
2007 Grand Prix GXP 5.3L
Old 07-19-2020, 07:46 PM
mgarblik mgarblik is online now
Thank you for that information. The pin plate kit for my Coats 950 balancer is $2,029 !!! Have to balance allot of lug centric wheels to pay for that! At a grand, I might consider it.
Old 07-20-2020, 06:27 AM
You might also want to know that the new "environmentally friendly" wheel weights will NOT clear the trim rings in Rally II wheels. I had 4 new tires installed at my local Town Fair Tire store. When they were done the manager comes up to me and says they can't put the trim rings back on because they hit the NEW wheel weights. I told him to use the weights that they took off and cut them if necessary. Some people just have no imagination.
Old 07-20-2020, 12:38 PM
I believe you should have a 40mm shaft. You can buy outside of Coats for a fair amount less. In fact..........if you are only worried about GM's per say, you can buy a plate that does the 5- 4 3/4 for around 300 ish.
https://www.tooldiscounter.com/produ...hoCo8IQAvD_BwE
Old 07-20-2020, 01:57 PM
Thanks for the info, NAPA68!
